龙人旗下深圳市龙芯世纪科技有限公司
  • 照明系统控制单元(LMU) LED照明
  • 发布时间:2009/2/28 10:39:52   修改时间:2009/2/28 10:39:52 浏览次数:3080
  • 首页NS国半方案应用LED照明
    LED照明
    高亮度LED 驱动器(18)
    Base Part Number 数据手册DataSheet下载 Regulated LEDs LED Configuration Current Matching Boost Type Switching Frequency Switching Type Total LED Current Efficiency (peak) PowerWise Technology Boost Voltage Supply Current Input Min Voltage Input Max Voltage OutputMax Voltage PWM BrightCtrl Analog-V BrightCtrl Ambient Light Compensation RGB-LED Temperature Min Temperature Max RegType AEC Q-100 Automotive Grade Automotive Selection Guide PowerWise 数据手册DataSheet下载
    LP5522 LP5522 1 Undefined Undefined Undefined Undefined Undefined 20 Undefined Programmable Stored Blinking Sequence Undefined 0.04 2.7 5.5 Undefined Yes No No No -30 85 Undefined   Yes Yes LP5522
    LM4970 LM4970 3 Parallel 0.30% Inductive 0.6 Fixed Freq Undefined Undefined Audio Adaptive RGB LED Driver Regulated 2.2 2.7 5.5 Undefined Yes No No Yes -40 85 Lighting Management Unit     Yes LM4970
    LP5521 LP5521 3 Parallel 1% Switched Capacitor Multi-Gain 1250 Fixed Freq 75 95 Adaptive Charge Pump Regulated Undefined 2.7 5.5 4.5 Yes No No Yes -30 85 Lighting Management Unit   Yes Yes LP5521
    LP5524 LP5524 4 Parallel 0.50% Undefined Undefined Undefined 100 Undefined   Undefined Undefined 2.7 5.5 Undefined Yes No No No -40 85 Lighting Management Unit     No LP5524
    LP3958 LP3958 5 Series Perfect Inductive 1000 PWM 96 90 Automatic Dimming Control Regulated 800 3 5.5 18 Yes No No Yes -30 85 Lighting Management Unit     Yes LP3958
    LP5526 LP5526 5 Series Perfect Inductive 1000 PWM 201 88 Programmable RGB Driver Regulated 1500 3 5.5 20 Yes No No Yes -30 85 null| Lighting Management Unit   Yes Yes| null LP5526
    LP5527 LP5527 5 Parallel 1% Inductive 2000 PWM 460 90 Audio Adaptive RGB LED Driver Regulated 1300 3 5.5 5 No No No No -30 85 Lighting Management Unit     Yes LP5527
    LP55271 LP55271 5 Parallel 1% Inductive 2000 PWM 430 90 Audio Adaptive RGB LED Driver Regulated 1400 3 5.5 5.4 No No No No -30 85 Lighting Management Unit     Yes LP55271
    LP3936 LP3936 6 Parallel 0.50% Inductive 1000 PWM 250 90 Programmable RGB Driver Regulated 1 3 6 5.3 Yes No Yes Yes -40 85 Lighting Management Unit     Yes LP3936
    LP3950 LP3950 6 Parallel - Inductive 2000 PWM 300 90 Audio Adaptive RGB LED Driver Regulated 1 3 7.2 5.3 Yes No No Yes -40 85 Lighting Management Unit     Yes LP3950
    LP3952 LP3952 6 Parallel 5% Inductive 2000 PWM 300 90 Audio Adaptive RGB LED Driver Regulated Undefined 3 7.2 5.3 Yes Yes No Yes -30 85 Lighting Management Unit     Yes LP3952
    LP3944 LP3944 8 Parallel 0.30% Inductive Undefined Fixed Freq Undefined Undefined   Regulated Undefined 2.3 5.5 Undefined Yes No No Yes -40 85 Lighting Management Unit     Yes LP3944
    LP8501 LP8501 9 Parallel 1% Switched Capacitor Multi-Gain 1250 Fixed Freq 225 95 Adaptive Charge Pump Regulated Undefined 2.7 5.5 4.5 Yes No No Yes -30 85 Lighting Management Unit Undefined Undefined Yes LP8501
    LP5520 LP5520 12 Series 0.20% Inductive 1000 Fixed Freq 180 87 Temperature Compensated RGB Driver Regulated 1.4 2.9 5.5 20 Yes Yes Yes Yes -30 85 Lighting Management Unit     Yes LP5520
    LP55281 LP55281 12 Parallel 5% Inductive 2000 PWM 400 88 Audio Adaptive RGB LED Driver Regulated 1 3 5.5 5.3 Yes No No Yes -30 85 Lighting Management Unit     Yes LP55281
    LP3954 LP3954 13 Parallel 0.20% Inductive 2000 PWM 300 90 Audio Adaptive RGB LED Driver Regulated 1 3 7.2 5.3 Yes Yes Yes Yes -30 85 Lighting Management Unit     Yes LP3954
    LP39542 LP39542 13 Parallel 0.20% Inductive 2000 PWM 400 90 Audio Adaptive RGB LED Driver Regulated Undefined 3 7.2 5.3 Yes Yes Yes Yes -30 85 Lighting Management Unit     Yes LP39542
    LP3943 LP3943 16 Parallel 0.30% Inductive Undefined Fixed Freq Undefined Undefined   Regulated Undefined 2.3 5.5 Undefined Yes No No Yes -40 85 Lighting Management Unit     Yes LP3943
    电源管理技术支持
    • Excel 文档格式下载 Excel 文档格式选型指南下载 - LED照明LED Lighting
    模拟产品选择及设计指引
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
