龙人旗下深圳市龙芯世纪科技有限公司
  • 通用运算放大器General Purpose
  • 发布时间:2009/2/28 9:37:27   修改时间:2009/2/28 9:37:27 浏览次数:3299
  • 首页NS国半放大器与比较器运算放大器
    运算放大器
    Excel 文档格式下载 通用运算放大器General Purpose (53)
    Base Part Number 数据手册DataSheet下载 Gain Bandwidth Channels Input OutputType Slew Rate Supply Min Supply Max Offset Voltage max, 25C Supply Current Per Channel PowerWise Rating 2 Max Input Bias Current Output Current Voltage Noise Shut down Special Features Function Temperature Min Temperature Max AEC Q-100 Automotive Grade Automotive Selection Guide PowerWise 数据手册DataSheet下载
    LM359 LM359 400 2 Not Rail to Rail 60 5 22   18.5 46.3 30000 6 6 No Adj BW, Adj Is Op Amp 0 70     Yes LM359
    LME49710 LME49710 55 1 Not Rail to Rail 20 5 34 0.7 4.8 87.3 72 26 2.5 No Ultra Low Distortion, Very Low Noise Op Amp -40 85   Yes Yes LME49710
    LME49720 LME49720 55 2 Not Rail to Rail 20 5 34 0.7 5 90.9 72 42 2.5 No Ultra Low Distortion, Very Low Noise Op Amp -40 85   Yes Yes LME49720
    LME49740 LME49740 55 4 Not Rail to Rail 20 5 34 0.7 4.62 84 72 30 2.5 No Ultra Low Distortion, Very Low Noise Op Amp -40 85   Yes Yes LME49740
    LMV861 LMV861 30 1 Vcm to V-, R-R Out 18 2.7 5.5 1 2.25 75 0.5 67 8 No EMI Hardened Op Amp -40 125     Yes LMV861
    LMV862 LMV862 30 2 Vcm to V-, R-R Out 18 2.7 5.5 1 2.25 75 0.5 67 8 No EMI Hardened Op Amp -40 128 Undefined   Yes LMV862
    LM837 LM837 25 4 Not Rail to Rail 10 10 36 5 2.5 100 1050 40 4.5 No   Op Amp -40 85     Yes LM837
    LM118 LM118 15 1 Not Rail to Rail 70 10 40 4 4.5 300 500 20 10 No Vos Adj, ExtCompCap Op Amp -55 125       LM118
    LM318 LM318 15 1 Not Rail to Rail 70 10 40 10 4.5 300 750 20 15 No Vos Adj, ExtCompCap Op Amp 0 70       LM318
    LM833 LM833 15 2 Not Rail to Rail 7 10 36 5 2.5 166.7 1050 40 4.5 No Undefined Op Amp -40 85   Yes   LM833
    LMV851 LMV851 8 1 Vcm to V-, R-R Out 4.5 2.7 5.5 1 0.41 51.3 0.5 62 11 No EMI Hardened Op Amp -40 125   Yes Yes LMV851
    LMV852 LMV852 8 2 Vcm to V-, R-R Out 4.5 2.7 5.5 1 0.41 51.3 0.5 62 11 No EMI Hardened Op Amp -40 125   Yes Yes LMV852
    LMV854 LMV854 8 4 Vcm to V-, R-R Out 4.5 2.7 5.5 1 0.41 51.3 0.5 62 11 No EMI Hardened Op Amp -40 125   Yes Yes LMV854
    LF156 LF156 5 1 Vcm to V+, Not R-R Out 12 10 44 5 5 1000 50 25 12 No Undefined Op Amp -55 125       LF156
    LF256 LF256 5 1 Vcm to V+, Not R-R Out 12 10 44 5 5 1000 5 25 12 No   Op Amp -40 85       LF256
    LF356 LF356 5 1 Vcm to V+, Not R-R Out 12 10 36 10 5 1000 8 25 12 No   Op Amp 0 70       LF356
    LF147 LF147 4 4 Vcm to V+, Not R-R Out 13 5 44 5 1.8 450 10 30 20 No Undefined Op Amp -55 125       LF147
    LF347 LF347 4 4 Vcm to V+, Not R-R Out 13 8 36 10| 5 1.8 450 8 31 20 No Undefined Op Amp 0 70       LF347
    LF353 LF353 4 2 Vcm to V+, Not R-R Out 13 10 36 10 1.8 450 8 20 16 No Undefined Op Amp 0 70       LF353
    LF411 LF411 4 1 Not Rail to Rail 15 10 36| 44| 36 0.4|  5| 5| 1 1.8 450 3| 4|  3 25 25 No Vos Adj Pin| Vos Adj Op Amp -55| 0 125| 70       LF411
    LF412 LF412 4 2 Not Rail to Rail 15 10 44| 36 3| 1 1.8 450 50| 4 25 25 No Undefined Op Amp -55| 0 125| 70       LF412
    TL082 TL082 4 2 Vcm to V+, Not R-R Out 13 10| 12 36 15 1.75 437.5 8 17 25 No JFET Op Amp 0 70       TL082
    LMV831 LMV831 3.3 1 Vcm to V-, R-R Out 2 2.7 5.5 1 0.25 72 0.01 64 12 No EMI Hardened Op Amp -40 125 0 No Yes LMV831
    LMV832 LMV832 3.3 2 Vcm to V-, R-R Out 2 2.7 5.5 1 0.24 72 0.01 64 12 No EMI Hardened Op Amp -40 125 0 Yes Yes LMV832
    LMV834 LMV834 3.3 4 Vcm to V-, R-R Out 2 2.7 5.5 1 0.24 73 0.5 30 12 No EMI Hardened Op Amp -40 125 0   Yes LMV834
