龙人旗下深圳市龙芯世纪科技有限公司
  • ATMEL 爱特梅尔 抗辐射处理器
  • 发布时间:2009/2/25 11:01:04   修改时间:2009/2/25 11:01:04 浏览次数:2990
  • 首页ATMEL 爱特梅尔抗辐射处理器
    ATMEL 爱特梅尔 抗辐射处理器     当前页面搜索:Ctrl+F
    抗辐射处理器
     Rad Hard ASICs   Rad Hard Memories
     Rad Hard FPGA Conversion   Rad Hard Processors
     Rad Hard FPGAs   Rad Hard Standard ASICs
    Rad Hard ASICs
    设备 描述
    ATC18RHA Rad Hard 0.18 Micron CMOS Cell-based ASIC
    MG2RT Rad Tolerant 0.5 Micron Sea of Gates
    MG2RTP Rad Hard 0.5 Micron Sea of Gates
    MH1RT Rad Hard 1.6M Used Gates 0.35 Micron CMOS Sea of Gates / Embedded Gates
    设备 描述
    Space FPGA Conversion Atmel offer to convert existing space FPGA-based designs into cost-effective radiation hardened ASICs. An optimized methodology allows to shorten conversion cycle time and minimize ASIC industrialization costs.
    Using rad-hard CMOS technologies, the ASICs feature up to 70K usable ASIC gates and a total dose capability of up to 300 Krads. They are available in MQFPF84, 132, 172, 208 and 256.
    Rad Hard FPGAs
    设备 描述
    AT17LV010-10DP FPGA Configuration EEPROM packaged in the 28-pin 400 mils wide FP package.
    This device works with the AT40KEL040.
    AT40KEL040 Rad Hard Reprogrammable FPGA with FreeRAM, up to 50K usable gates and 18Kbit SRAM
    The AT40KEL040 also offers the ability to implement Cache Logic?design, where part of the FPGA can be re-programmed without loss of register data, while the remainder of the FPGA continues to operate without disruption.
    Rad Hard Memories
    设备 描述
    AT28C010-12DK Space 1M bit Parallel EEPROM with 128-Byte Page & Software Data Protection
    AT60142 Rad Hard Memory 512K x 8 Very Low Power CMOS SRAM. This product is available in 15 ns (AT60142F) or 20 ns (AT60142E) for 3.3V biased and in 17 ns for 5V tolerant (AT60142FT). It is offered in the smallest available 4Mb SRAM hermetic package, a 500 mils wide 36 pins DIL flat pack.
    AT61162E Rad Hard Memory 2Mbit x 8 SRAM Cube. Made of 16 stacked 128K x 8 SRAMs.
    AT68166F/FT The AT68166F/FT are Rad Hard hermetic Multi Chip Modules (MCM), integrating very low-power CMOS asynchronous static RAM which can be organized as 1 bank of 512K x 32, 2 banks of 512Kx16, or 4 banks of 512Kx8.
    Build with 4 dies of the AT60142F/FT SRAM, the resulting 68 pins quad flat pack package offers a footprint compatible with products from other sources.
    For more information, please contact .
    M65608E Rad Tolerant Memory 5V 128Kx8 Very Low Power CMOS SRAM
    M65609E Rad Hard Memory 3.3 Volt 128Kx8 Very Low Power CMOS SRAM
    M67025E Rad Tolerant Memory High Speed 8Kx16 Dual Port RAM
    M67204 Rad Tolerant Memory High Speed 4Kx9 CMOS Parallel FIFO
    M67206 Rad Tolerant Memory High Speed 16Kx9 Parallel FIFO
    M672061 Rad Tolerant Memory High Speed 16Kx9 Parallel FIFO with Programmable Flag
    Rad Hard Processors
    设备 描述
    80C32E Rad Tolerant ROMless version of the 80C52 single chip 8-bit microcontroller.
    AT697E Rad Hard 32-bit SPARC V8 embedded processor
    The implementation is based on the European Space Agency (ESA) LEON2 fault tolerant model.
    The AT697E samples are available. The AT697E will be delivered tested to military quality flow (QML-Q) for some ESA projects by mid 2006. At the beginning of 2007, the AT697F processor flight models will be delivered tested to either QML Q & V or ESCC quality flows. This second version of the AT697 processor will have improved radiation capabilities, up to 300 krads, and will correct all the bugs described in the AT697E erratasheet. The AT697F version will be pinout compatible with the AT697E.
    TSC21020F Rad Hard Tolerant 32-bit floating point DSP
    TSC695F Rad Hard SPARC single chip processor. 5V supply.
    TSC695FL Rad Hard SPARC single chip processor. 3.3V supply.
    设备 描述
    29C516E 16-Bit Flow Through EDAC Error Detection And Correction unit
    Std ASICs Legal Notice
    AT7908E CAN Controller for Space Application.
    T7906E Single Point to Point IEEE 1355 High Speed Controller.
    TSS901E Tripple Point to Point IEEE1355 High Speed Controller.
    首页ATMEL 爱特梅尔抗辐射处理器
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
