龙人旗下深圳市龙芯世纪科技有限公司
  • CCD照相机
  • 发布时间:2009/2/25 9:53:06   修改时间:2009/2/25 9:53:06 浏览次数:4420
  • 首页ATMEL 爱特梅尔CCD照相机
    CCD照相机
    CCD照相机
     CCD Areascan Cameras   CCD Monochrome Linescan Cameras
     CCD Color Linescan Cameras   CMOS Areascan Cameras
    产品参数表 产品参数表 到期停产的产品 到期停产的产品
    设备 描述
    Camelia C1 CL 8M CCD Color 8 Megapixels Digital Camera, 12 bit output, 3500 x 2300 pixels, Camera Link interface
    Camelia C1 LV 8M CCD Color 8 Megapixels Digital Camera, 12 bit output, 3500 x 2300 pixels, LVDS interface
    Camelia M1 CL 8M CCD Monochrome 8 Megapixels Digital Camera, 12 bit output, 3500 x 2300 pixels, Camera Link interface
    Camelia M1 LV 8M CCD Monochrome 8 Megapixels Digital Camera, 12 bit output, 3500 x 2300 pixels, LVDS interface
    设备 描述
    AKYLA HD Camera Link 3-CCD Color 3-CCD Prismatic Color Linescan Camera, 1k/2k active pixels, 10/14 祄 pixel pitch, up to 40 MPixels/s data rate, Camera Link Interface
    AKYLA HD LVDS 3-CCD Color 3-CCD Prismatic Color Linescan Camera, 1k/2k active pixels, 10/14 祄 pixel pitch, up to 40 MPixels/s data rate, LVDS Interface
    AVIIVA SC2 CL 4010 3 X 1365 active pixels RGB pattern, 10 祄 pixel, color version, from 20 MHz to 60 MHz data rate Camera link interface, flat field correction , up to 14l/s data rate
    AVIIVA SC2 LV 4010 3 X 1365 active pixels RGB pattern, 10 祄 pixel, color version, from 20 MHz to 60 MHz data rate LVDS interface, flat field correction , up to 14l/s data rate
    设备 描述
    AVIIVA M2 CL 0514 512 active pixels, 14 祄 pixel, from 20 MHz to 60 MHz data rate Camera link interface
    AVIIVA M2 CL 1010 1024 active pixels, 10 祄 pixel, from 20 MHz to 60 MHz data rate Camera link interface
    AVIIVA M2 CL 1014 1024 active pixels, 14 祄 pixel, from 20 MHz to 60 MHz data rate Camera link interface
    AVIIVA M2 CL 2010 2048 active pixels, 10 祄 pixel, from 20 MHz to 60 MHz data rate Camera link interface
    AVIIVA M2 CL 2014 2048 active pixels, 14 祄 pixel, from 20 MHz to 60 MHz data rate Camera link interface
    AVIIVA M2 CL 4010 4096 active pixels, 10 祄 pixel, from 20 MHz to 60 MHz data rate Camera link interface
    AVIIVA M2 LV 0514 512 active pixels, 14 祄 pixel, from 20 MHz to 60 MHz data rate LVDS interface
    AVIIVA M2 LV 1010 1024 active pixels, 10 祄 pixel, from 20 MHz to 60 MHz data rate LVDS interface
    AVIIVA M2 LV 1014 1024 active pixels, 14 祄 pixel, from 20 MHz to 60 MHz data rate LVDS interface
    AVIIVA M2 LV 2010 2048 active pixels, 10 祄 pixel, from 20 MHz to 60 MHz data rate LVDS interface
    AVIIVA M2 LV 2014 2048 active pixels, 14 祄 pixel, from 20 MHz to 60 MHz data rate LVDS interface
