龙人旗下深圳市龙芯世纪科技有限公司
  • NSC 国半热管理器
  • 发布时间:2009/2/28 10:13:38   修改时间:2009/2/28 10:13:38 浏览次数:2098
  • 首页NS国半热管理器
    NSC 国半热管理器
    模拟 Analog(18 )
    Base Part Number 数据手册DataSheet下载 Temperature Accuracy (+/-) Supply Min Quiescent Current_ Temperature Min Temperature Max Sensor Gain Supply Max Single Supply Output Impedance Quiescent Current AEC Q-100 Automotive Grade Automotive Selection Guide PowerWise
    LM35 LM35 0.5| 1 4 56 -55| 0| -40 150| 110| 100 10 mV/Deg C 30 No 0.4 0.056   Yes
    LM135A LM135A 1 5 1000 -55 150 10 mV/Deg K - Yes 0.5 1
    LM235A LM235A 1 5 1000 -40 125 10 mV/Deg K - Yes 0.5 1
    LM34 LM34 1.11| 0.556 5 75 -45.5555| 0| -40 110| 148.889008| 100 10 mV/Deg F 30 No 0.4 0.075
    LM20 LM20 1.5| 2.5| 4 2.4 4.5 -55| -40 130| 125 -11.7 mV/Deg C 5.5 Yes 160 0.0045   Yes
    LM94021 LM94021 1.5 1.5 9 -50 150 -5.5 to -13.6 mV/degC 5.5 Yes 8 0.012   Yes Yes
    LM94022 LM94022 1.5 1.5 5.4 -50 150 -5.5 to -13.6 mV/degC 5.5 Yes 5.2 0.0081 0 Yes Yes
    LM94023 LM94023 1.5 1.5 8.1 -50 150 -5.5 or -8.2 mV/degC 5.5 Yes 4.4 0.0081 Undefined Yes Yes
    LM19 LM19 2.5 2.4 4.5 -55 130 -11.7 mV/Deg C 5.5 Yes 160 0.0045   Yes
    LM135 LM135 3 5 1000 -55 150 10 mV/Deg K - Yes 0.5 1
    LM235 LM235 3 5 1000 -40 125 10 mV/Deg K - Yes 0.5 1
    LM335 LM335 3| 6 5 1000 -40 100 10 mV/Deg K - Yes 0.6 1
    LM335A LM335A 3 5 1000 -40 100 10 mV/Deg K - Yes 0.6 1
    LM45 LM45 3| 2 4 120 -20 100 10 mV/Deg C 10 No 35 0.12     No
    LM50 LM50 3| 2 4.5 130 -40| -25 125| 100 10 mV/Deg C 10 Yes 2000 0.13   Yes
    LM60 LM60 3| 2 2.7 82 -40| -25 125 6.25 mV/Deg C 10 Yes 800 0.082   Yes
    LM61 LM61 3| 2 2.7 82 -30| -25 85| 100 10 mV/Deg C 10 Yes 800 0.082   Yes
    LM62 LM62 3| 2 2.7 82 0 90 15.6 mV/Deg C 10 Yes 4400 0.082   Yes
    数字 Digital (27 )
    Base Part Number 数据手册DataSheet下载 Remote Diode Thermal Sensors Temperature Accuracy (+/-) Supply Min Quiescent Current Temperature Min Temperature Max Interface Type Programmable Setpoints TruTherm(TM) Beta Compensation Resolution Resolution degC/LSB Supply Max Shut down Integrated Fan Controls Interrupt Outputs Fault Queue AEC Q-100 Automotive Grade Automotive Selection Guide PowerWise
    LM70 LM70 - 2 2.7 0.49 -55 150 SPI/Microwire No - 11 0.25 5.5 Yes - - No   Yes Yes
    LM71 LM71 - 1.5 2.65 0.55 -40 150 SPI/Microwire No - 14 0.0325 5.5 Yes - - No   Yes Yes
    LM73 LM73 - 1 2.7 0.495 -40 150 2-Wire Serial Yes - 14 0.03125 5.5 Yes - 1 No   Yes Yes
    LM74 LM74 - 1.25 3| 4.5 0.52 -55 150 SPI/Microwire No - 13 0.0625 3.6| 5.5 Yes - - No   Yes
    LM75 LM75 - 2 3| 4.5 1 -55 125 2-Wire Serial Yes - 9 0.5 3.6| 5.5 Yes - 1 Yes   Yes
    LM76 LM76 - 1 4.5 0.45 -55 150 2-Wire Serial Yes - 13 0.0625 5.5 Yes - 2 Yes   Yes
