龙人旗下深圳市龙芯世纪科技有限公司
  • Boomer音频放大器 Boomer Audio Amplifiers
  • 发布时间:2009/2/28 9:50:38   修改时间:2009/2/28 9:50:38 浏览次数:5960
  • 首页NS国半音频
    Boomer音频放大器 Boomer Audio Amplifiers(87)
    Base Part Number 数据手册DataSheet下载 Power@ 4Ohms, 1% THD Power@ 8Ohms, 1% THD Power@ 4Ohms, 10% THD Power@ 8Ohms, 10% THD THD PSRR SNR CMRR Channels Supply Range THD Conditions PSRR Conditions SNR Conditions CMRR Conditions User Supply Mute/Shutdown Shut down Shutdown Type Mono/Stereo Gain Bandwidth Slew Rate Temperature Min Temperature Max AEC Q-100 Automotive Grade Automotive Selection Guide PowerWise 数据手册DataSheet下载
    LM4804 LM4804   1.8   2.1 0.15         +2.6 - +5 V Vs = 5V, RL = 8 Ohms, Pout= 1.5W       3.3   Yes Low       -40 85       LM4804
    LM4805 LM4805   1.2   1.65 0.25         +2.7 - +5.5 V Vs = 5V, RL = 8 Ohms, Pout= 0.5W       3.3   Yes Low       -40 85       LM4805
    LM4808 LM4808   -   - 0.05 66 105   2 +2.0 - +5.5 V RL=16,Vo=3.5VPP(at 0 dB) - Vo=3.5V   5             -40 85       LM4808
    LM4809 LM4809   0.15   0.18 0.03 70 107   2 +2.0 - +5.5 V Po=50mW @ f="20Hz" to 20kHz f=1kHz, ter. input into 50 Ohms Po=.08W   5     Low       -40 85       LM4809
    LM4810 LM4810   0.15   0.18 0.03 70 107   2 +2.0 - +5.5 V Po=50mW @ R="32" ohms, f="20Hz" to 20kHz f=1kHz, ter. input into 50 Ohms Po=.08W   5     High       -40 85       LM4810
    LM4811 LM4811   0.15   0.18 0.03 60 106   2 +2.0 - +5.5 V Po=50mW @ R="32" ohms, f="20Hz" to 20kHz f=217 Hz Po=.08W   5     High       -40 85       LM4811
    LM48510 LM48510   1.2   1.55 0.07         +2.7 - +5.5 V Pout=500mW,Vdd=3.3v       3.3   Yes Low       -40 85     Yes LM48510
    LM48555 LM48555         0.05 80     1 +2.7 - +5.5 V Vout = 14Vpp, f = 1kHz VRIPPLE = 200mVp-p, f = 217Hz,     Undefined   Yes High       -40 85       LM48555
    LM4880 LM4880   0.25   0.325 0.02 50 -   2 +2.7 - +5.5 V Po=75mW @ R = 32 ohms f=100Hz     5     High       -40 85       LM4880
    LM4881 LM4881   0.26   0.3 0.02 50 100   2 +2.7 - +5.5 V Po=75mW @ R="32" ohms f=120 Hz -   5     High       -40 85       LM4881
    LM4910 LM4910   -   - 0.3 65 97   2 +2.2 - +5.5 V Po=30mW @ Vs="5V", R="32" ohms f=217 Hz or 1kHz, input term. With 10 ohms to ground Po=.035W   3.3     Low       -40 85       LM4910
    LM4911 LM4911   -   - - 65 110   2 +2.0 - +5.5 V - f=1 kHz Po=.048W   5     Low (Mute)       -40 85       LM4911
    LM4915 LM4915   -   - 0.1 65 -   1 +2.2 - +5.5 V Pout=25mW Vripple=200mV     5     Low       -40 85       LM4915
