龙人旗下深圳市龙芯世纪科技有限公司
  • 高速运算放大器High Speed > 50MHz
  • 发布时间:2009/2/28 9:40:22   修改时间:2009/2/28 9:40:22 浏览次数:4749
  • 首页NS国半放大器与比较器运算放大器
    运算放大器
    Excel 文档格式下载 高速运算放大器High Speed > 50MHz (49)
    Base Part Number 数据手册DataSheet下载 -3dB BW AvCL for -3dB BW Slew Rate Input OutputType Supply Min Supply Max Supply Current Per Channel PowerWise Rating 2 Channels Offset Voltage max, 25C Max Input Bias Current Output Current Voltage Noise Shut down Feedback Type Av+1 BW Av+2 BW Av+5 BW Av+10 BW Av+20 BW HD 2nd HD 3rd Diff Gain Diff Phase Settling Time Tsettling Conditions Special Features Function Gain Bandwidth Temperature Min Temperature Max AEC Q-100 Automotive Grade Automotive Selection Guide PowerWise 数据手册DataSheet下载
    LMH6703 LMH6703 1800 1 4200 Not Rail to Rail 8 12 11 6.11| 6.1 1 7 23000 90 2.3 Yes Current 1800 1200 700 500   -87 -100 0.01 0.02 10 to 0.1% Undefined Op Amp 1200 -40 85     Yes LMH6703
    LMH6702 LMH6702 1700 2 3100 Not Rail to Rail 10 12 12.5 3.7 1 4.5 34000 80 1.83 No Current 1700 1700 280 150   -100 -96 0.024 0.004 13.4 to 0.1% Undefined Op Amp 1700 -40 85   Yes Yes LMH6702
    LMH6552 LMH6552 1500 1 3800 Diff In and Out 4.5 12 19 12.7 1 16.5 8000 80 1.1 Yes Current 1000 930 800 500   -82 -79     10 to 0.1% Differential in, Differential out Op Amp 1000 -40 85     Yes| null LMH6552
    LMH6733 LMH6733 1000 1 3750 Not Rail to Rail 3 12 6.5 6.5 3 2.2 26000 80 2.1 Yes Current 1000 830 400     -72 -63 0.03 0.03 10 to 0.1% Undefined Op Amp 1000 -40 85     Yes LMH6733
    LMH6609 LMH6609 900 1 1400 Not Rail to Rail 6 12 7 7.8 1 2.5 8000 90 3.1 No Voltage 900 450 180 90 45 -63 -67 0.01 0.026 15 to 0.05%   Op Amp 900 -40 85       LMH6609
    LMH6738 LMH6738 750 1 3300 Not Rail to Rail 10 12 10.5 14 3 2.5 5000 90 2.2 Yes Current 750 480 320 300   -80 -90 0.02 0.01 10 to 1% Undefined Op Amp 400 -40 85     Yes LMH6738
    LMH6732 LMH6732 540 2 2700 Not Rail to Rail 9 12 9 8.3 1 8 12000 115 2.5 Yes Current 540 540 400 200 80 -60 -64 0.025 0.01 18 to 0.04% Is adj 1mA to 9mA, AvCl>2 Op Amp 540 -40 85     Yes LMH6732
    LMH6715 LMH6715 480   1300 Not Rail to Rail 10 12 5.8 12.1 2 6 20000 70 3.4 No Current 430 400 250 100 Undefined -60 -75 0.02 0.02 12 to 0.05% | Undefined Op Amp 480 -55| -40 85| 125     Yes| null LMH6715
    LMH6550 LMH6550 400 1 3000 Diff In and Out 5 12 20 50 1 5 50000 75 6 Yes Voltage 400 200 80 40 20 -92 -103     8 to 0.1% Differential in, Differential out Op Amp 400 -40 85     Yes LMH6550