    AVIIVA M2 LV 4010 4096 active pixels, 10 祄 pixel, from 20 MHz to 60 MHz data rate LVDS interface
    AVIIVA M4 CL 2014 2048 active pixels, 14 祄 pixel, from 30 MHz to 120 MHz data rate, CameraLink interface
    AVIIVA M4 CL 6007 6144 active pixels, 7 祄 pixel, from 40 MHz to 160 MHz data rate, Camera Link interface
    AVIIVA M4 CL 8007 8192 active pixels, 7 祄 pixel, from 40 MHz to 160 MHz data rate, Camera Link interface
    AVIIVA SM2 CL 0514 512 active pixels, 14 祄 pixel, from 20 MHz to 60 MHz data rate Camera Link interface, flat field correction
    AVIIVA SM2 CL 1010 1024 active pixels, 10 祄 pixel, from 20 MHz to 60 MHz data rate Camera Link interface, flat field correction
    AVIIVA SM2 CL 1014 1024 active pixels, 14 祄 pixel, from 20 MHz to 60 MHz data rate Camera Link interface, flat field correction
    AVIIVA SM2 CL 2010 2048 active pixels, 10 祄 pixel, from 20 MHz to 60 MHz data rate Camera Link interface, flat field correction
    AVIIVA SM2 CL 2014 2048 active pixels, 14 祄 pixel, from 20 MHz to 60 MHz data rate Camera Link interface, flat field correction
    AVIIVA SM2 CL 4010 4096 active pixels, 10 祄 pixel, from 20 MHz to 60 MHz data rate Camera Link interface, flat field correction
    AVIIVA SM2 LV 0514 512 active pixels, 14 祄 pixel, from 20 MHz to 60 MHz data rate LVDS interface, flat field correction
    AVIIVA SM2 LV 1010 1024 active pixels, 10 祄 pixel, from 20 MHz to 60 MHz data rate LVDS interface, flat field correction
    AVIIVA SM2 LV 1014 1024 active pixels, 14 祄 pixel, from 20 MHz to 60 MHz data rate LVDS interface, flat field correction
    AVIIVA SM2 LV 2010 2048 active pixels, 10 祄 pixel, from 20 MHz to 60 MHz data rate LVDS interface, flat field correction
    AVIIVA SM2 LV 2014 2048 active pixels, 14 祄 pixel, from 20 MHz to 60 MHz data rate LVDS interface, flat field correction
    AVIIVA SM2 LV 4010 4096 active pixels, 10 祄 pixel, from 20 MHz to 60 MHz data rate LVDS interface, flat field correction
    AViiVA UM2 GIgE AVIIVA UM2 Gigabit Ethernet, Line Scan Camera, from 512 to 4096 pixels, 10 and 14 祄 Pixel Pitch.
    AViiVA UM8 CL 1205 12288 active pixels 5 祄 pixel, 320 MHz data rate, Camera Link interface.
    设备 描述
    ATMOS 1M30 CMOS Monochrome Area scan Camera, 8-10-12 bit Output 1312x1024 Pixels, Camera Link Interface, 24 fps.
    ATMOS 1M60 CMOS Monochrome Area scan Camera, 8-10-12 bit Output 1312x1024 Pixels, Camera Link Interface, 48 fps.
    ATMOS 2M30 CMOS Monochrome Area scan Camera, 8-10-12 bit Output 2112x1156 pixels, Camera Link Interface, 26 fps.
    ATMOS 2M60 CMOS Monochrome Area scan Camera, 8-10-12 bit Output 2112x1156 pixels, Camera Link Interface, 52 fps.
