龙人旗下深圳市龙芯世纪科技有限公司
  • 英特尔 LXT9785/LXT9785E 快速以太网 8 端口 PHY
  • 发布时间:2007/3/18 12:48:08   修改时间:2009/2/27 15:36:10 浏览次数:1879
  • 首页Intel半导体LXT9785EHC-C2
          采用了低功率、高性能的Intel LXT9785芯片,使10/100Base-T 端口在一般五类线上的连接距离可以高达200米。 此外,阿尔卡特还在其交换机中集成了英特尔LXT9785 10/100 8端口收发机 (transceiver), 它可通过低功耗和多接口简化多端口交换机的设计。
          The LXT9785 and LXT9785E are Intel's lowest power, highest performance octal 10/100 transceivers. The Intel LXT9785/9785E transceivers simplify multi-port switch design through low power, previous-generation register compatibility, and multiple interfaces. The LXT9785/9785E transceiver complies with all applicable requirements of IEEE 802.3 standards and demonstrates superior Ethernet performance with operation up to 200 meters.       LXT9785 and LXT9785E are identical except for the Voice over IP (VoIP) telephony features included in the LXT9785E transceiver. The LXT9785E is an enhanced version of the LXT9785 that detects data terminal equipment (DTE) capable of being powered remotely from the switch over a Category 5 cable. The system can use the information collected by the LXT9785E to apply power over the cable if the link partner requires it, such as an IP telephone. The LXT9785E offers an easy to use solution for OEMs designing VoIP systems that need to be as robust as typical PBX-based telephone systems.
    Product LXT9785/LXT9785E Features
    LXT9785/LXT9785E Key Applications
    Intel Carrier Class Ethernet
         Many networking and telecom applications require high-performance Ethernet components capable of operating under harsh environmental conditions. Intel Carrier Class Ethernet products support operation over the entire extended temperature range while providing features that increase reliability. Each device has an operation lifetime of at least 10 years with less than 100 failures per billion hours. All Intel Carrier Class Ethernet devices will be available a minimum of 5 years from product introduction.       The Intel Carrier Class Ethernet product portfolio includes solutions for Ethernet physical layer, switching and repeater technologies at a variety of speeds. Intel Carrier Class Ethernet products are ideal for applications where equipment must function reliably in uncontrolled environmental conditions such as base stations, telecom/network switches, factory floor equipment, and industrial computers.
    技术支持:
    LXT9785/LXT9785E DataSheet
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