    LMH6714 LMH6714 400 2 1800 Not Rail to Rail 10 12 5.6 7 1 6 15000 70 3.4 No Current 420 400 150     -58 -70 0.02 0.01 12 to 0.05% | Undefined Op Amp 400 -40 85     Yes| null LMH6714
    LMH6720 LMH6720 400 2 1800 Not Rail to Rail 10 12 5.6 7 1 6 15000 70 3.4 Yes Current 420 400 150     -58 -70 0.02 0.01 12 to 0.05% Undefined Op Amp 400 -40 85     Yes LMH6720
    LMH6722 LMH6722 400 2 1800 Not Rail to Rail 10 12 5.6 7 4 6 15000 70 3.4 No Current 420 400 150     -58 -70 0.02 0.01 12 to 0.05% Undefined Op Amp 400 -40 85     Yes LMH6722
    LMH6551 LMH6551 370 1 2400 Diff In and Out 3 12 12.5 33.8 1 5 10000 65 6 No Voltage 370 185 74 37 18.5 -94 -96     18 to 0.1% Differential in, Differential out Op Amp 370 -40 85     Yes LMH6551
    LMH6723 LMH6723 370 1 600 Not Rail to Rail 5 12 1 2.7 1 3 5000 110 4.3 No Current 370 260 170     -65 -63 0.03 0.11 30 to 0.05% Undefined Op Amp 370 -40 85     Yes LMH6723
    LMH6724 LMH6724 370 1 600 Not Rail to Rail 5 12 1 2.7 2 3 5000 110 4.3 No Current 370 260 170     -65 -63 0.03 0.11 30 to 0.05% Undefined Op Amp 370 -40 85     Yes LMH6724
    LMH6725 LMH6725 370 1 600 Not Rail to Rail 5 12 1 2.7 4 3 5000 110 4.3 No Current 370 260 170     -65 -63 0.03 0.11 30 to 0.05% Undefined Op Amp 370 -40 85     Yes LMH6725
    LMH6611 LMH6611 365 1 460 Vcm to V-, R-R Out 2.7 11 3.3 9 1 0.6 11100 120 10 Yes Voltage 365 182.5 73 36.5 18.25 -82 -80 0.05 0.05 100 to 0.01% Undefined Op Amp 345 -40 125     Yes LMH6611
    LMH6612 LMH6612 365 1 460 Vcm to V-, R-R Out 2.7 11 3.45 9.5 2 0.6 11100 120 10 Yes Voltage 365 182.5 73 36.5 18.25 -82 -80 0.05 0.05 100 to 0.1% R-R Out Op Amp 345 -40 125     Yes| null LMH6612
    LMH6628 LMH6628 300 1 550 Not Rail to Rail 5 12 9 30 2 2 20000 85 2 No Voltage 300 150 60 30 15 -65 -74     12 to 0.1% Undefined Op Amp 300 -55| -40 85| 125   Yes Yes LMH6628
    LMH6657 LMH6657 270 1 700 Vcm to V-, Not R-R Out 3 12 6 22.2 1 5 30000 45 11 No Voltage 270 135 54 27 13.5 -70 -57 0.03 0.1 35 to 0.1% Undefined Op Amp 270 -40 85     Yes LMH6657
    LMH6658 LMH6658 270 1 700 Vcm to V-, Not R-R Out 3 12 6 22.2 2 5 30000 45 11 No Voltage 270 135 54 27 13.5 -70 -57 0.03 0.1 35 to 0.1% Undefined Op Amp 270 -40 85     Yes LMH6658
    LMH6601 LMH6601 250 1 275 Vcm to V-, R-R Out 2.4 5.5 9.6 38.4 1 2.4 0.1 150 10 Yes Voltage 250 125 50 25 12.5 -56 -73 0.25 0.25 250 to 0.02% CMOS Input Op Amp 125 -40 85 3     LMH6601
