龙人旗下深圳市龙芯世纪科技有限公司
  • MCF5232CAB80:集成式V2 ColdFire微处理器
  • 发布时间:2009/2/27 14:15:46   修改时间:2009/2/27 14:15:46 浏览次数:3022
  • 首页>Freescale飞思卡尔>32 位微控制器与处理器 MCF5232CAB80:集成式V2 ColdFire微处理器 MCF5232CAB80 ColdFire集成式微处理器整合了常用的V2 ColdFire内核和16 通道增强型时间处理单元(eTPU)、CAN及其它通信外设,来解决提高应用复杂度需要更大的系统吞吐量的问题。这款经济型控制器在频率为150MHz时的性能高达144 (Dhrystone 2.1) MIPS,可以实现网络化和单个复杂实时控制应用,如工业控制、生产设备和机器人。 MCF523x 器件系列还为MC68332的现有用户提供自然的、向较高性能和/或网络支持转移的方法,同时还能以与更成熟的产品系列一样的价格,通过增加功能实现新一代产品。 The MCF5232 ColdFire Integrated Microprocessor combines the popular Version 2 ColdFire core with a 16-channel enhanced Time Processing Unit (eTPU), CAN and other communications peripherals to address increasing application complexity requiring more system throughput. Providing up to 144 (Dhrystone 2.1) MIPS at 150MHz, this cost-effective controller enables networked and stand-alone complex real-time control applications such as industrial control, manufacturing equipment and robotics. The family of MCF523x devices also provides current users of the MC68332 with a natural migration path to higher performance and/or networking support while enabling a new generation of products with increased functionality at a similar price point to more mature generations. MCF5232 特点 V2 ColdFire? 内核具有增强型乘累加模块,且在频率为150 MHz的情况下,其性能高达144 (Dhrystone 2.1) MIPS 具有8个芯片选择(芯片选择支持分页模式的Flash存储器)的32 位非多路复用总线 64 KB内部SRAM 8 KB可配置I/D-缓存 具有6 KB SRAM的16 通道eTPU 双组SDRAM控制器 CAN 2.0 B 3个UART 排队串行外设接口(QSPI) I2C总线接口 具有DMA的4 通道32 位定时器 4 通道DMA控制器 系统集成(PLL、SW看门狗) 温度范围:-40°C ~ +85°C 2种封装选择:196-MAPBGA或160QFP V2 ColdFire? core with enhanced multiply accumulate module and performance up to 144 (Dhrystone 2.1) MIPS @ 150 MHz 32-bit non-multiplexed bus with up to eight chip selects (chip select support for paged mode Flash memories) 64 KB internal SRAM 8 KB of configurable I/D-Cache 16-channel eTPU with 6 KB of SRAM Two-bank SDRAM controller CAN 2.0 B Three UARTs Queued serial peripheral interface (QSPI) I2C bus interface Four-channel 32-bit timers with DMA Four-channel DMA controller System Integration (PLL, SW watchdog) Temperature range: -40°C to +85°C Choice of two packages: 196-MAPBGA or 160QFP MCF5232CAB80 相关订购型号 MCF5232CAB80:LQFP 160 绿色无铅环保封装,-40oC到80oC工业级 MCF5232CAB80 技术支持 MCF5232CAB80 英文数据手册 DataSheet . PDF MCF5232CAB80 功能模块图 .bmp ColdFire 系列处理器产品选型指南 . PDF ColdFire 系列嵌入式处理器产品概说 . PDF
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