    LM77 LM77 - 1.5 3 0.5 -55 125 2-Wire Serial Yes - 10 0.5 5.5 Yes - 2 Yes   Yes
    LM92 LM92 - 0.33 2.7 0.625 -55 150 2-Wire Serial Yes - 13 0.0625 5.5 Yes - 2 Yes   Yes Yes
    LM95010 LM95010 - 3 3 0.5 0 125 Sensor Path No - - 0.25 3.6 Yes - - No
    LM95071 LM95071 - 1 2.4 0.28 -40 150 SPI/Microwire No - 14 0.03125 5.5 Yes - - No   Yes Yes
    LM63 LM63 1 1 3 1.3 0 125 SMBus Yes No 11 0.125 3.6 Yes 1 1 Yes   Yes Yes
    LM82 LM82 1 3 3 0.8 -40 125 2-Wire Serial Yes - 8 1 3.6 No - 2 No
    LM84 LM84 1 3 3 1 0 125 2-Wire Serial Yes - 8 1 3.6 No - 2 No
    LM86 LM86 1 0.75 3 1.7 0 125 2-Wire Serial Yes - 11 0.125 3.6 Yes - 2 Yes
    LM89 LM89 1 1 3 1.7 0 125 2-Wire Serial Yes - 11 0.125 3.6 Yes - 2 Yes
    LM90 LM90 1 3 3 1.7 0 125 2-Wire Serial Yes - 11 0.125 3.6 Yes - 2 Yes
    LM95235 LM95235 1 0.75 3 0.35 25 125 2-Wire Serial Yes Yes 13 0.03125 3.6 Yes Undefined 2 No 3 Yes Yes
    LM95245 LM95245 1 0.75 3 0.25 -40 125 SMBus Yes Yes 13 0.03125 3.6 Yes Undefined 2 No     Yes
    LM99 LM99 1 1 3 1.7 30 140 SMBus Yes - 11 0.125 3.6 Yes - 2 Yes     Yes
    LM95213 LM95213 2 1.1 3 0.57 -40 140 2-Wire Serial Yes No 13 0.03125 3.3 Yes Undefined 3 No   Yes Yes
    LM95221 LM95221 2 1 3 2 0 140 2-Wire Serial No No 11 0.125 3.6 Yes - - No
    LM95231 LM95231 2 1.25 3 0.363 25 140 2-Wire Serial No Yes 13 0.03125 3.6 Yes Undefined Undefined No
    LM95233 LM95233 2 0.875 3 0.57 -40 140 2-Wire Serial Yes Yes 13 0.03125 3.6 Yes Undefined 3 No   Yes Yes
    LM95241 LM95241 2 1.25 3 0.471 0 140 2-Wire Serial No Yes 13 0.03125 3.6 Yes     No     Yes
    LM83 LM83 3 3 3 0.8 -40 125 2-Wire Serial Yes - 8 1 3.6 No - 2 No
    LM95214 LM95214 4 1.1 3 0.57 -40 140 2-Wire Serial Yes No 13 0.03125 3.6 Yes Undefined 3 Yes   Yes Yes
    LM95234 LM95234 4 0.875 3 0.57 -40 140 2-Wire Serial Yes Yes 13 0.03125 3.6 Yes Undefined 3 Yes   Yes Yes
    硬件监视 Hardware Monitor(11)
    Base Part Number 数据手册DataSheet下载 Temp Resolution Remote Diode Thermal Sensors TruTherm(TM) Beta Compensation Analog Inputs ADC Resolution Fan Speed Inputs Fan Control Output(s) Fan Control Method VID Inputs Dynamic VID VCCP Monitoring Bidirectional PROCHOT Support GPIOs Interrupt Outputs Reference Voltage Temperature Accuracy (+/-) Temperature Min Temperature Max Interface Type Supply Min Supply Max Quiescent Current Resolution Temperature Accuracy (+/-) AEC Q-100 Automotive Grade Automotive Selection Guide PowerWise
    LM63 LM63 11-bit/0.125degC 1 No Undefined Undefined 1 1 PWM Lookup Table Undefined Undefined Undefined Undefined 1 Undefined 1 0 125 SMBus 3 3.6 1.3 11 1   Yes Yes
    LM64 LM64 11-bit/0.125degC 1 No Undefined Undefined 1 1 PWM Lookup Table Undefined Undefined Undefined 5 GPIO, 5 GPD 1 Undefined 1 0 125 SMBus 3 3.6 1.1 11 1   Yes