    LMH6654 LMH6654 250 1 200 Vcm to V-, Not R-R Out 4.5 12 4.5 18 1 3 20000 186 4.5 No Voltage 250 125 50 25 12.5 -80 -85 0.01 0.025 14 to 0.1% Undefined Op Amp 260 -40 85     Yes LMH6654
    LMH6655 LMH6655 250 1 200 Vcm to V-, Not R-R Out 4.5 12 4.5 18 2 3 20000 186 4.5 No Voltage 250 125 50 25 12.5 -80 -85 0.01 0.025 14 to 0.1% Undefined Op Amp 260 -40 85     Yes LMH6655
    LM7121 LM7121 235 1 1300 Not Rail to Rail 4.5 33 4.8 20.4 1 8 12000 52 17 No Voltage 235 117.5 47 23.5 11.75     0.3 0.65 65 to 0.1% Undefined Op Amp 175 -40 85   Yes Yes LM7121
    LMH6639 LMH6639 228 1 172 Vcm to V-, R-R Out 3 12 3.6 15.8 1 5 3250 160 12 Yes Voltage 228 114 45.6 22.8 11.4 -65   0.065 0.05 33 to 0.1% 85nsec turn on Op Amp 190 -40 85     Yes| null LMH6639
    LM7171 LM7171 220 2 4100 Not Rail to Rail 5.5 36 6.5 32.5 1 3| 1 12000 100 14 No Voltage Undefined 220 100 20 10 -75 -55 0.01 0.02 42 to 0.1% AvCl>2 Op Amp 200 -55| -40 85| 125       LM7171
    LM7372 LM7372 220 2 3000 Not Rail to Rail 9 36 6.5 14.8 2 8 12000 150 14 No Voltage   220 88 44 22 -84 -94 0.01 0.02 70 to 0.1% High Output Current, AvCl>2 Op Amp 120 -40 85       LM7372
    LME49713 LME49713 214 2 1900 Not Rail to Rail 10 36   18.7 1 1 5000 140 1.9 No     214 126 82               Current Feedback Audio Amp, AvCl>2 Op Amp 190 -40 85   Yes   LME49713
    LMH6640 LMH6640 190 1 170 Vcm to V-, R-R Out 4.5 16 4 21.1 1 1 3500 110 10 No Voltage 190 95 38 19 9.5 -71 -72 0.12 0.12 35 to 0.1% High Cload Drive Op Amp 62 -40 85       LMH6640
    LMH6624 LMH6624 180 10 400 Not Rail to Rail 5 12 12 6.7 1 0.5 25000 100 0.92 No Voltage       180 90 -65 -80     14 to 0.1% AvCl>10 Op Amp 1500 -40 125 0 Yes Yes LMH6624
    LMH6682 LMH6682 180 2 940 Vcm to V-, Not R-R Out 3 12 6.5 18.1 2 5 30000 80 12 No Voltage   180 72 36 18 -66 -54 0.01 0.08 42 to 0.1% AvCl>2 Op Amp 190 -40 85       LMH6682
    LMH6683 LMH6683 180 2 940 Vcm to V-, Not R-R Out 3 12 6.5 18.1 3 5 30000 80 12 No Voltage   180 72 36 18 -66 -54 0.01 0.08 42 to 0.1% AvCl>2 Op Amp 190 -40 85       LMH6683
    LM6171 LM6171 160 1 3600 Not Rail to Rail 5.5 34 2.5 15.6 1 3| 6 4000 135 12 No Voltage 160 80 32 16 8 -50 -50 0.03 0.5 48 to 0.1% Undefined Op Amp 100 -40 85     Yes LM6171
    LM6172 LM6172 160 1 3000 Not Rail to Rail 5.5 36 2.3 14.4 2 1.5| 3 4000 85 12 No Voltage 160 80 32 16 8 -50 -50 0.28 0.6 65 to 0.1% Undefined Op Amp 100 -40 85     Yes| null LM6172
