龙人旗下深圳市龙芯世纪科技有限公司
  • 轨到轨运算放大器Rail to Rail Input
  • 发布时间:2009/2/28 9:45:53   修改时间:2009/2/28 9:45:53 浏览次数:1815
  • 首页NS国半放大器与比较器运算放大器
    运算放大器
    Excel 文档格式下载 轨到轨运算放大器Rail to Rail Input (57)
    Base Part Number 数据手册DataSheet下载 Channels VCM Min from Neg Supply VCM Max from Pos Supply Offset Voltage max, 25C Supply Min Supply Max Gain Bandwidth Supply Current Per Channel PowerWise Rating 2 Input OutputType Vout Min vs Negative Supply Vout Max vs Positive Supply Max Input Bias Current Slew Rate Voltage Noise Output Current Shut down Special Features Temperature Min Temperature Max Function AEC Q-100 Automotive Grade Automotive Selection Guide PowerWise 数据手册DataSheet下载
    LM7301 LM7301 1 0 0 6 2.2 30 4 0.6 150 R-R In and Out 0.07 -0.07 250 1.25 36 9.5 No Undefined -40 85 Op Amp   Yes   LM7301
    LM7321 LM7321 1 -0.3 0.3 6 2.5 32 16 1.7 106 R-R In and Out 0.2 -0.3 2500 18 15 60 No High Cload Drv -40 125 Op Amp Undefined Yes Yes LM7321
    LM7341 LM7341 1 0 0 4 2.7 32 4.6 1.2 187 R-R In and Out 0.3 -0.3 300 1.9 31 10 No   -40 125 Op Amp Undefined Yes No LM7341
    LM8261 LM8261 1 -0.1 0.3 5 2.5 30 21 0.97 46.2 R-R In and Out 0.086 -0.13 2700 12 15 53 No High Cload Drive -40 85 Op Amp   Yes   LM8261
    LMC7101 LMC7101 1 -0.2 0.2 3| 7 2.7 15.5 1.1 0.5 454.5 R-R In and Out 0.1 -0.1 0.064 1.1 37 24 No Undefined -40 85 Op Amp       LMC7101
    LMC7111 LMC7111 1 -0.2 0.2 7 2.7 11 0.05 0.025 500 R-R In and Out 0.01 -0.01 0.02 0.027 110 7 No Undefined -40 85 Op Amp   Yes   LMC7111
    LMC8101 LMC8101 1 -0.2 0.2 5 2.7 10 1 0.7 700 R-R In and Out 0.025 -0.025 0.064 1 36 49 Yes Undefined -40 85 Op Amp   Yes   LMC8101
    LMH6618 LMH6618 1 | -0.2 | 0.2 0.6 2.7 11 140 1.35 9.6 R-R In and Out | 0.43 | -0.44 2400 57 10 35 Yes Precision Hi Speed -40 125 Op Amp     Yes LMH6618
    LMH6645 LMH6645 1 -0.5 0.5 3 2.5 12 55 0.725 13.2 R-R In and Out 0.02 -0.03 4000 22 17 20 No Undefined -40 85 Op Amp     Yes LMH6645
    LMH6647 LMH6647 1 -0.5 0.5 3 2.5 12 55 0.725 13.2 R-R In and Out 0.02 -0.03 4000 22 17 20 Yes Shutdown to 50uA max -40 85 Op Amp     Yes| null LMH6647
    LMP7701 LMP7701 1 -0.2 0.2 0.2 2.7 12 2.5 0.715 286 R-R In and Out 0.04 -0.05 0.05 1 9 66 No Low Offset CMOS Input -40 125 Op Amp   Yes   LMP7701
    LMP7731 LMP7731 1 0 0 0.05 2.5 5 22 2.2 100 R-R In and Out 0.023 -0.024 85 2.4 2.9 47 No Ultra Low Noise -40 125 Op Amp   Yes Yes LMP7731
    LMP8270 LMP8270 1 -2| null 22| null 1 4.75| 4.5 5.5 0.08 1 12500 R-R In and Out 0.03| null -0.05| null 20000 0.7 452 5| 1 No Diff Input; Fixed Av+20; Vcm to +27V -40 125 Op Amp   Yes   LMP8270
    LMP8271 LMP8271 1 -2| null 22| null 1 4.5 5.5 0.08 1 12500 R-R In and Out 0.03| null -0.05| null 20000 0.7 452 5 No Diff Input; Fixed Av+20; Adj Bias Point; Vcm to +27; AvCl>20; Differential in -40 125 Op Amp   Yes   LMP8271
    LMP8272 LMP8272 1 -2| null 22| null 1 4.5 5.5 0.08 1 12500 R-R In and Out 0.03| null -0.05| null 20000 0.7 452 5 No Diff Input;Fixed AV+14; Vcm to +27V; AvCl>14; Differential in -40 125 Op Amp   Yes   LMP8272
