龙人旗下深圳市龙芯世纪科技有限公司
  • 电源管理器件 - 线性/低压降(LDO)稳压器
  • 发布时间:2009/2/28 10:42:56   修改时间:2009/2/28 10:42:56 浏览次数:2733
  • 首页NS国半电源管理
    Low-Noise Low Dropout(22)
    Base Part Number 数据手册DataSheet下载 Output Current Output Min Input Min Voltage Input Max Voltage Dropout Voltage Adjustable Output Quiescent Current PSRR Voltage Noise (rms) PowerWise Rating 5 Feedback Tolerance Ceramic Capacitors Stable On/Off Pin Error Flag RegType Temperature Min Temperature Max Special Features Output Voltage Output Max Feedback Voltage AEC Q-100 Automotive Grade Automotive Selection Guide PowerWise 数据手册DataSheet下载
    LP38501-ADJ LP38501-ADJ 3000 0.6 2.7 5.5 0.42 Yes 0.000025 58 100 0.03 3.5 Yes Yes No LDO -40 125 FlexCap LDO Undefined 5 0.6 Undefined     LP38501-ADJ
    LP38503-ADJ LP38503-ADJ 3000 0.6 2.7 5.5 0.42 Yes 0.000025 58 100 0.03 3.5 Yes No No LDO -40 125 FlexCap LDO Undefined 5 0.6 Undefined     LP38503-ADJ
    LP38500-ADJ LP38500-ADJ 1500 0.6 2.7 5.5 0.22 Yes 0.000025 58 100 0.07 3.5 Yes No No LDO -40 125 Flexcap LDO Undefined 5.1 0.6       LP38500-ADJ
    LP38502-ADJ LP38502-ADJ 1500 0.6 2.7 5.5 0.22 Yes 0.000025 58 100 0.07 3.5 Yes Yes No LDO -40 125 Flexcap LDO Undefined 5.1 0.6 Undefined     LP38502-ADJ
    LP38512 LP38512 1500 1.755 2.25 5.5 Undefined No 14 73 Undefined 0.05 Undefined Yes Yes Yes LDO -40 125 Undefined 1.8 1.845 Undefined       LP38512
    LP38690 LP38690 1000 1.8| 3.3 2.75| 3.95 10 0.95| 0.65 No 0.055 55 70 0.07 2.5 Yes No No LDO -40 125   1.8| 3.3 1.8| 3.3     Undefined Yes LP38690
    LP38690-ADJ LP38690-ADJ 1000 1.25 2.7 10 0.65 Yes 0.055 55 70 0.07 2.5 Yes No No LDO -40 125 Undefined Undefined 9 1.25   Yes Yes LP38690-ADJ
    LP38692 LP38692 1000 5.0| 3.3 5.45| 3.75 10 0.2 No 0.055 55 70 0.07 2.5 Yes Yes No LDO -40 125   5.0| 3.3 5.0| 3.3 Undefined Undefined Undefined Yes LP38692
    LP38511 LP38511 800 1.755 2.25 5.5 Undefined No 14 73 Undefined 0.09 Undefined Yes Yes Yes LDO -40 125 Undefined 1.8 1.845 Undefined       LP38511
    LP3878-ADJ LP3878-ADJ 800 1 2.5 16 0.475 Yes 0.18 60 18 0.02     Yes No LDO -40 125   Undefined 5.5         LP3878-ADJ
    LP3879 LP3879 800 1.2| 1 2.5 6 Undefined No 0.1 60 18 0.02     Yes No LDO -40 125   1.2| 1 1.2| 1         LP3879
    LP5952 LP5952 350 2.0| 1.6| 1.5| 0.7| 1.8| 1.3| 1.0| 1.2| 1.4 2.2| 1.8| 1.7| 1.4| 1.55| 1.5| 1.6| 2.0| 0.9| 1.75| 1.45| 2.05| 1.2 4.5 0.088| 0.128 No 0.011 95 100 0.29   Yes Yes No Linear Regulator -40 125 Dual Rail 2.0| 1.6| 1.5| 0.7| 1.8| 1.3| 1.0|  1.2| 1.2| 1.4 2.0| 1.6| 1.5| 0.7| 1.8| 1.3| 1.0|  1.2| 1.2| 1.4       Yes LP5952