    LMH6622 LMH6622 160 2 80 Not Rail to Rail 5 12 4.3 13.4 2 1.2 15000 90 1.6 No Voltage   160 64 32 16 -90 -100 0.03 0.03 40 to 0.1% AvCl>2 Op Amp 160 -40 85   Yes Yes LMH6622
    LMH6626 LMH6626 160 10 360 Not Rail to Rail 5 12 12 7.5 2 0.5 25000 100 1 No Voltage       160 80 -65 -80     14 to 0.1% AvCl>10 Op Amp 1300 -40 125   Yes Yes LMH6626
    LMH6618 LMH6618 140 1 57 R-R In and Out 2.7 11 1.35 9.6 1 0.6 2400 35 10 Yes Voltage 140 70 28 14 7 -75 -75 0.1 0.1 90 to 0.1% Precision Hi Speed Op Amp 140 -40 125     Yes LMH6618
    LMH6619 LMH6619 140 1 57 R-R In and Out 2.7 11 1.45 10.4 2 0.6 2400 35 10 No Voltage 140 70 28 14 7 -75 -75 0.1 0.1 90 to 0.1% Precision Hi Speed Op Amp 140 -40 125     Yes LMH6619
    LMH6642 LMH6642 130 1 135 Vcm to V-, R-R Out 2.7 12.8 2.7 20.8 1 5 3250 115 17 No Voltage 130 65 26 13 6.5 -80 -65 0.01 0.01 68 to 0.1% Undefined Op Amp 130 -40 85     Yes LMH6642
    LMH6643 LMH6643 130 1 135 Vcm to V-, R-R Out 2.7 12.8 2.7 20.8 2 5 3250 115 17 No Voltage 130 65 26 13 6.5 -80 -65 0.01 0.01 68 to 0.1% Undefined Op Amp 130 -40 85     Yes LMH6643
    LMH6644 LMH6644 130 1 135 Vcm to V-, R-R Out 2.7 12.8 2.7 20.8 4 5 3250 115 17 No Voltage 130 65 26 13 6.5 -80 -65 0.01 0.01 68 to 0.1% Undefined Op Amp 130 -40 85     Yes LMH6644
    LM6181 LM6181 120 1 1400 Not Rail to Rail 7 32 7.5 62.5 1 5 5000 130 4 No Current 120 100 90 80   -50 -55 0.05 0.04 50 to 0.1% Undefined Op Amp 100 -40 85   Yes   LM6181
    LMH6672 LMH6672 90 2 170 Vcm to V-, Not R-R Out 5 12 6.2 34.4 2 5.5 14000 200 4.5 No Voltage   90 36 18 9 -92 -95         High Output Current, AvCl>2 Op Amp 130 -40 85       LMH6672
    LM6152 LM6152 75 10 30 R-R In and Out 2.7 24 1.4 1.8 2 5| 2 1500 6.2 9 No Voltage   37.5 15 7.5 3.75             AvCl>2 Op Amp 75 0 70     Yes LM6152
    LM6154 LM6154 75 10 30 R-R In and Out 2.7 24 1.4 1.8 4 5 1500 6.2 9 No Voltage   37.5 15 7.5 3.75             AvCl>2 Op Amp 75 0 70     Yes LM6154
    LMH6645 LMH6645 55 1 22 R-R In and Out 2.5 12 0.725 13.2 1 3 4000 20 17 No Voltage 55 27.5 11 5.5 2.75 -62 -72     125 to 0.1% Undefined Op Amp 55 -40 85     Yes LMH6645
    LMH6646 LMH6646 55 1 22 R-R In and Out 2.5 12 0.725 13.2 2 3 4000 20 17 No Voltage 55 27.5 11 5.5 2.75 -62 -72     125 to 0.1% Undefined Op Amp 55 -40 85     Yes LMH6646
    LMH6647 LMH6647 55 1 22 R-R In and Out 2.5 12 0.725 13.2 1 3 4000 20 17 Yes Voltage 55 27.5 11 5.5 2.75 -62 -72     125 to 0.1% Shutdown to 50uA max Op Amp 55 -40 85     Yes| null LMH6647
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