    LMP8275 LMP8275 1 -2 22 2 4.5 5.5 0.08 1 12500 R-R In and Out 0.03 -0.05 20000 0.7 452 5 No Diff Input,Fixed AV+20, Vcm to +27V, AvCl>20, Differential in -40 125 Op Amp   Yes   LMP8275
    LMP8276 LMP8276 1 -2 22 2 4.5 5.5 0.08 1 12500 R-R In and Out 0.03 -0.05 20000 0.7 452 5 No Adj Bias Point, Diff Input, Fixed Av+20, Vcm to +27V, AvCl>20, Differential in -40 125 Op Amp       LMP8276
    LMP8277 LMP8277 1 -2 22 2 4.5 5.5 0.08 1 12500 R-R In and Out 0.03 -0.05 20000 0.7 452 5 No Diff Input, Fixed Av+14, Vcm to +27V, AvCl>14, Differential in -40 125 Op Amp   Yes   LMP8277
    LMV710 LMV710 1 0 0 3 2.7 5 5 1.17 234 R-R In and Out 0.01 -0.02 0.1 5 20 40 No Undefined -40 85 Op Amp       LMV710
    LMV711 LMV711 1 0 0 3 2.7 5 5 1.17 234 R-R In and Out 0.01 -0.02 0.1 5 20 40 Yes <10uSec Turn-On -40 85 Op Amp       LMV711
    LMV715 LMV715 1 0 0 3 2.7 5 5 1.17 234 R-R In and Out 0.01 -0.02 0.1 5 20 40 Yes <10us Turn-on time; Output High-Z when Shut Down -40 85 Op Amp       LMV715
    LMV841 LMV841 1 -0.2 0.2 0.5 2.7 12 4.5 1.02 226.7 R-R In and Out 0.05 -0.05 0.3 2.5 20 30 No | Undefined -40 125 Op Amp   Yes   LMV841
    LMV931 LMV931 1 -0.2 0.2 4 1.8 5.5 1.5 0.116 77.3 R-R In and Out 0.035 -0.035 50 0.42 50 100 No Undefined -40 125 Op Amp       LMV931
    LMV951 LMV951 1 -0.2 0.2 2.8 0.9 3 2.8 0.37 132.1 R-R In and Out 0.013 -0.017 85 1.4 25 80 Yes 0.9V to 3V, Shutdown -40 125 Op Amp   Yes   LMV951
    LMV981 LMV981 1 -0.2 0.2 4 1.8 5 1.5 0.116 77.3 R-R In and Out 0.037 -0.033 50 0.42 50 65 Yes Shutdown to 1uA -40 125 Op Amp       LMV981
    LPV511 LPV511 1 0 0.1 3 2.7 12 0.027 0.00097 18.7 R-R In and Out 0.11 -0.11 1.9 0.0077 320 0.5 No   -40 85 Op Amp 0   Yes LPV511
    LM6132 LM6132 2 0 0 2| 6 2.7 24 10 0.36 36 R-R In and Out 0.007 -0.008 350| 300 14 27 4.3 No Undefined -40 85 Op Amp   Yes   LM6132
    LM6142 LM6142 2 0 0 2.5| 1 1.8 24 17 0.65 38.2 R-R In and Out 0.005 -0.005 526 25 16 8 No Undefined -55| -40 85| 125 Op Amp   Yes   LM6142
    LM6152 LM6152 2 0 0 5| 2 2.7 24 75 1.4 1.8 R-R In and Out 0.006 -0.008 1500 30 9 6.2 No AvCl>2 0 70 Op Amp     Yes LM6152
    LM7322 LM7322 2 -0.3 0.3 6 2.5 32 16 2 125 R-R In and Out 0.2 -0.3 2500 18 15 60 No High Cload Drv -40 125 Op Amp Undefined Yes Yes LM7322
    LM7332 LM7332 2 -0.3 0.3 4 2.5 32 20 1.2 60 R-R In and Out 0.01 -75 1000 13.2 14.7 100 No High Cload Drv -40 125 Op Amp Undefined Yes   LM7332
    LM8262 LM8262 2 -0.1 0.3 7 2.5 22 21 1.05 50 R-R In and Out 0.05 -0.17 2700 12 15 60 No High Cload Drive -40 85 Op Amp   Yes   LM8262
    LM8272 LM8272 2 -0.1 0.1 5 2.5 24 13 0.9 69.2 R-R In and Out 0.215 -0.07 2700 12 15 100 No High Cload Drive -40 85 Op Amp   Yes   LM8272
    LMC6462 LMC6462 2 -0.1 0.3 3| 0.5 3 15.5 0.05 0.02 400 R-R In and Out 0.005 -0.005 0.005 0.015 80 27 No Undefined -55| -40 85| 125 Op Amp       LMC6462
    LMC6482 LMC6482 2 -0.25 0.25 3| 0.75 3 15.5 1.5 0.5 333.3 R-R In and Out 0.005 -0.005 0.004 1.3 37 30 No Undefined -55| -40 85| 125 Op Amp       LMC6482
    LMC6492 LMC6492 2 -0.25 0.25 3| 6 2.5 15.5 1.5 0.5 333.3 R-R In and Out 0.1 -0.1 0.2 1.3 37 22 No Undefined -40 125 Op Amp       LMC6492
