龙人旗下深圳市龙芯世纪科技有限公司
  • 电压参考
  • 发布时间:2009/2/28 10:10:25   修改时间:2009/2/28 10:10:25 浏览次数:3370
  • 首页NS国半电源管理电压参考
    NSC国半基准源
    基准电流源Current References(3)
    Base Part Number 数据手册DataSheet下载 Initial Accuracy (+/-) Max Input Min Voltage Input Max Voltage Output Current Temperature Min Temperature Max PowerWise 数据手册DataSheet下载
    LM134 LM134 3 0.8 40 10 -55 125   LM134
    LM234 LM234 3 0.8 40 10 -25 100   LM234
    LM334 LM334 6 0.8 40 10 0 70   LM334
    串联电压基准 Series Voltage References(5)
    Base Part Number 数据手册DataSheet下载 Initial Accuracy (+/-) Max Reference Voltage Tempco, max (ppm/C) Input Min Voltage Input Max Voltage Dropout Voltage Quiescent Current Output Current Voltage Noise (rms) Long Term Stability (ppm/1000hr) Temperature Min Temperature Max AEC Q-100 Automotive Grade Automotive Selection Guide PowerWise 数据手册DataSheet下载
    LM4140 LM4140 0.1 1.25 V| 4.096 V| 2.048 V| 1.024 V| 2.5 V 10| 3| 6 4.366| 1.8| 2.283| 2.735 5.5 0.195| 0.16 0.23 8 2.2 60 0 70     Yes LM4140
    LM4120 LM4120 0.2| 0.5 3 V| 3.3 V| 4.096 V| 2.048 V| 5 V| 1.8 V| 2.5 V 50 3.3 14 0.18 0.16 5 20 100 -40 85   Yes Yes LM4120
    LM4121 LM4121 0.2| 0.5 1.25 V| Adjustable 50 3.3 14 0.25 0.16 5 30 100 -40 85     Yes LM4121
    LM4128 LM4128 0.2| 0.5| 1| 0.1 3 V| 3.3 V| 4.096 V| 2.048 V| 1.8 V| 2.5 V 75| 100 2.2| 4.496| 3.4| 2.448| 3.7| 2.9 5.5 0.4 0.06 20 170 50 -40 125   Yes Yes LM4128
    LM4132 LM4132 0.4| 0.2| 0.5| 0.1| 0.05 4.096 V| 2.048 V| 2.5 V 30| 10|  20| 20|  10 2.2 5.5 0.175 0.06 20 170 50 -40 125   Yes Yes LM4132
    并联型电压基准(24)
    Base Part Number 数据手册DataSheet下载 Initial Accuracy (+/-) Max Reference Voltage Tempco, max (ppm/C) Output Current Operating Current Reference with respect to Temperature Min Temperature Max AEC Q-100 Automotive Grade Automotive Selection Guide PowerWise 数据手册DataSheet下载
    LM4030 LM4030 0.05 4.096 V| 2.5 V 10 50 0.12 Cathode (high side) -40 125 Undefined Yes No LM4030
    LM4051 LM4051 0.1 1.225 V| Adjustable 50 12 0.06 Cathode (high side) -40 85       LM4051
    LM4040 LM4040 0.2| 2| 0.5| 1| 0.1 4.096 V| 10 V| 5 V| 2.5 V 150| 100 15 0.06| 0.068| 0.074| 0.1   -40 85| 125       LM4040
    LM4041 LM4041 0.2| 2| 0.5| 1| 0.1 1.225 V| Adjustable 150| 100 12 0.06 Cathode (high side) -40 85| 125       LM4041
    LM4050 LM4050 0.2| 0.5| 0.1 4.096 V| 5 V| 2.5 V 50 15 0.06| 0.068| 15| 0.074   -40 85| 125       LM4050
    LMV431B LMV431B 0.5 Adjustable 129 Undefined 0.055 Anode (low side) -40 85       LMV431B
    LM185-1.2 LM185-1.2 1 1.235 V 150 20 0.01   -55 125       LM185-1.2
    LM185-ADJ LM185-ADJ 1 Adjustable 150 20 0.01 Cathode (high side) -55 125       LM185-ADJ
    LM285-1.2 LM285-1.2 1 1.235 V 150 20 0.01   -40 85       LM285-1.2
    LM431 LM431 1 Adjustable 54 100 1 Anode (low side) -40 85       LM431
    LMV431A LMV431A 1 1.2 V 138| 129 Undefined 0.055 Anode (low side) -40 85     Undefined LMV431A
    LM199 LM199 1.2 6.95 V 0.05 10 0.5   -55 125       LM199
    LM185-2.5 LM185-2.5 1.5 2.5 V 150 20 0.02   -55 125       LM185-2.5
    LM285-2.5 LM285-2.5 1.5 2.5 V 150| 30| 50 20 0.02   -40 85       LM285-2.5
    LMV431 LMV431 1.5 Adjustable 138| 129 Undefined 0.055 Anode (low side) -40| 0 85| 70       LMV431
    LM285-ADJ LM285-ADJ 2 Adjustable 150 20 0.01 Cathode (high side) -40 85       LM285-ADJ
    LM385-1.2 LM385-1.2 2 1.235 V 150 20 0.01   0 70       LM385-1.2
    LM385-ADJ LM385-ADJ 2 Adjustable 150 20 0.01 Cathode (high side) 0 70       LM385-ADJ
    LM4431 LM4431 2 2.5 V - 15 0.1   0 70       LM4431
    LM385-2.5 LM385-2.5 3 2.5 V - 20 0.02   0 70       LM385-2.5
    LM336-2.5 LM336-2.5 4 2.5 V 34 10 0.4   0 70       LM336-2.5
    LM336-5.0 LM336-5.0 4 5 V 34 10 0.6   0 70       LM336-5.0
    LM113 LM113 5 1.22 V - 20 0.5   -55 150       LM113
    LM329 LM329 5 6.9 V 10 15 0.6   0 70       LM329
    基准源技术支持:
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