    CCD照相机 到期停产的产品
    设备 描述
    AKYLA MD20/30 CL 3CCD Prismatic Color Linescan Camera, 1K/2K active pixels, 10/14 祄 pixel pitch, 20 or 30 Mpixels/s, Camera Link interface
    Not recommended for new design: replaced by AKYLA HD
    AKYLA MD20/30 LV 3CCD Prismatic Color Linescan Camera, 1K/2K active pixels, 10/14 祄 pixel pitch, 20 or 30 Mpixels/s, LVDS interface
    CAMELIA Color 1.6 M Area array CCD Camera, 1536 x1024, Digital 3x12-bit Output 10F/s
    CAMELIA 1.6M Area array CCD Camera, 1536 x1024, Digital 12-bit Output 10F/s
    CAMELIA 2.5M Area array CCD Camera, 1840 x1360, Digital 12-bit Output 3F/s
    CAMELIA 4M Area array CCD Camera, 2048 x 2048, Digital 12-bit Output 4.3F/s
    CAMELIA 8M Area array CCD Camera, 3500 x 2300, Digital 12-bit Output 2.7F/s
    Not recommended for new design: replaced by CAMELIA M1 8M
    CAMELIA Color 2.5M Area array CCD Camera, 1840 x 1360, Digital 3 X 12-bit Output 3F/s
    CAMELIA Color 4M Area array CCD Camera, 2048 x 2048, Digital 3x12-bit Output 4.3F/s
    TH78CA13/14 High speed 8/12-bit Linescan Camera, 1024/2048 Pixels
    Not recommended for new design: replaced by AVIIVA M2 or SM2
    TH78CA15 High speed 8/12-bit Linescan Cameras, 4096 pixels
    TH78CD13/14 High speed 8/12-bit Linescan camera 1024/2048 pixels
    TH78CD15 High speed 8/12-bit Linescan camera 4096 pixels
    TH78CE13/14 High speed 8/12-bit Linescan camera 1024/2048 pixels
    TH78CE15 High speed 8/12-bit Linescan camera 4096 pixels, digital RS422
    TH78CH13/14 High speed 8/12-bit Linescan camera 1024/2048 pixels
    TH78CH15 High speed 8/12-bit Linescan camera 4096 pixels
    CAMELIA 4M-T20 CCD Frame Transfer Camera 12-bit 112MHz 4-Mpixels
    CAMELIA 8M-F10 CCD Full Frame Camera Head 12-bit 112MHz 8-Mpixels
    AVIIVA C2 LV 4010 4096 active pixels, 10 祄 pixel, from 20 MHz to 60 MHz data rate LVDS interface
    产品参数表 (CCD and CMOS Industrial Cameras)
    设备 CCD Type FPS at Max Resol. Max Resolution Output Pixel rates (MHz) Pixel Size (um) Power Supply (V) Rate lines/s 封装 绿色封装
    AKYLA HD Camera Link 3-CCD Color 3 color linear array - 1024 - 2048 12-bit up to 3 x 40 10 - 14 20 to 36 -
    AKYLA HD LVDS 3-CCD Color 3 color linear array - 1024 - 2048 12-bit up to 3 x 40 10 - 14 20 to 36 -
    ATMOS 1M30 B&W area array 24 1312x1024 8-10-12 bit up to 37.5 5 12 to 24 -
    ATMOS 1M60 B&W area array 48 1312x1024 8-10-12 bit up to 75 5 12 to 24 -
    ATMOS 2M30 B&W area array 26 2112x1156 8-10-12 bit up to 75 5 x 5 12 to 24 -
    ATMOS 2M60 B&W area array 52 2112x1156 8-10-12 bit up to 150 5 x 5 12 to 24 -
    AVIIVA M2 CL 0514 B&W linear array - 512 8-10-12 bit 20 to 60 14 12 to 24 98K
    AVIIVA M2 CL 1010 B&W linear array - 1024 8-10-12 bit 20 to 60 10 12 to 24 57K
