龙人旗下深圳市龙芯世纪科技有限公司
  • 升降压稳压器Buck-Boost Regulators
  • 发布时间:2009/2/28 10:29:27   修改时间:2009/2/28 10:29:27 浏览次数:3640
  • 首页NS国半电源管理
    电源管理器件 - - 升降压稳压器
    Buck-Boost Inductive Regulators(8)
    Base Part Number 数据手册DataSheet下载 Switch Current Output Min Output Max Output Range Input Min Voltage Input Max Voltage Frequency Min Frequency Max Efficiency (peak) Sync Pin Adj Switch Frequency On/Off Pin Error Flag SoftStart Special Features PWM Mode Topology Step-Up Inverting Flyback RegType Adjustable Output Output Power Temperature Min Temperature Max Feedback Voltage AEC Q-100 Automotive Grade Automotive Selection Guide PowerWise Quiescent Current 数据手册DataSheet下载
    LM3668 LM3668 1000| 1 3| 2.8 5| 3.3 | 2.8/3.3 2.5 5.5 1600 2700 93 Yes Yes| No Yes No Yes Buck-Boost| Aut | Auto PFM-PWM & Forced PWM | Buck-Boost| Voltage Mode | Yes     Switching Regulator| LDO | Yes| No   | -40 | 85 | null Undefined | null Yes| null   LM3668
    LM78S40 LM78S40 1.5 1.245 Undefined 1.245V min 2.5 40 0.1 100 - No Yes No No No Integrated 1.5A diode, uncommitted op amp Voltage Buck, Boost, Flyback, Inverting Yes Yes Yes Switching Regulator Yes -| Undefined -55 125 1.245 Undefined | null | null   LM78S40
    LM5015 LM5015 1.2 Undefined Undefined Undefined 4.25 75 25 750 87 Yes Yes Yes No Yes   Current Mode Two-Switch Forward Yes Yes Yes Switching Regulator Yes Undefined -40 125           LM5015
    LM5001 LM5001 1 Undefined Undefined Undefined 3.1 75 50 1500 96 Yes Yes Yes No No   Current Mode Boost, Flyback, Forward, SEPIC Yes No Yes Switching Regulator Yes Undefined -40 125 1.26   Yes     LM5001
    LM2611 LM2611 0.9| 1.2 -1.23 Undefined -1.23V to -(36-Vinmax)V 2.7 14 1400 1400 80 No No Yes No No   CUK Inverting No Yes No Switching Regulator Yes 2 -40 125           LM2611
    LM2578A LM2578A 0.75     Undefined 2 40 1 100 Undefined No Yes No No No FB and NFB pins Voltage Buck, Boost, Flyback, Inverting Yes Yes Yes Switching Controller Yes   -40 125 1 Undefined     Undefined LM2578A
    LM3578A LM3578A 0.75 1 Undefined Undefined Undefined 40 1 100 - No Yes No No No FB and NFB pins Voltage Buck, Boost, Flyback, Inverting Yes Yes Yes Switching Regulator Yes Undefined 0 125 1 Undefined       LM3578A
    LM5002 LM5002 0.5 Undefined Undefined Undefined 3.1 75 50 1500 95 Yes Yes Yes No No   Current Mode Boost, Flyback, Forward, SEPIC Yes No Yes Switching Regulator Yes Undefined -40 125 1.26   Yes     LM5002
    Buck-Boost Switched Capacitor Regulators(4)
    Base Part Number 数据手册DataSheet下载 Output Current Output Min Output Max Input Min Voltage Input Max Voltage Frequency Max Efficiency (peak) Adjustable Output Frequency Min Adj Switch Frequency On/Off Pin Quiescent Current Special Features PWM Mode Topology Step-Down Step-Up Inverting RegType Temperature Min Temperature Max PowerWise 数据手册DataSheet下载
    LM2758 LM2758 700 2.7 5.3 2.7 5.5 1500 90 Yes 800 No Yes 0.7 Flash LED Driver   Charge pump No Yes No Switched Cap Regulator -40 85 Yes LM2758
    LM3352 LM3352 200 3.0| 2.5| 3.3 3.0| 2.5| 3.3 2.5 5.5 1000 80 No 1000 No Yes 0.4 Auto buck/boost multi-gain architecture Multi-gain Switched Capacitor Boost, Buck Yes Yes No Switched Cap Regulator -40 85   LM3352