    LP2992 LP2992 250 1.5| 5| 1.8| 2.5| 3.3 2.5 16 0.45 No 0.065 46 30 0.12     Yes No LDO -40 125   1.5| 5| 1.8| 2.5| 3.3 1.5| 5| 1.8| 2.5| 3.3         LP2992
    LP2988 LP2988 200 3.8| 3| 2.7| 5| 3.2| 2.8| 3.3 3.98| 2.1| 2.98 16 0.18 No 0.1 65 20 0.1     Yes Yes LDO -40 125   3.8| 3| 2.7| 5| 3.2| 2.8| 3.3 3.8| 3| 2.7| 5| 3.2| 2.8| 3.3         LP2988
    LP2985 LP2985 150 3| 3.6| 3.2| 2.5| 6.1| 2.9| 2.6| 3.3| 3.8| 2.4| 5| 2.7| 3.1| 4.5| 4| 2.8 2.5 16 0.28 No 0.065 45 30 null| 0.2 | null | null Yes No LDO -40 125   3| 3.6| 3.2| 2.5| 6.1| 2.9| 2.6| 3.3| 3.8| 2.4| 5| 2.7| 3.1| 4.5| 4| 2.8 3| 3.6| 3.2| 2.5| 6.1| 2.9| 2.6| 3.3| 3.8| 2.4| 5| 2.7| 3.1| 4.5| 4| 2.8 | null null| 0 | null   LP2985
    LP2985LV LP2985LV 150 3.0| 2.85| 3.3 2.2 16 0.28 null| No 0.065 45 30 0.2     Yes No LDO -40 125 null| 3.0| 2.85| 3.3 3.0| 2.85| 3.3   Undefined     LP2985LV
    LP3985 LP3985 150 4.7| 3| 5| 2.7| 3.2| 2.5| 3.1| 2.9| 2.8| 2.6| 3.3 2.5 6 0.06 No 0.085 50 30 0.2     Yes No LDO -40 125   4.7| 3| 5| 2.7| 3.2| 2.5| 3.1| 2.9| 2.8| 2.6| 3.3 4.7| 3| 5| 2.7| 3.2| 2.5| 3.1| 2.9| 2.8| 2.6| 3.3         LP3985
    LP3995 LP3995 150 3| 2.8| 1.9 2.7| 2.5| 3.1| 2.9 6 -| 0.06 No 0.085 60 25 0.17 | null Yes| null Yes No LDO -40 125   3| 2.8| 1.9 3| 2.8| 1.9 | null       LP3995
    LP3999 LP3999 150 1.5| 2.4| 1.8| 2.5| 2.8| 3.3 2.5 6 -| 0.06 No 0.085 60 30 0.2     Yes No LDO -40 125   1.5| 2.4| 1.8| 2.5| 2.8| 3.3 1.5| 2.4| 1.8| 2.5| 2.8| 3.3         LP3999
    LP5900 LP5900 150 1.5| 2.8| 3.3 2.5 5.5 0.08 No 0.025 75 6.5 0.07     Yes No LDO -40 125   1.5| 2.8| 3.3 1.5| 2.8| 3.3       Yes LP5900
    LP5951 LP5951 150 2.0| 1.5| 3.0| 1.8| 1.3| 2.5| 2.8| 3.3 1.8 5.5 0.2 No 0.029 60 125 0.29   Yes Yes No LDO -40 125   2.0| 1.5| 3.0| 1.8| 1.3| 2.5| 2.8| 3.3 2.0| 1.5| 3.0| 1.8| 1.3| 2.5| 2.8| 3.3         LP5951
    LP2982 LP2982 50 3.8| 4.7| 3| 5| 3.6| 5.3| 2.5| 4.5| 4| 2.8| 2.6| 3.3 5.42| 2.72| 4.62| 2.92| 5.12| 4.82| 2.62| 3.42| 3.12| 4.12| 3.72 16 0.12 No 0.065 45 30 0.6     Yes No LDO -40 125   3.8| 4.7| 3| 5| 3.6| 5.3| 2.5| 4.5| 4| 2.8| 2.6| 3.3 3.8| 4.7| 3| 5| 3.6| 5.3| 2.5| 4.5| 4| 2.8| 2.6| 3.3         LP2982
    Positive Low Dropout (VinMax >25V)(28)
    Base Part Number 数据手册DataSheet下载 Output Current Output Min Input Min Voltage Input Max Voltage Dropout Voltage Adjustable Output Quiescent Current PSRR Voltage Noise (rms) Ceramic Capacitors Stable Feedback Tolerance On/Off Pin Error Flag RegType Temperature Min Temperature Max Output Max Output Voltage Special Features Feedback Voltage AEC Q-100 Automotive Grade Automotive Selection Guide PowerWise 数据手册DataSheet下载