    LM4916 LM4916   0.085   0.1 0.2 66 -   2 - RL=16 ohms, SE, Po="5mW" f=1kHz, R="16" ohms, SE     1.5             -40 85       LM4916
    LM4917 LM4917   -   - 0.02 70 100   2 +1.4 - +3.6 V Po=50mW, f="1kHz", Rl="32" Ohms Vripple=200mW, f="1kHz" RL=32 Ohms, Pout="20mW", f="1kHz"   3     Independent Low       -40 85       LM4917
    LM4920 LM4920         0.03 70 100   2 +1.4 - +3.6 V Po=50mW, f="1kHz", RL="32" Ohms, single channel f=217Hz, Vripple="200mVp-p" RL=32, Po="20mW"   3     Independent Low       -40 85       LM4920
    LM4921 LM4921   -   - 0.03 62 82   2 - f=1kHz, Pout = 12mW f = 217Hz, Vripple="200mVpp" f=1kHz   3     High       -40 85       LM4921
    LM4924 LM4924   -   - 0.1 66 -   2 +1.4 - +3.6 V Po=10mW Vrpi=200Mvpp,Sine,f=100Hz,OCL     3     Low (Mute)       -40 85       LM4924
    LM4980 LM4980         0.02 90     2 +1.5 - +3.3V RL = 32ohm, POUT = 10mW, f = 1kHz VRIPPLE = 200mVP-P sine wave     3     Low       -40 85   Yes Yes LM4980
    LM4982 LM4982   Undefined   Undefined   66 100   2 +1.6 - +4.0V   Input referred, f="217Hz" BW-20Hz to 22kHz   3     Independent Low       -40 85       LM4982
    LM4985 LM4985   Undefined   Undefined 0.08 77     2 +2.2 - +5.5 V Pout = 100mW, f = 1kHz, Rload = 16ohms OCL mode, f = 217Hz, Rload = 16ohms     5     I2C       -40 85   Yes   LM4985
    LM48100Q LM48100Q Undefined 1.3 Undefined 1.6 0.04 74 104 Undefined 1 -2 Po=850mW, f-1kHz, RL="8Ohms" Vripple-200mVp-p Sine, Inputs AC ground,Cin=1uF, Input refferred, Cbias = 2.2uF Pout=400mW Undefined 5 Undefined Yes Low Mono Undefined Undefined -40 105 2 Yes Yes LM48100Q
    LM4867 LM4867 Undefined| 1.9 1.1 Undefined| 2.6 1.5 0.3 67 97   2 +2.0 - +5.5 V Po=1W @ Vs="5V", R="8" Ohms| Po="2W" @ Vs="5V", R="4" Ohms Vdd=5V, RL="8" Ohms RL=8 Ohms, Po="1".1W   5     High       -40 85       LM4867
    LM4923 LM4923 Undefined 1.1 Undefined 1.5 0.02 85 Undefined   Undefined +2.4 - +5.5 V Po = 0.4 Wrms; f = 1kHz 217Hz, Vripple = 200mV sine p-p Undefined   5 Mute   High Mono Undefined Undefined -40 85       LM4923
    LM4941 LM4941 Undefined 1.25 Undefined 1.54 0.04 95 108 70 1 +2.4 - +5.5 V Pout = 700mW, f = 1kHz Vripple = 200mVpp, f = 217Hz Pout = 1W, f="1kHz"   5             -40 85   Yes Yes LM4941
    LM4995 LM4995 Undefined 1.3 Undefined Undefined 0.1 73 Undefined   1 +2.4 - +5.5 V Po = 500mWRMS; f = 1kHz Vripple = 200mV sine p-p, Input Teminated to Ground Undefined   5     Low       -40 85   Yes Yes LM4995