    AVIIVA M2 CL 1014 B&W linear array - 1024 8-10-12 bit 20 to 60 14 12 to 24 57K
    AVIIVA M2 CL 2010 B&W linear array - 2048 8-10-12 bit 20 to 60 10 12 to 24 29K
    AVIIVA M2 CL 2014 B&W linear array - 2048 8-10-12 bit 20 to 60 14 12 to 24 29K
    AVIIVA M2 CL 4010 B&W linear array - 4096 8-10-12 bit 20 to 60 10 12 to 24 15K
    AVIIVA M2 LV 0514 B&W linear array - 512 8-10-12 bit 20 to 60 14 12 to 24 98K
    AVIIVA M2 LV 1010 B&W linear array - 1024 8-10-12 bit 20 to 60 10 12 to 24 57K
    AVIIVA M2 LV 1014 B&W linear array - 1024 8-10-12 bit 20 to 60 14 12 to 24 57K
    AVIIVA M2 LV 2010 B&W linear array - 2048 8-10-12 bit 20 to 60 10 12 to 24 29K
    AVIIVA M2 LV 2014 B&W linear array - 2048 8-10-12 bit 20 to 60 14 12 to 24 29K
    AVIIVA M2 LV 4010 B&W linear array - 4096 8-10-12 bit 20 to 60 10 12 to 24 15K
    AVIIVA M4 CL 2014 B&W linear array - 2048 4x8 or 4x10 bit 30 to 120 14 12 to 24 52K
    AVIIVA M4 CL 6007 B&W linear array - 6144 4x8 or 4x10 bit 40 to 160 7 12 to 24 25K
    AVIIVA M4 CL 8007 B&W linear array - 8192 4x8 or 4x10 bit 40 to 160 7 12 to 24 19K
    AVIIVA SC2 CL 4010 color linear array - 3 x 1365 8-10-12 bit 20 to 60 10 12 to 24 14K
    AVIIVA SC2 LV 4010 color linear array - 3 x 1365 8-10-12 bit 20 to 60 10 12 to 24 14 K
    AVIIVA SM2 CL 0514 B&W linear array - 512 8-10-12 bit 20 to 60 14 12 to 24 98K
    AVIIVA SM2 CL 1010 B&W linear array - 1024 8-10-12 bit 20 to 60 10 12 to 24 53K
    AVIIVA SM2 CL 1014 B&W linear array - 1024 8-10-12 bit 20 to 60 14 12 to 24 53K
    AVIIVA SM2 CL 2010 B&W linear array - 2048 8-10-12 bit 20 to 60 10 12 to 24 28K
    AVIIVA SM2 CL 2014 B&W linear array - 2048 8-10-12 bit 20 to 60 14 12 to 24 28K
    AVIIVA SM2 CL 4010 B&W linear array - 4096 8-10-12 bit 20 to 60 10 12 to 24 14K
    AVIIVA SM2 LV 0514 B&W linear array - 512 8-10-12 bit 20 to 60 14 12 to 24 98 K
    AVIIVA SM2 LV 1010 B&W linear array - 1024 8-10-12 bit 20 to 60 10 12 to 24 53 K
    AVIIVA SM2 LV 1014 B&W linear array - 1024 8-10-12 bit 20 to 60 14 12 to 24 53 K
    AVIIVA SM2 LV 2010 B&W linear array - 2048 8-10-12 bit 20 to 60 10 12 to 24 28 K
    AVIIVA SM2 LV 2014 B&W linear array - 2048 8-10-12 bit 20 to 60 14 12 to 24 28 K
    AVIIVA SM2 LV 4010 B&W linear array - 4048 8-10-12 bit 20 to 60 10 12 to 24 14 K
    AViiVA UM2 GIgE B&W linear CCD - 4096 8, 10, 12 bit 62 10-14 12 to 24 -
    AViiVA UM8 CL 1205 B&W linear CCD - 12288 8, 10, 12 bit 320 (8x40) 5 12 to 24 -
    Camelia C1 CL 8M Color area array 2.7 3500 x 2300 12 bit 25 10 24 -
    Camelia C1 LV 8M Color area array 2.7 3500 x 2300 12 bit 25 10 24 -
    Camelia M1 CL 8M B&W area array 2.7 3500 x 2300 12 bit 25 10 24 -
    Camelia M1 LV 8M B&W area array 2.7 3500 x 2300 12 bit 25 10 24 -
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
