龙人旗下深圳市龙芯世纪科技有限公司
  • 耳机放大器 Headphone
  • 发布时间:2009/2/28 9:51:57   修改时间:2009/2/28 9:51:57 浏览次数:6533
  • 首页NS国半音频
    Headphone(20)
    Base Part Number 数据手册DataSheet下载 Power@ 8Ohms, 1% THD Power@ 16Ohms, 1% THD Power@ 32Ohms, 1% THD Power@ 8Ohms, 10% THD Power@ 16Ohms, 10% THD Power@ 32Ohms, 10% THD THD PSRR SNR Channels THD Conditions PSRR Conditions SNR Conditions User Supply Shutdown Type Supply Range Volume Control Exposed DAP Capless Headphone Temperature Min Temperature Max AEC Q-100 Automotive Grade Automotive Selection Guide PowerWise 数据手册DataSheet下载
    LM48822 LM48822 Undefined 0.035 0.04 Undefined Undefined Undefined 0.04 110 100 2 PO = 50mW, f = 1kHz, RL = 16脦漏 VRIPPLE = 200mVP-P, Inputs AC GND fRIPPLE = 217Hz 3.6 Undefined +2.4 - +5.5 V I2C No Yes -40 85 0 No   LM48822
    LM48860 LM48860 Undefined 0.04 0.05 Undefined Undefined Undefined 0.014 80 105 2 Po=25mW, f="1kHz", RL="32ohms" Vripple=200mVpp, input referred, f="217Hz" Po=50mW, f="1kHz", BW="20Hz-22kHz", A-weighted, RL="32ohms" 3 Low +2.0 - +5.5 V Undefined No Yes -40 84 Undefined No Undefined LM48860
    LM48861 LM48861 Undefined 0.012 0.013 Undefined Undefined Undefined 0.04 83 102 2 PO = 8mW, f = 1kHz, RL = 32脦漏 fRIPPLE = 217Hz RL = 32脦漏, POUT = 8mW 1.5 Low +1.4 - +3.6 V No No Yes -40 85 0 Yes Yes LM48861
    LM4982 LM4982 Undefined 0.047 0.051 Undefined Undefined Undefined   66 100 2   Input referred, f="217Hz" BW-20Hz to 22kHz 3 Independent Low +1.6 - +4.0V       -40 85       LM4982
    LM4985 LM4985 Undefined 0.135 0.08 Undefined     0.08 77   2 Pout = 100mW, f = 1kHz, Rload = 16ohms OCL mode, f = 217Hz, Rload = 16ohms   5 I2C +2.2 - +5.5 V 32 step I2C No Yes -40 85   Yes   LM4985
    LM4881 LM4881 0.26 0.15 0.092 0.3 0.2 0.11 0.02 50 100 2 Po=75mW @ R="32" ohms f=120 Hz - 5 High +2.7 - +5.5 V   No No -40 85       LM4881
    LM4880 LM4880 0.25 0.16 0.085 0.325 0.2 0.11 0.02 50 - 2 Po=75mW @ R = 32 ohms f=100Hz   5 High +2.7 - +5.5 V   No No -40 85       LM4880
    LM4809 LM4809 0.15 0.13 0.08 0.18 0.16 0.09 0.03 70 107 2 Po=50mW @ f="20Hz" to 20kHz f=1kHz, ter. input into 50 Ohms Po=.08W 5 Low +2.0 - +5.5 V   Yes No -40 85       LM4809
    LM4810 LM4810 0.15 0.13 0.08 0.18 0.16 0.09 0.03 70 107 2 Po=50mW @ R="32" ohms, f="20Hz" to 20kHz f=1kHz, ter. input into 50 Ohms Po=.08W 5 High +2.0 - +5.5 V   Yes No -40 85       LM4810
    LM4811 LM4811 0.15 0.13 - 0.18 0.16 - 0.03 60 106 2 Po=50mW @ R="32" ohms, f="20Hz" to 20kHz f=217 Hz Po=.08W 5 High +2.0 - +5.5 V Up/Down Yes No -40 85       LM4811
    LM4916 LM4916 0.085 0.055 - 0.1 0.7 - 0.2 66 - 2 RL=16 ohms, SE, Po="5mW" f=1kHz, R="16" ohms, SE   1.5   -       -40 85       LM4916
    LM4808 LM4808 - 0.105 0.07 - 0.15 0.09 0.05 66 105 2 RL=16,Vo=3.5VPP(at 0 dB) - Vo=3.5V 5   +2.0 - +5.5 V   Yes No -40 85       LM4808
    LM4910 LM4910 - 0.062 0.035 - 0.08 0.048 0.3 65 97 2 Po=30mW @ Vs="5V", R="32" ohms f=217 Hz or 1kHz, input term. With 10 ohms to ground Po=.035W 3.3 Low +2.2 - +5.5 V   Yes Yes -40 85       LM4910
    LM4911 LM4911 - 0.145 0.085 - 0.15 0.11 - 65 110 2 - f=1 kHz Po=.048W 5 Low (Mute) +2.0 - +5.5 V   Yes Yes -40 85       LM4911
    LM4915 LM4915 - 0.25 0.12 - - - 0.1 65 - 1 Pout=25mW Vripple=200mV   5 Low +2.2 - +5.5 V   Yes No -40 85       LM4915
    LM4917 LM4917 - 0.097 0.082 - 0.108 0.108 0.02 70 100 2 Po=50mW, f="1kHz", Rl="32" Ohms Vripple=200mW, f="1kHz" RL=32 Ohms, Pout="20mW", f="1kHz" 3 Independent Low +1.4 - +3.6 V       -40 85       LM4917
    LM4921 LM4921 - - 0.05 - - - 0.03 62 82 2 f=1kHz, Pout = 12mW f = 217Hz, Vripple="200mVpp" f=1kHz 3 High - SPI No No -40 85       LM4921
    LM4924 LM4924 - 0.04 - - - - 0.1 66 - 2 Po=10mW Vrpi=200Mvpp,Sine,f=100Hz,OCL   3 Low (Mute) +1.4 - +3.6 V   Yes Yes -40 85       LM4924
    LM4920 LM4920   0.08 0.065       0.03 70 100 2 Po=50mW, f="1kHz", RL="32" Ohms, single channel f=217Hz, Vripple="200mVp-p" RL=32, Po="20mW" 3 Independent Low +1.4 - +3.6 V       -40 85       LM4920
    LM4980 LM4980   0.042 0.028       0.02 90   2 RL = 32ohm, POUT = 10mW, f = 1kHz VRIPPLE = 200mVP-P sine wave   3 Low +1.5 - +3.3V   No Yes -40 85   Yes Yes LM4980
    运算放大器技术支持
    Excel 文档格式下载 Excel 文档格式选型指南下载
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