    LM4940 LM4940 3.1 - 6 - - 56 -   2 -6   Vripple 200mV, 12V, 4ohm     10   Yes Low Stereo     -40 85       LM4940
    LM4950 LM4950 3.1 - - 3.1 0.14 70 -   2 -6.4 Po=2.5Wrms,Av=10,f-1kHz,RL=4 ohm SE Vripple=200mVpp,f=1kHz,RL=8 ohm BTL     12   Yes Low Stereo - - -40 85       LM4950
    LM4952 LM4952 3.1 - 3.8 - 0.08 89 -   2 -6.4 2Wrms, 1kHz, 12V, 4ohm Vr 200mV, 1kHz, 12V, 4ohm     12   Yes Low Stereo     -40 85       LM4952
    LM4670 LM4670 2.3 1.35 3 1.65 0.3 68 93   1 +2.4 - +5.5 V 3.6V 0.5Wrms 1KHz 3.6V 1KHz Vripple 200mVpp 5V 1Wrms   5   Yes Low Mono     -40 85       LM4670
    LM4671 LM4671 2.21 1.19 2.5 1.7 0.04 65 93   1 +2.4 - +5.5 V 3.6v 0.1Wrms 1Lhz 3.6v 1khz Vr="200mVpp" 5V 1Wrms   5   Yes Low Mono     -40 85       LM4671
    LM4675 LM4675 2.2 1.3 2.7 1.6 0.02 82 97   1 +1.4 - +3.6 V Vdd=3.6V, Po="0".1W, f="1kHz" 200mVpp 217Hz, 3.6V, Inputs to AC GND, C1=2uF Vdd=5V, Po="1Wrms"       Yes High (Audio); Low (LDO) Mono     -40 85   Yes Yes LM4675
    LM4863 LM4863 2.2 1.1 2.7 1.5 0.3 67 98   2 +2.0 - +5.5 V Po=2W @ Vs="5V", R="4" ohms, 20Hz-20kHz| Po="1W" @ Vs="5V", R="8" ohms, 20Hz-20kHz - Pout=1.1W   5     High       -40 85       LM4863
    LM4866 LM4866 2.2 1.1 2.7 1.5 0.3 67 -   2 +2.7 - +5.5 V f=20Hz-20KHz, AVD="2" Vdd=5V, Vripple="200mWrms", RL="8" Ohms, CB="1".0microF     5     High       -40 85       LM4866
    LM4871 LM4871 2.2 1.2 2.5 1.5 0.13| 0.25 60 98   1 +2.0 - +5.5 V Po=1.6W @ Vs="5V", R="4" ohms| Po="1W" @ Vs="5V", R="8" ohms - -   5     High       -40 85       LM4871
    LM4673 LM4673 2.15 1.24 2.65 1.7 0.02 78 97   1 +2.4 - +5.5 V VDD=3.6V, Pout="100mA", f="1kHz" VDD=3.6V, 5V, f(ripple)=1kHz, V(ripple)=200mVpp VDD=5V, Pout="1Wrms"   5   Yes Low Mono     -40 85   Yes Yes LM4673
    LM4663 LM4663 2.1 - - - 0.2 44 -   2 +4.5 - +5.5 V Po=1W 200mV, Vin="0" -   5   Yes High Stereo     -40 85       LM4663
    LM4666 LM4666 2.1 1.2 2.7 1.5 0.65 65 83   2 +2.7 - +5.5 V Po=100mWrms, f="1kHz", 22kHz BW, Both channels in phase 100mVrms, fripple="217Hz", Po="10mW", 1kHz Po=1Wrms;A-Weighted Filter   5   Yes Low Stereo     -40 85       LM4666
    LM4873 LM4873 2.1| 1.9 1.1 2.6 1.5 0.3 67 97   2 +2.0 - +5.5 V Po=1W@5V, 8 ohms, 20-20kHz| Po="2W"@5V, 4 ohms, 20-20kHz - -   5     High       -40 85 0     LM4873
    LM4883 LM4883 2.1 1.3 - - 0.05 73 -   4 +2.4 - +5.5 V 8 ohm 200mW input gnd, 1KHz Vr 200mV, 8ohm     5     High       -40 85       LM4883