    LMH6646 LMH6646 2 -0.5 0.5 3 2.5 12 55 0.725 13.2 R-R In and Out 0.02 -0.03 4000 22 17 20 No Undefined -40 85 Op Amp     Yes LMH6646
    LMP7702 LMP7702 2 -0.2 0.2 0.22 2.7 12 2.5 0.75 300 R-R In and Out 0.04 -0.06 0.4 1 9 66 No Low Offset CMOS Input -40 125 Op Amp   Yes   LMP7702
    LMP7707 LMP7707 2| 1 -0.2 0.2 0.15 2.7 12 14 0.75 53.6 R-R In and Out 0.03 -0.04 0.05 5.6 9 66 No Decomp Avcl>10 -40 125 Op Amp   Yes Yes LMP7707
    LMP7708 LMP7708 2 -0.2| null 0.2| null 0.15 2.7 12 14 0.75 53.6 R-R In and Out 0.03| null -0.04| null 0.05 5.6 9 66 No Decomp Avcl>10 -40 125 Op Amp 0 Yes Yes LMP7708
    LMP7732 LMP7732 2 0 0 0.05 2.5 5 22 2.2 100 R-R In and Out 0.023 -0.024 85 2.4 2.9 47 No Ultra Low Noise -40 125 Op Amp   Yes Yes LMP7732
    LMV712 LMV712 2 0 0 3 2.7 5.5 5 1.17 234 R-R In and Out 0.01 -0.02 0.13 5 20 35 Yes 1.5uA Shutdown; 2.2us turn-on -40 85 Op Amp       LMV712
    LMV842 LMV842 2 -0.2 0.2 0.5 2.7 12 4.5 1.02 226.7 R-R In and Out 0.05 -0.05 0.3 2.5 20 30 No Undefined -40 125 Op Amp   Yes   LMV842
    LMV932 LMV932 2 -0.2 0.2 5.5 1.8 5.5 1.5 0.116 77.3 R-R In and Out 0.035 -0.035 50 0.42 50 65 No Undefined -40 125 Op Amp       LMV932
    LMV982 LMV982 2 -0.2 0.2 5.5 1.8 5 1.5 0.116 77.3 R-R In and Out 0.037 -0.033 50 0.42 50 65 Yes Independent Shutdown to 1uA -40 125 Op Amp       LMV982
    LM6134 LM6134 4 0 0 2| 6 2.7 24 10 0.36 36 R-R In and Out 0.007 -0.008 350| 300 14 27 4.3 No Undefined -40 85 Op Amp   Yes   LM6134
    LM6144 LM6144 4 0 0 2.5| 1 1.8 24 17 0.65 38.2 R-R In and Out 0.005 -0.005 526 25 16 8 No Undefined -40 85 Op Amp   Yes   LM6144
    LM6154 LM6154 4 0 0 5 2.7 24 75 1.4 1.8 R-R In and Out 0.006 -0.008 1500 30 9 6.2 No AvCl>2 0 70 Op Amp     Yes LM6154
    LM6584 LM6584 4 0 0 4 5 13 15.4 0.78 50.6 R-R In and Out 0.055 -0.1 7000 15 23 75 No   -40 85 Op Amp       LM6584
    LM6588 LM6588 4 0 0 4 5 16 15.4 0.8 51.9 R-R In and Out 0.1 -0.1 7000 15 23 230 No   -40 85 Op Amp       LM6588
    LMC6464 LMC6464 4 -0.1 0.3 3| 0.5 3 15.5 0.05 0.02 400 R-R In and Out 0.005 -0.005 0.2| 0.005 0.015| 0.028 80 27 No Undefined -55| -40 85| 125 Op Amp       LMC6464
    LMC6484 LMC6484 4 -0.25 0.25 3 3 15 1.5 0.5 333.3 R-R In and Out 0.005 -0.005 0.004 1.3 37 30 No Undefined -55| -40 85| 125 Op Amp       LMC6484
    LMC6494 LMC6494 4 -0.25 0.25 3| 6 2.5 15.5 1.5 0.5 333.3 R-R In and Out 0.1 -0.1 0.2 1.3 37 22 No Undefined -40 125 Op Amp       LMC6494
    LMP7704 LMP7704 4 -0.2 0.2 0.22 2.7 12 2.5 0.725 290 R-R In and Out 0.04 -0.06 0.4 1 9 66 No Low Offset CMOS Input -40 125 Op Amp   Yes   LMP7704
    LMP7709 LMP7709 4 -0.2 0.2 0.15 2.7 12 14 0.75 53.6 R-R In and Out 0.03 -0.04 0.05 5.6 9 66 No Decomp Avcl>10 -40 125 Op Amp   Yes Yes LMP7709
    LMV844 LMV844 4 -0.2 0.2 0.5 2.7 12 4.5 1.02 226.7 R-R In and Out 0.05 -0.05 0.3 2.5 20 30 No Undefined -40 125 Op Amp   Yes   LMV844
    LMV934 LMV934 4 -0.2 0.2 5.5 1.8 5.5 1.5 0.116 77.3 R-R In and Out 0.035 -0.035 50 0.42 50 65 No Undefined -40 125 Op Amp       LMV934
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