    LM1084 LM1084 5000 1.25| 5| 3.3 2.6 29| 27| 25 1.3 No 5         No No LDO -40 125 27.5| 5| 3.3 | 5| 3.3           LM1084
    LM1085 LM1085 3000 1.25| 5| 3.3 2.6 29| 27| 25 1.3 No 5         No No LDO -40 125 27.5| 5| 3.3 | 5| 3.3           LM1085
    LM1086 LM1086 1500 1.25| 5| 2.5| 3.3 2.6 29| 30| 27| 25 1.3 No 5| 2         No No LDO -40 125 27.5| 5| 2.5| 3.3 | 5| 2.5| 3.3           LM1086
    LM2940 LM2940 1000 10| 5| 9| 8| 12 - 26 0.5 No 10         No No LDO -55 125 10| 5| 9| 8| 12 10| 5| 9| 8| 12           LM2940
    LM2940C LM2940C 1000 5| 9| 15| 12 - 26 0.5 No 10         No No LDO -55 125 5| 9| 15| 12 5| 9| 15| 12           LM2940C
    LM2941 LM2941 1000 5 -15 26 0.5 Yes 10         Yes No LDO -55 125 20 | null | null 1.275       LM2941
    LM2941C LM2941C 1000 5 -15 26 0.5 Yes 10         Yes No LDO -55 125 20     1.275       LM2941C
    LM2937 LM2937 500 10| 5| 15| 8| 12 - 26 0.5 No 2         No No LDO -40 125 10| 5| 15| 8| 12 10| 5| 15| 8| 12           LM2937
    LM2937-3.3 LM2937-3.3 500| 400 3.3 4.75 26 - No 2         No No LDO -40 85| 125 3.3 3.3           LM2937-3.3
    LM2937-2.5 LM2937-2.5 400 2.5 4.75 26 - No 2         No No LDO -40 85 2.5 2.5           LM2937-2.5
    LM9070 LM9070 250 5 5.3 26 0.8 No 4         Yes Yes LDO -40 125 5 5       Yes   LM9070
    LM9071 LM9071 250 5 5.3 26 0.8 No 4         No Yes LDO -40 125 5 5       Yes   LM9071
    LP2952 LP2952 250 1.23| 3.3 -20 30 0.47 Yes| No 0.13         Yes Yes LDO -40 125 29| 3.3 | 3.3       Yes   LP2952
    LP2953 LP2953 250 1.23| 3.3 -20 30 0.47 Yes| No 0.13         Yes Yes LDO -40 125 29| 3.3 | 3.3       Yes   LP2953
    LP2953A LP2953A 250 1.23 -20 30 0.47   0.13         Yes Yes LDO -40 125 29             LP2953A
    LP2954 LP2954 250 1.23 -20 30 0.8 Yes 0.21         Yes Yes LDO -40 125 29         Yes   LP2954
    LP2954A LP2954A 250 1.23 -20 30 0.8 Yes 0.21         Yes Yes LDO -40 125 29             LP2954A
    LP2957 LP2957 250 5 -20 30 0.47 No 0.15         Yes Yes LDO -40 125 5 5       Yes   LP2957
    LM2930 LM2930 150 5 Undefined 26 0.32 No 4         No No LDO -40 85 5 5           LM2930
    LM330 LM330 150 5 - 26 0.32 No 18         No No LDO 0 70 5 5           LM330
    LM9076 LM9076 150 5| 3.3 5.4| 3.65 40 0.25 No 4.5         Yes| No Yes LDO -40 125 5| 3.3 5| 3.3       Yes   LM9076
    LM2931 LM2931 100 3| 5 - 26 0.3 No 0.4         Yes| No No LDO -40 85 5| 24 | 5           LM2931