    LM4888 LM4888 2.1 1.3 2.5 1.7 0.06 85 Undefined   2 +2.7 - +5.5 V IkHz, Avd="2";Rl=8ohm; Ro=.4W 217Hz; Vrip = 200mVp-p; Rl="8ohm" Undefined   5             -65 150       LM4888
    LM4991 LM4991 2.1 1.1 2.5 1.5 0.2 64 -   1 +2.2 - +5.5 V Po=0.5W, f="1kHz" Vripple=0.2V sine p-p, input terminated with 10ohms, f="1kHz"     5     High       -40 85       LM4991
    LM4835 LM4835 2 1.1 2.5 1.5 0.3 74 93   2 +2.7 - +5.5 V Po=1W @Vs=5V, 20Hz-20kHz 120 Hz Pout=1.1W   5     High       -40 85 0     LM4835
    LM4836 LM4836 2 1.1 2.5 1.5 0.3 74 93   2 +2.7 - +5.5 V Po=1W @Vs=5V, 20Hz-20kHz 120 Hz Pout=1.1W   5     High       -40 85       LM4836
    LM4838 LM4838 2 1.1 - 1.5 0.3 74 93   2 +2.7 - +5.5 V Po=1W @Vs=5V, 20Hz-20kHz 120 Hz RL="8" Ohms Pout=1.1W   5     High       -40 85       LM4838
    LM4839 LM4839 2 1.1 - 1.5 0.3 74 93   2 +2.7 - +5.5 V Po=1W @Vs=5V, 20Hz-20kHz 120 Hz RL="8" Ohms Pout=1.1W   5     High       -40 85       LM4839
    LM4840 LM4840 2 1 - 1.5 0.3 74 93   2 +2.7 - +5.5 V p=1w,20-20khz,rl=8avd=2 cb=1uf,f=120hz,vripple=200mvrms,rl=8 vdd=5v,pot=1.1w,rl=8, A wegihted   5     High       -40 85 0     LM4840
    LM4849 LM4849 2 1.1 - 1.5 0.3 74 93   2 +2.7 - +5.5 V Po=1W @Vs=5V 20Hz-20kHz 120Hz RL="8ohm" Po=1.1W   5     High       -40 85       LM4849
    LM4869 LM4869 1.9 1.2 1.9 1.5 0.3 62 97   2 +2.7 - +5.5 V         5     High       -40 85       LM4869
    LM4884 LM4884 1.9 1.2 2.3 1.5 0.3 62 97   2 - RL=8 Ohms, Po="1W" Vripple=200mVpp, Cbypass="0".46uF f=1kHz, Cbypass="0".47uF, Po="1".1W   5     High       -40 85       LM4884
    LM4876 LM4876 1.8 1.2 2.3 1.5 0.25 65 98   1 +2.0 - +5.5 V Po=1 W@ Vs="5V", R="8ohms", 20Hz-20kHz - -   2.6     Low       -40 85       LM4876
    LM4928 LM4928 1.8 1.2 2.2 1.5 0.04 90 105   2 +2.4 - +5.5 V Pout=1W, f="1kHz" Vripple=200mV p-p, f="217Hz", f="1kHz" Pout=1W, f="1kHz"   5     Low       -40 85       LM4928
    LM4853 LM4853 1.7 1.1 1.9 1.4 - 63 90   2 +2.4 - +5.5 V         5     High       -40 85       LM4853
    LM4860 LM4860 1.6 1.15 - 1.3 0.72 65 98   1 +2.0 - +5.5 V Po=1W@Vs=5V, R="8" ohms - Pout=1W   5     High       -20 85       LM4860
    LM4861 LM4861 1.55 1.15 1.9 1.5 0.72 65 98   1 +2.0 - +5.5 V Po=1W @ Vs="5V", R="8" ohms - Pout=1W   5     High       -40 85       LM4861
    LM4850 LM4850 1.5| 1.7 1.1 2.4| 1.9 1.45| 1.4 - - 100   2| 1 +2.4 - +5.5 V -| Undefined -| Undefined -| Undefined   5             -40 85       LM4850