    LM3354 LM3354 90 5.0| 4.1| 1.8| 3.3 5.0| 4.1| 1.8| 3.3 2.5 5.5 1000 75 No 1000 No Yes 0.375 Auto buck/boost multi-gain architecture Multi-gain Switched Capacitor Boost, Buck Yes Yes No Switched Cap Regulator -40 85   LM3354
    LM3355 LM3355 50 4.1 4.1 2.5 5.5 1000 75 No 1000 No Yes 0.375 Auto buck/boost multi-gain architecture Multi-gain Switched Capacitor Boost, Buck Yes Yes No Switched Cap Regulator -40 85   LM3355
    Buck-Boost Switching Controllers(9)
    Base Part Number 数据手册DataSheet下载 Input Max Voltage Input Min Voltage Adjustable Output Feedback Voltage Output Range Frequency Min Frequency Max Efficiency (peak) Adj Switch Frequency Sync Pin On/Off Pin SoftStart Error Flag Special Features Output Power Topology Output Max Output Min AEC Q-100 Automotive Grade Output Current Step-Down Step-Up Inverting Flyback RegType Multiple Output Capability Temperature Min Temperature Max PowerWise Quiescent Current 数据手册DataSheet下载
    LM5020 LM5020 100 13 Yes 1.25 Undefined 50 1000 85 Yes Yes Yes Yes No 80% and 50% duty cycle limit (-2 and -1 versions), Programmable UVLO, error amplifier for non-isolated designs, leading-edge blanking, high current gate drive 300 Flyback, Inverting, Buck, Boost, Forward Undefined 1.25   - Yes Yes Yes Yes Switching Controller Yes -40 125 Yes   LM5020
    LM5118 LM5118 75 3 Yes 1.23 1.23V-70V 50 500 95 Yes Yes Yes Yes No soft mode transition Undefined buck-boost 70 1.23   Undefined Yes Yes No No Switching Controller No -40 125 Yes   LM5118
    LM5022 LM5022 60 6 Yes 1.25   50 2000 90 Yes Yes Yes Yes| null No     Boost, Sepic         No Yes No No Switching Controller No -40 125 Yes   LM5022
    LM3481 LM3481 48 2.97 Yes 1.275 1.275V min 100 1000 Undefined Yes Yes Yes Yes No Adjustable UVLO Undefined Boost, SEPIC, Flyback       Undefined No Yes No Yes Switching Controller Yes -40 125     LM3481
    LM2524D LM2524D 40 5 Yes Undefined - 0.001 550 - Yes Yes Yes Yes No Dual bipolar (C, E) outputs - Buck, Boost, Flyback, Push-pull       200 Yes Yes Yes Yes Switching Regulator Yes -40 125     LM2524D
    LM3478 LM3478 40 2.95 Yes 1.26 1.26V min 100 1000 - Yes Yes Yes Yes No   - Boost, Sepic, Flyback   1.26 Undefined - No Yes No Yes Switching Controller Yes -40 125     LM3478
    LM3488 LM3488 40 2.95 Yes 1.26 1.26V min 100 1000 - Yes Yes Yes Yes No   - Boost, Sepic, Flyback     Undefined - No Yes No Yes Switching Regulator Yes -40 125     LM3488
    LM3578A LM3578A 40 Undefined Yes 1 Undefined 1 100 - Yes No No No No FB and NFB pins Undefined Buck, Boost, Flyback, Inverting Undefined 1 Undefined 750 Yes Yes Yes Yes Switching Regulator No 0 125     LM3578A
    LM5021 LM5021 30 8 Yes Undefined set by external feedback network 50 1000 Undefined Yes Yes Yes Yes No For offline (AC-DC) applications, direct opto-coupler interface Undefined Flyback, Forward       Undefined Yes Yes Yes Yes Switching Controller Yes -40 125     LM5021
    电源管理技术支持
    • Excel 文档格式下载 Excel 文档格式选型指南下载 - 升降压、反向Buck-Boost, Invert
    模拟产品选择及设计指引
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
