龙人旗下深圳市龙芯世纪科技有限公司
  • 高性能音频 Performance Audio
  • 发布时间:2009/2/28 9:53:35   修改时间:2009/2/28 9:53:35 浏览次数:5221
  • 首页NS国半音频
    高性能音频 Performance Audio (17)
    Base Part Number 数据手册DataSheet下载 THD PSRR Supply Min Single/Dual/Quad Special Features THD Conditions PSRR Conditions User Supply Supply Max Supply Current per Amplifier Shut down Voltage Noise Supply Range Max Input Bias Current Output Current Offset Voltage, typ Gain Bandwidth Slew Rate CMRR CMRR Conditions Mono/Stereo Temperature Min Temperature Max Channels Input OutputType Offset Voltage max, 25C AEC Q-100 Automotive Grade Automotive Selection Guide PowerWise 数据手册DataSheet下载
    LME49722 LME49722 0.00002 120 2.5 Dual Undefined Undefined Undefined Undefined 18 12.1 Undefined 1.9 Undefined 53 28 0.02 55 22 130 Undefined Undefined -40 85 2 Not Rail to Rail 0.7       LME49722
    LM4562 LM4562 0.00003 120 5 Dual Ultra Low Distortion, Very Low Noise Av=1; Vout="3Vrms"; Load="600ohm" and 2k delta(Vs)=20V   34 5 No 2.7   72 42 0.1 55 20 120 Vcm from -10V to +10V   -40 85 2 Not Rail to Rail 0.7     Yes LM4562
    LME49600 LME49600 0.00003 Undefined| 75 4.5 Single Adj BW Closed loop with LME49710| Closed loop with LME49860 Undefined 44| 15 44| 36 13| 14.5 No 3| 2.6 +/-2.5 to +/-22V| +/-2.25V to +/-18V 5000| 5 250 Undefined| 17 180 2000| 2000 Undefined Undefined Mono -40 85 1 Not Rail to Rail 60 Undefined Yes   LME49600
    LME49710 LME49710 0.00003 125 5 Single Ultra Low Distortion, Very Low Noise Av=1; Vout="3Vrms"; Load="600ohm" and 2k delta(Vs)=20V   34 4.8 No 2.5   72 26 0.05 55 20 120 Vcm from -10V to +10V   -40 85 1 Not Rail to Rail 0.7   Yes Yes LME49710
    LME49720 LME49720 0.00003 120 5 Dual Ultra Low Distortion, Very Low Noise Av=1; Vout="3Vrms"; Load="600ohm" and 2k delta(Vs)=20V   34 5 No 2.5   72 42 0.1 55 20 120 Vcm from -10V to +10V   -40 85 2 Not Rail to Rail 0.7   Yes Yes LME49720
    LME49740 LME49740 0.00003 120 5 Quad Ultra Low Distortion, Very Low Noise Av=1; Vout="3Vrms"; Load="600ohm" and 2k delta(Vs)=20V   34 4.62 No 2.5   72 30 0.1 55 20 120 Vcm from -10V to +10V   -40 85 4 Not Rail to Rail 0.7   Yes Yes LME49740
    LME49860 LME49860 0.00003 120 5 Dual High Operating Voltage, Ultra Low Distortion, Very Low Noise Av=1; Vout="3Vrms"; Load="600ohm" and 2k delta(Vs)=30V   44 5.25 No 2.7   72 37 0.14 55 20 120 Vcm from -15V to +15V   -40 85 2 Not Rail to Rail 0.7   Yes   LME49860
    LME49870 LME49870 0.00003 120 5 Single High Operating Voltage, Ultra Low Distortion, Very Low Noise Av=1; Vout="3Vrms"; Load="600ohm" and 2k delta(Vs)=30V   44 4.8   2.7   72 26 0.05 55 20 120 Vcm from -15V to +15V   -40 85 1   0.7   Yes   LME49870
    LME49725 LME49725 0.00004 120 4.5 Dual Undefined Undefined Undefined Undefined 18 3 Undefined 3.3 Undefined 90 22 0.5 40 15 120   Stereo -40 85 Undefined Not Rail to Rail 1       LME49725
    LME49743 LME49743 0.0001 98 3 Quad Undefined Undefined Undefined Undefined 17 2.62 Undefined 3.5 Undefined 250 21 0.05 30 12 106 Undefined Undefined -40 85 4 Not Rail to Rail 0.26       LME49743
    LME49721 LME49721 0.0002 103 2.2 Dual Rail to rail Av=+1, Vout="2Vpp", Rl="2kohm", Rl="600ohm"   5 5.5 2.15 No 4 +2.2 - +5.5 V 0.00004 9.7 0.3 20 8.5 93 Vss-100mV < Vout < Vdd+200mV Stereo -40 85 2 R-R In and Out 1.5   Yes   LME49721
    LME49723 LME49723 0.0002 100 2.5 Dual   Av=1, Vout="3Vrms", Rl="600ohms" delta Vs= 20V 7 17 6.7 No 3.2 +1.4 - +3.6 V   25 0.3 17 8 100 -10V<Vom<10V Stereo -40 85 2 Not Rail to Rail 1   Yes   LME49723
    LME49811 LME49811 0.0003 110   Single   No load, Av = 30dB, Vout = 20Vrms @ 1kHz Rs = 1k, f = 100Hz, Vripple = 1Vrms, Input Referred           +/-20V to +/-100V         17     Mono -20 75 1       Yes   LME49811
    LME49830 LME49830 0.0006 105   Single   No Load, f = 1kHz, AV = 30dB,VOUT = 14VRMS, 22kHz BW f=100Hz, VRIPPLE =1VRMS, Input referred, AV = 30dB 100   36     +/-20V to +/-100V 45 60 2.1   34 94   Mono -20 75 1 Not Rail to Rail 35       LME49830
    LME49810 LME49810 0.0007 110   Single Baker Clamp prevents output saturation No Load, BW="30kHz", VOUT="30Vrms", f="1kHz" f=DC, Input Referred 100         +/-20V to +/-100V 200 60 1 Undefined 50 Undefined Undefined Mono -20 85 1   3   Yes   LME49810
    LME49713 LME49713 0.0008 102 10 Single Current Feedback Audio Amp, AvCl>2 Rl=600, Vout="1".4Vrms 102 15 36 8 No 1.9 +/-2.25V to +/-18V 5000 140 0.05 190 1900 88 #NAME? Mono -40 85 1 Not Rail to Rail 1   Yes   LME49713
    LM4702 LM4702 0.005|  0.0003 110   Dual   No load, Av="30dB", Vout="14Vrms", f="1kHz|" No load, Av="30dB", Vout="20Vrms", f="1kHz" Rs=1k, f="100Hz", 1Vrms, input referred 75| 100     No   -100V - +100V| -75 - +75V   5.5 10   15| 17     Stereo -20 75 2 Undefined     Yes   LM4702
    运算放大器技术支持
    Excel 文档格式下载 Excel 文档格式选型指南下载
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