    LM13700 LM13700 2 2 Not Rail to Rail 50 10 36 4 1.3 650 7000 20 -| No Undefined Op Amp 0 70       LM13700
    LM747 LM747 1.5 2 Not Rail to Rail 0.5 10 44 5 1.7 1133.3 1500 25 23 No Vos Adj Op Amp -55 125       LM747
    LM346 LM346 1.2 4 Not Rail to Rail 0.4 3 36 6 0.035 29.2 250 20 28 No Is adj 35uA to 350uA Op Amp 0 70     Yes LM346
    LM101A LM101A 1 1 Vcm to V+, Not R-R Out 0.5 10 44 2 1.8 1800 100 25 15 No Vos Adj, ExtCompCap Op Amp -55 125       LM101A
    LM108A LM108A 1 1 Not Rail to Rail 0.3 4 40 0.5 0.3 300 3 8 30 No ExtCompCap Op Amp -55 125       LM108A
    LM124 LM124 1 4 Vcm to V-, Not R-R Out 0.5 3 32 5| 2 0.18 180 100| 300 20 40 No Undefined Op Amp -55 125       LM124
    LM1458 LM1458 1 2 Not Rail to Rail 0.5 6 36 6 1.5 1500 800 45 30 No Undefined Op Amp 0 70       LM1458
    LM1558 LM1558 1 2 Not Rail to Rail 0.5 6 44 5 1.5 1500 1500 45 30 No Undefined Op Amp -55 125       LM1558
    LM158 LM158 1 2 Vcm to V-, Not R-R Out 0.5 3 32 5| 2 0.25 250 100| 300 20 40 No | Undefined Op Amp -55 125       LM158
    LM224 LM224 1 4 Vcm to V-, Not R-R Out 0.5 3 32 5 0.18 180 300 20 40 No Undefined Op Amp -25 85       LM224
    LM2902 LM2902 1 4 Vcm to V-, Not R-R Out 0.5 3 26 7 0.18 180 500 20 40 No Undefined Op Amp -40 85       LM2902
    LM2904 LM2904 1 2 Vcm to V-, Not R-R Out 0.1 3 26 7 0.25 250 500 20 40 No Undefined Op Amp -40 85       LM2904
    LM301A LM301A 1 1 Vcm to V+, Not R-R Out 0.5 10 36 7.5 1.8 1800 300 25 15 No Vos Adj, ExtCompCap Op Amp 0 70       LM301A
    LM321 LM321 1 1 Vcm to V-, Not R-R Out 0.5 3 32 7 0.45 450 500 20 40 No   Op Amp -40 85       LM321
    LM324 LM324 1 4 Vcm to V-, Not R-R Out 0.5 3 32 3| 7 0.18 180 200| 500 20 40 No Undefined Op Amp 0 70       LM324
    LM348 LM348 1 4 Not Rail to Rail 0.5 10 36 6 0.6 600 400 25 60 No Undefined Op Amp 0 70       LM348
    LM358 LM358 1 2 Vcm to V-, Not R-R Out 0.1 3 32 3| 7 0.25 250 200| 500 20 40 No Undefined Op Amp 0 70       LM358
    LM392 LM392 1 2 Vcm to V-, Not R-R Out 0.1 3 32 5 0.5 500 400 20 38 No w/ Comparator, w/ OpAmp Op Amp and Comparator 0 70       LM392
    LM432 LM432 1 2 Vcm to V-, Not R-R Out 0.5 2.5 16 4 0.075 75 50 11 50 No With 2.5V Reference Op Amp -40 85     Yes LM432
    LM741 LM741 1 1 Not Rail to Rail 0.5 10 44| 36 5| 6 1.7 1700 800| 1500 25 30 No Vos Adj Op Amp -55| 0 125| 70       LM741
    LM148 LM148 0.9 4 Not Rail to Rail 0.5 10 44| 40 5 0.6 666.7 325 25 60 No Undefined Op Amp -55 125       LM148
    LM611 LM611 0.8 1 Vcm to V-, Not R-R Out 0.7 4 36 5 0.21 262.6 40 17 70 No w/Reference Op Amp with Reference -40| 0 85| 70       LM611
    LM613 LM613 0.8 2 Vcm to V-, Not R-R Out 0.7 4 36 5 0.112 140 40 25 74 No w/ OpAmp, w/ reference, w/ comparator Op Amp and Comparator -40 85       LM613
    LM614 LM614 0.8 4 Vcm to V-, Not R-R Out 0.7 4 36 5 0.112 140 40 50 74 No w/Reference Op Amp with Reference 0 70       LM614
    LM10 LM10 0.4| 0.09| 0.05 1 Vcm to V-, R-R Out 0.2 1.1 7| 40| 45 2| 4 0.28| 0.27| 0.3 3111.1| 5400| 675| 3333.3 30| 40 20 50 No With Adj Reference| w/Reference Op Amp with Reference -55| 0| -40 85| 125| 70       LM10
    LM4250 LM4250 0.25 1 Not Rail to Rail 0.2 2 36 6 0.01 40 20 12 40 No Is Adj dwn to 100nA; Vos Adj Pin Op Amp 0 70     Yes LM4250
    LP2902 LP2902 0.1 4 Vcm to V-, Not R-R Out 0.05 3 26 10 0.02125 212.5 40 4 80 No Undefined Op Amp -40 85       LP2902
    LP324 LP324 0.1 4 Vcm to V-, Not R-R Out 0.05 3 32 9 0.02125 212.5 20 4 80 No Undefined Op Amp 0 70       LP324
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