    LM3480 LM3480 100 5| 15| 12| 3.3 - 30   No           No No QuasiLDO -40 125 5| 15| 12| 3.3 5| 15| 12| 3.3           LM3480
    LP2950 LP2950 100 3| 5| 3.3 - 30 | 0.38 No | 0.075         No No LDO -40 125 3| 5| 3.3 3| 5| 3.3           LP2950
    LP2951 LP2951 100 3| 1.24| 3.3 -0.3 30 0.38 Yes| No| null 0.075         Yes Yes LDO -40 125 3| 29| 3.3 | 3| null| 3.3 | null         LP2951
    LP4951C LP4951C 100 1.24 2.43 30 0.43 Yes 15         Yes Yes LDO -40 125 29             LP4951C
    LM2936 LM2936 50 3| 5| 3.3 5.5| 4.0 60 0.2 No 0.009| 0.016| 0.015         Yes No LDO -40 125 3| 5| 3.3 3| 5| 3.3       Yes   LM2936
    LM9036 LM9036 50 4.75| 3.135 -45 40 0.4 No 2.5 -40 Undefined No Undefined No No LDO -40 125 3.465| 5.25 5.0| 3.3 Undefined Undefined Undefined Yes Undefined LM9036
    Positive NPN Standard(25)
    Base Part Number 数据手册DataSheet下载 Output Current Output Voltage Input Min Voltage Input Max Voltage Adjustable Output On/Off Pin Error Flag Temperature Min Temperature Max Special Features RegType Feedback Voltage PowerWise Quiescent Current 数据手册DataSheet下载
    LM138 LM138 5000   4.2 40 Yes No No -55 150   Linear Regulator       LM138
    LM338 LM338 5000   4.2 40 Yes No No 0 125   Linear Regulator       LM338
    LM123 LM123 3000 5 7.5 20   No No -55 150   Linear Regulator       LM123
    LM150 LM150 3000   4.2 35 Yes No No -55 150   Linear Regulator       LM150
    LM323 LM323 3000 5 7.5 20   No No 0 125   Linear Regulator       LM323
    LM350 LM350 3000   4.2 35 Yes No No 0 125   Linear Regulator       LM350
    LM317HV LM317HV 1500   4.2 60 Yes No No 0 125   Linear Regulator       LM317HV
    LM109 LM109 1000 5.05 7.1 35 No No No -55 150   Linear Regulator       LM109
    LM309 LM309 1000 5.05 7.1 35 No No No 0 125   Linear Regulator       LM309
    LM317 LM317 1000| 500| 1500   4.2 37| 40 Yes No No 0| -40 125   Linear Regulator       LM317
    LM340 LM340 1000 5| 15| 7.5| 12 14.8| 17.9| 7.5 35 No No No 0 70   Linear Regulator       LM340
    LM117 LM117 500| 1500 Undefined 4.2 40 Yes No No -55 150| 125   Linear Regulator       LM117
    LM117HV LM117HV 500| 1500   4.2 60 Yes No No -55 125   Linear Regulator       LM117HV
    LM341 LM341 500 5 7.5 35 No No No -40 125   Linear Regulator       LM341
    LM78M05 LM78M05 500 5 7.2 35 No No No -40 125   Linear Regulator       LM78M05
    LM9074 LM9074 180 5 7.5 40 No Yes Yes -40 125   Linear Regulator       LM9074
    LM723 LM723 150 Undefined 9.5 40 Yes No No -55 150   Linear Regulator       LM723
