龙人旗下深圳市龙芯世纪科技有限公司
  • DAC数据转换器
  • 发布时间:2009/2/28 9:56:59   修改时间:2009/2/28 9:56:59 浏览次数:4490
  • 首页NS国半数据转换器
    DAC 数据转换器Data Converters
    Base Part Number 数据手册DataSheet下载 Resolution Pin and Function Compatible Family Channels Interface Type Settling Time INL (LSB) DNL (LSB) PowerWise Rating 1 Power Down, typ. at 3.6V Oper Pwr typ, 3.6V, 30/0.4MHz SPI/I2C Reference Source Max Supply Voltage Min Supply Voltage Temperature Min Temperature Max OtherSupply Voltage Tsettling Conditions Data Converter Type AEC Q-100 Automotive Grade Automotive Selection Guide PowerWise 数据手册DataSheet下载
    DAC121C081 DAC121C081 12 None 1 I2C 8500 +/-8 +0.6, -0.5 15.94 0.05 0.48 Supply 5.5 2.7 -40 125 Undefined   DAC     Yes DAC121C081
    DAC121C085 DAC121C085 12 None 1 I2C 8500 +/-8 +0.6, -0.5 15.94 0.05 0.48 External 5.5 2.7 -40 125 Undefined   DAC     Yes DAC121C085
    DAC121S101 DAC121S101 12 1 ch, SOT-6| 1 ch, MSOP-8 1 Serial 8000 +/-2.6 +0.25, -0.1 6.5 0.14 0.64 Supply 5.5 2.7 -40 105 4.5V to 5.5V code change 400h to C00h DAC     Yes DAC121S101
    DAC122S085 DAC122S085 12 2/4 ch, MSOP-10| 2/4 ch, LLP-10 2 SPI/Microwire 8500 +/-2.4 +2.0, -0.15 2.99 0.3 0.6 External 5.5 2.7 -40 105 4.5V to 5.5V code change 400h to C00h DAC   Yes Yes DAC122S085
    DAC124S085 DAC124S085 12 2/4 ch, MSOP-10| 2/4 ch, LLP-10 4 SPI/Microwire 8500 +/-2.4 +2.0, -0.15 2.74 0.3 1.1 External 5.5 2.7 -40 105 4.5V to 5.5V code change from 100h to 300h DAC   Yes Yes DAC124S085
    DAC128S085 DAC128S085 12 None 8 SPI/QSPI/Microwire 8000 +/-8 +0.75, -0.4 7.62 0.3 1.95 External 5.5 2.7 -40 125 Undefined 5.5V DAC   Yes Yes DAC128S085
    DAC101C081 DAC101C081 10 1 ch, SOT-6| 1 ch, LLP-6 1 I2C 8500 +/-2 +0.35, -0.25       Supply 5.5 2.7 -40 125 4.5V to 5.5V   DAC       DAC101C081
    DAC101C085 DAC101C085 10 1 ch, MSOP-8 1 I2C 8500 +/-2 +0.35, -0.25       External 5.5 2.7 -40 125 4.5V to 5.5V   DAC       DAC101C085
    DAC101S101 DAC101S101 10 1 ch, SOT-6| 1 ch, MSOP-8 1 Serial 8000 +/-0.6 +/-0.15 5.91 0.14 0.63 Supply 5.5 2.7 -40 105 4.5V to 5.5V code change 100h to 300h DAC 1 Yes Yes DAC101S101
    DAC102S085 DAC102S085 10 2/4 ch, MSOP-10| 2/4 ch, LLP-10 2 SPI/Microwire 6000 +/-0.7 +0.08, -0.03 2.46 0.3 0.6 External 5.5 2.7 -40 105 4.5V to 30V code change 100h to 300h DAC   Yes Yes DAC102S085
    DAC104S085 DAC104S085 10 2/4 ch, MSOP-10| 2/4 ch, LLP-10 4 SPI/Microwire 8500 +/-0.7 +0.08, -0.03 3.2 0.3 1.1 External 5.5 2.7 -40 105 4.5V to 5.5V code change from 100h to 300h DAC   Yes Yes DAC104S085
    DAC108S085 DAC108S085 10 None 8 SPI/QSPI/Microwire 8000 +/-2 +0.35, -0.2 7.62 0.3 1.95 External 5.5 2.7 -40 125 Undefined 5.5V DAC   Yes Yes DAC108S085
    DAC0800 DAC0800 8 None 1 Parallel 100 - -       External - - -55 125 ±5V to ±15V 1/2 LSB DAC       DAC0800
    DAC0802 DAC0802 8 None 1 Parallel 100 - -       External - - -55 125 ±5V to ±15V 1/2 LSB DAC       DAC0802
    DAC0808 DAC0808 8 None 1 Parallel 150 - -       External - - 0 70 ±5V to ±15V 1/2 LSB DAC       DAC0808
    DAC081C081 DAC081C081 8 1 ch, SOT-6| 1 ch, LLP-6 1 I2C 8500 +/-0.5 +0.18, -0.13       Supply 5.5 2.7 -40 125 4.5V to 5.5V   DAC       DAC081C081
    DAC081C085 DAC081C085 8 1 ch, MSOP-8 1 I2C 8500 +/-0.5 +0.18, -0.13       External 5.5 2.7 -40 125 4.5V to 5.5V   DAC       DAC081C085
    DAC081S101 DAC081S101 8 1 ch, SOT-6| 1 ch, MSOP-8 1 SPI/Microwire 3000 +/-0.2 +/-0.04 2.95 0.14 0.63 Supply 5.5 2.7 -40 105 4.5V to 5.5V code change 40h to C0h DAC     Yes DAC081S101
    DAC082S085 DAC082S085 8 2/4 ch, MSOP-10| 2/4 ch, LLP-10 2 SPI/Microwire 4500 +/-0.14 +0.04, -0.02 1.48 0.3 0.6 External 5.5 2.7 -40 105 4.5V to 5.5V code change 40h to C0h DAC   Yes Yes DAC082S085
    DAC0830 DAC0830 8 - 1 Parallel 1000 - -       External 5 - -55 125 +5V to +15V 1/2 LSB DAC       DAC0830
    DAC0832 DAC0832 8 - 1 Parallel 1000 - -       External 5 - -55 125 +5V to +15V 1/2 LSB DAC       DAC0832
    DAC084S085 DAC084S085 8 2/4 ch, MSOP-10| 2/4 ch, LLP-10 4 SPI / QSPI / Microwire 8500 +/-0.14 +0.04, -0.02 2.56 0.3 1.1 External 5.5 2.7 -40 105 - code change 40h to C0h DAC   Yes Yes DAC084S085
    DAC088S085 DAC088S085 8 None 8 SPI/QSPI/Microwire 8000 +/-0.5 +0.15, -0.1 7.62 0.3 1.95 External 5.5 2.7 -40 125 Undefined 5.5V DAC   Yes Yes DAC088S085
    DAC 数据转换器Data Converters技术支持
    Excel 文档格式下载 Excel 文档格式选型指南下载
    ADC 数据转换器Data Converters
    ADC 数据转换器Data Converters技术支持
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