    LM96163 LM96163 11-bit/0.125degC 1 Yes Undefined Undefined 1 1 LUT 12 point Undefined Undefined Undefined Undefined 2 Undefined 0.75 -40 125 SMBus 3 3.6 0.456 13 0.75 Undefined Yes Yes
    LM85 LM85 8-bit/1degC 2 No 4, V+ 8 4 3 PWM Linear 5 Undefined Undefined Undefined Undefined Undefined Undefined 0 125 SMBus 3 3.6 0.53 Undefined Undefined
    LM87 LM87 8-bit/1degC 2 No 7 to 3, V+ 8 4 1 DAC Undefined 5 Undefined Undefined CI, RESET 1 Undefined 3 -40 125 2-Wire Serial 2.8 3.8 2 8 3   Yes Yes
    LM93 LM93 8-bit/1degC 2 No 15 to 10, V+ 8 4 2 PWM, 22.5kHz Lookup Table Dual 6 2 2 8 GPIO, 2 GPI, RESET 1 2.5 V 3 0 85 SMBus 3 3.6 0.9 8 3
    LM96000 LM96000 8-bit/1degC 2 No 4, V+ 8 4 3 PWM, 22.5kHz Linear 5 Undefined Undefined Undefined Undefined Undefined 3 0 125 SMBus 3 3.6 0.53 8 3   Yes Yes
    LM80 LM80 9-bit/0.5degC - No 7 8 2 Undefined Undefined Undefined Undefined Undefined CI, RESET, BTI, INT_IN 2 Undefined 3 -25 125 2-Wire Serial 2.8 5.75 1 9 3     Yes
    LM94 LM94 9-bit/0.5degC 4 Yes 15 to 10, V+ 8 4 2 PWM, 22.5kHz PI and Lookup Table Dual 7 2 2 8 GPIO, 2GPI, RESET 1 2.5 V 2.5 0 100 SMBus 3 3.6 1.6 9 2.5   Yes Yes
    LM96194 LM96194 9-bit/0.5degC 4 Yes 8 to 6, V+ 8 4 2 PWM, 22.5kHz PI and Lookup Table 7 1 1 8 GPIO, 1 GPI, RESET 1 Undefined 2.5 -40 100 SMBus 3 3.6 1.6 9 2.5   Yes Yes
    LM81 LM81 9-bit/0.5degC;12-bit/0.0625degC - No 6 8 2 1 DAC Undefined 5 Undefined Undefined CI, RESET 2 Undefined 3 -40 125 SMBus 2.8 3.8 0.9 9 3
    温度开关 Temperature Switch(7)
    Base Part Number 数据手册DataSheet下载 SetPoint Type SetPoint Value Temperature Accuracy (+/-) Supply Min Temperature Min Temperature Max Quiescent Current_ Comparators Sensor Gain Remote Diode Thermal Sensors Supply Max VtempOutput Impedance Reference Output Quiescent Current AEC Q-100 Automotive Grade Automotive Selection Guide PowerWise 数据手册DataSheet下载
    LM26 LM26 Fixed 85| 105| 0| 70| 115| 75| 95| 65| 50| 90| 110| 100| -25| 120| 45 3 2.7 -55 125 40 1 -10.82 mV/Deg C Undefined 5.5 18 Undefined 0.04 null| Undefined Yes Yes LM26
    LM26LV LM26LV Fixed 105 2.2 1.6 0 150 8 1 -5.1 to -12.8 mV/C Undefined 5.5 1 Undefined 0.008   Yes Yes LM26LV
    LM26NV LM26NV Fixed 115 3 2.7 -55 125 40 1 Undefined Undefined 5.5 Undefined Undefined 0.04 Undefined Yes Yes LM26NV
    LM27 LM27 Fixed 130| 140| 120 3 2.7 120 150 40 1 -10.82 mV/Deg C Undefined 5.5 18 -| Undefined 0.04   Yes Yes LM27
    LM88 LM88 Fixed 80 3 2.8 -40 85 1500 3 Digital Output 2 3.8 - - 1.5       LM88
    LM56 LM56 Resistor Selectable   3| 2 2.7 -40 125 230 2 6.2 mV/Deg C Undefined 10 1500 1.25 0.23     Yes LM56
    LM77 LM77       3 -55 125       - 5.5     0.5   Yes   LM77
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