    LM723C LM723C 150 | Undefined 9.5 40 Yes No No 0 70   Linear Regulator       LM723C
    LM140L LM140L 100 5| 15| 12 7.2| 17.5| 14.3 35 No No No -55 125   Linear Regulator       LM140L
    LM317L LM317L 100   4.2 40 Yes No No -40 125   Linear Regulator       LM317L
    LM340L LM340L 100 5 7 35 No No No 0 70   Linear Regulator       LM340L
    LM78L05 LM78L05 100 | 5 7| 6.7 35 No No No -55| -40 85| 125   Linear Regulator       LM78L05
    LM78L12 LM78L12 100 12 13.7 35 No No No -40 85   Linear Regulator       LM78L12
    LM78L15 LM78L15 100 15 16.7 35 No No No -40 85   Linear Regulator       LM78L15
    LM78L62 LM78L62 100 6.2 7.6 35 No No No -40 85   Linear Regulator       LM78L62
    Negative Low Dropout(2)
    Base Part Number 数据手册DataSheet下载 Output Current Output Min Input Min Voltage Input Max Voltage Dropout Voltage Adjustable Output Quiescent Current On/Off Pin Error Flag RegType Temperature Min Temperature Max Output Max Output Voltage Special Features Feedback Voltage PowerWise 数据手册DataSheet下载
    LM2990 LM2990 1500 -5| -12| -15 -26 0.3 0.6 No 1 No No LDO -40 125 -5| -12| -15 -5| -12| -15       LM2990
    LM2991 LM2991 1000 -24 -26 0.3 0.6 Yes 1 Yes No LDO -40 125 -3 Undefined       LM2991
    Negative Standard Linear(9)
    Base Part Number 数据手册DataSheet下载 Output Current Output Min Input Min Voltage Input Max Voltage Adjustable Output Quiescent Current On/Off Pin Error Flag RegType Temperature Min Temperature Max Output Max Output Voltage Special Features Feedback Voltage PowerWise 数据手册DataSheet下载
    LM120 LM120 1500   -25 -| -8| -18| -15 No   No No Linear Regulator -55 150   -| -5| -12| -15       LM120
    LM137 LM137 1500 -37 -40 -4.2 Yes   No No Linear Regulator -55 150 -1.2 Undefined       LM137
    LM137HV LM137HV 1500 -47 -50 -4.2 Yes   No No Linear Regulator -55 150 -1.2 Undefined       LM137HV
    LM337 LM337 1500 -37 -50 -4.2 Yes   No No Linear Regulator -40 125 -1.2 Undefined       LM337
    LM7905 LM7905 1500 -5 -25 -7 No   No No Linear Regulator 0 125 -5 -5       LM7905
    LM7912 LM7912 1500 -12 -35 -14.5 No   No No Linear Regulator 0 125 -12 -12       LM7912
    LM7915 LM7915 1500 -15 -35 -17.5 No   No No Linear Regulator 0 125 -15 -15       LM7915
    LM337L LM337L 100 -37 -40 -4.2 Yes   No No Linear Regulator -25 100 -1.2 Undefined       LM337L
    LM79L05 LM79L05 100 -5 -20 -7 No   No No Linear Regulator 0 70 -5 -5       LM79L05
    电源管理技术支持
    • Excel 文档格式下载 Excel 文档格式选型指南下载 - 线性/低压降(LDO)稳压器Linear/LDO Regulators
    模拟产品选择及设计指引
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