    LM4895 LM4895 1.4 1 1.9 1.2 0.1 80 98 50 1 +2.2 - +5.5 V Po=.4Wrms@Vs=5V, R="8ohms" - -   5     High/Low Selectable       -40 85       LM4895
    LM4898 LM4898 1.4 1 2 1.3 0.05 90 - 50 1 +2.4 - +5.5 V Po=0.4Wrms, f="1kHz" Vripple=0.2V sine p-p, f="1kHz"     5     High/Low Selectable       -40 85       LM4898
    LM4899 LM4899 1.4 1 2 1.3 0.05 90 -   1 +2.4 - +5.5 V Po=0.4Wrms, f="1kHz" Vripple = 0.2V sine p-p, f = 1kHz     5     High/Low Selectable       -40 85       LM4899
    LM4665 LM4665 1 0.6 2.4 1.5 0.5 52 -   1 +2.7 - +5.5 V Po=0.1W @ Vs="3V" f=217Hz, Vripple="100Vrms"     5   Yes High/Low Selectable Mono     -40 85       LM4665
    LM48410 LM48410 0.94 0.58 1.14 0.74 0.025 70 88   2 +2.4 - +5.5 V Po=500mW, f="1kHz", RL = 8ohms Vripple=200mVpp, fripple="217Hz", Inputs AC GND Vdd=5V, Po = 1W, FF mode   3.6   Yes Independent Low Stereo     -40 85       LM48410
    LM4864 LM4864 0.675 0.725 - 0.85 0.7 50 98   1 +2.7 - +5.5 V Po=0.3W @ Vs="5V", R="8" ohms - -   5     High       -40 85       LM4864
    LM4877 LM4877 0.6 0.32 0.75 0.43 0.1 65 98   1 +2.0 - +5.5 V Po=.25 W @Vs=5V, R="8ohms", 20Hz-20kHz - -   2.6     Low       -40 85       LM4877
    LM4878 LM4878 0.55 0.32 0.75 0.43 0.1 65 98   1 +2.0 - +5.5 V Po=.25 W @Vs=5V, R="8ohms", 20Hz-20kHz - -   2.6     Low       -40 85       LM4878
    LM4667 LM4667 - 1.09 - 1.3 0.8 55 83   1 +2.7 - +5.5 V Pout=100mW, fin="1kHz" Vripple=100mV,fripple=217Hz Po-1Wrms, A-Weighted Filter   5   Yes Low Mono     -40 85       LM4667
    LM4668 LM4668 - 6 - 10 0.2 85 90   1 +9 - +14V   100Hz     12   Yes Low   - - -40 85       LM4668
    LM4680 LM4680 - 6 - 10 0.02 104 116   1 +9 - +14V Pout=1watt f=1kHZ,Vrip=200mV,cbypass=10uF,input reffered a weighted filter Vin="0V",input reffered   12   Yes Low   100 8 -40 85       LM4680
    LM4818 LM4818 - 0.24 - 0.3 1 - -   1 +2.0 - +5.5 V f=1kHz, Avd="2", Po = 0.27Wrms       5     High       -40 85       LM4818
    LM4819 LM4819 - 0.25 - 0.3 1 - -   1 +2.0 - +5.5 V f=1kHz, Avd="2", Po = 0.27Wrms       5     High       -40 85       LM4819
    LM4832 LM4832 - 0.25 - 0.35 0.15 89 105   2 +4.5 - +5.5 V Po=0.20W @ Vs="5V" 100 Hz Vo=3.5V   5     High       -40 85       LM4832
    LM4854 LM4854 -| 1.7 1.1 -| 2.1 1.3 0.08 63 90   2 +2.4 - +5.5 V Pout=.05W @ Vs="5V", R= 8 Ohms 1 kHz Pout=900mW, RL="8" Ohms   5     Low       -40 85       LM4854
    LM4862 LM4862 - 0.68 - 0.83 0.55 50 98   1 +2.7 - +5.5 V Po=0.5W @ Vs="5V", R="8" ohms - Pout=1W   5     High       -40 85       LM4862
    LM4865 LM4865 - 0.75 - 1 0.6 50 115   1 +2.7 - +5.5 V Po=300mW @ Vs="5V", R="8" ohms - -   5     High       -40 85       LM4865
    LM4868 LM4868 -| 2.1| 1.9 1.1 -| 2.6 1.5| 1.4 0.3 67 97   2 +2.0 - +5.5 V Po=1W @ Vs="5V", R="8" Ohms| Po="2W" @ Vs="5V", R="4" Ohms Vdd=5V, RL="8" Ohms RL=8 Ohms, Po="1".1W   5     High       -40 85       LM4868
    LM4872 LM4872 - 1.2 0.75 1.5 0.1 65 98   1 +2.0 - +5.5 V Po=.25W@Vs=-5V, R="8ohms" - -   5     High       -40 85       LM4872
    LM4875 LM4875 - 0.75 - 1 0.6 50 -   1 +2.7 - +5.5 V Pout=30mW, f="20Hz-20KHz", RL="8Ohms" Vripple=200mWrms, RL="8" Ohms, CB="1uF", F="1KHz"     5     Low       -40 85       LM4875
    LM4879 LM4879 - 1.1 - 1.2 0.1 68 -   1 - f=1kHz, Po = 0.5Wrms Vripple = 0.2Vpp sine, CB="1".0uF.  Input terminated with 10ohms to ground.  F = 1kHz     5     Low       -40 85       LM4879
    LM4889 LM4889 - 1 - 1.2 0.1 62 105   1 -         5     Low       -40 85       LM4889
    LM4890 LM4890 - 1 - 1.2 0.1 62 105   1 +2.0 - +5.5 V Po=.4Wrms@Vs=5 f = 1kHz -   5     Low       -40 85       LM4890
    LM4891 LM4891 - 0.9 - 1.1 0.1 66 -   1 +2.2 - +5.5 V Po = 0.4Vrms, f="1kHz" Vripple = 0.2V sine p-p, f = 1kHz     5     High       -40 85       LM4891
    LM4892 LM4892 - 1 - 1.2 0.1 66 105   1 +2.0 - +5.5 V Po=.4Wrms@Vs=5 f="1kHz", BW="10Hz-80Hz" f = 1kHz -   5     Low       -40 85       LM4892
    LM4894 LM4894 - 1 - 1.2 0.1 87 98 50 1 +2.0 - +5.5 V Po=.4Wrms@Vs=5, R="8ohms" - -   5     High/Low Selectable       -40 85       LM4894
    LM4900 LM4900 - - - - 0.4 67 100   1 +2.0 - +5.5 V Po=.4Wrms@Vs=5V, R="8ohms", @20Hz-20kHz 1KHz, 200mV -   5     High       -40 85       LM4900
    LM4901 LM4901 - 1 - 1.3 0.2 64 -   1 +2.0 - +5.5 V Po = 0.5Wrms, f="1kHz" Vripple = 0.2V sine p-p, Input terminated with 10ohms, f="1kHz"     5     High/Low Selectable       -40 85       LM4901
    LM4902 LM4902 - 0.675 - 1 0.4 67 -   1 +2.0 - +5.5 V Po = 0.4Wrms, Avd="2", RL="8ohms" Vripple=0.2Vrms sine p-p, f="1kHz"     5     Low       -40 85       LM4902
    LM4992 LM4992 - 1.07 - - 0.15 55 -   2 +2.2 - +5.5 V Vdd 5V, Po 0.5Wrms, f 1kHz Vr 200mV, Vdd 5V, terminated with 10ohm     5     Low       -40 85       LM4992
    LM4682 LM4682   6   8 0.2 94     2 +9 - +14V Po=6W/channel,fin=1kHz Vrip=200mVpp, 1kHz,Vin=0,input referred,f=60Hz     12   Yes Low       -40 85       LM4682
    运算放大器技术支持
    运算放大器技术支持
    Excel 文档格式下载 Excel 文档格式选型指南下载
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
