龙人旗下深圳市龙芯世纪科技有限公司
  • 线性/低压降(LDO)稳压器Positive Low Dropout (VinMax < 25V)
  • 发布时间:2009/2/28 10:44:00   修改时间:2009/2/28 10:44:00 浏览次数:3190
  • 首页NS国半电源管理
    电源管理器件 - 线性/低压降(LDO)稳压器
    Positive Low Dropout (VinMax < 25V)(92)
    Base Part Number 数据手册DataSheet下载 Output Current Output Min Input Min Voltage Input Max Voltage Dropout Voltage Adjustable Output Quiescent Current PSRR Voltage Noise (rms) Ceramic Capacitors Stable Feedback Tolerance On/Off Pin Error Flag RegType Temperature Min Temperature Max Special Features Output Voltage Output Max Feedback Voltage AEC Q-100 Automotive Grade Automotive Selection Guide PowerWise 数据手册DataSheet下载
    LP2975 LP2975 Undefined 5| 12 1.8 24 Undefined No 0.18         Yes No LDO -40 125   5| 12 5| 12         LP2975
    LMS1585A LMS1585A 5000 1.25| 3.3 2.5 13 1.2 Yes| No 7         No No LDO 0 125   Undefined| 3.3 5.75| 3.3         LMS1585A
    LMS1587 LMS1587 3000 1.25| 1.5| 3.3 2.4| 2.5 13 1.15 Yes| No 7         No No LDO -40| 0 125   1.5| Undefined| 3.3 1.5| 5.75| 3.3         LMS1587
    LP38501-ADJ LP38501-ADJ 3000 0.6 2.7 5.5 0.42 Yes 0.000025 58 100 Yes 3.5 Yes No LDO -40 125 FlexCap LDO Undefined 5 0.6 Undefined     LP38501-ADJ
    LP38503-ADJ LP38503-ADJ 3000 0.6 2.7 5.5 0.42 Yes 0.000025 58 100 Yes 3.5 No No LDO -40 125 FlexCap LDO Undefined 5 0.6 Undefined     LP38503-ADJ
    LP38513 LP38513 3000 1.764 2.25 5.5 0.45 No 20         Yes Yes LDO -40 125   1.8 1.836         LP38513
    LP3853 LP3853 3000 2.5 2.5 7 0.39 No 4         Yes Yes LDO -40 125   2.5 2.5         LP3853
    LP3856 LP3856 3000 1.8| 2.5| 3.3 2.5 7 0.39 No 4         Yes No LDO -40 125   1.8| 2.5| 3.3 1.8| 2.5| 3.3         LP3856
    LP3876 LP3876 3000 2.5 2.5 7 0.8 No 6         Yes No LDO -40 125   2.5 2.5         LP3876
    LP3876-ADJ LP3876-ADJ 3000 1.216 2.5 7 0.8 Yes 6         Yes No LDO -40 125     6.2         LP3876-ADJ
    LP3883 LP3883 3000 1.2 1.41 5.5 0.21 No 0.00006         Yes No LDO -40 125   1.2 1.2         LP3883
    LP38853 LP38853 3000 0.8 Undefined 5.5 0.45 Yes 13.5         Yes No LDO -40 125 Dual Rail, Soft-Start Undefined 1.8       Yes LP38853
    LP38856 LP38856 3000 0.8| 1.2 1.55| 1.15 5.5 0.35 No 22         Yes No LDO -40 125   0.8| 1.2 0.8| 1.2       Yes LP38856
    LP38859 LP38859 3000 0.8| 1.2 1.55| 1.15 5.5 0.35 No 20         No No LDO -40 125   0.8| 1.2 0.8| 1.2       Yes LP38859
    LP3963 LP3963 3000 2.5| 3.3 2.5 7 0.8 No 5         Yes Yes LDO -40 125   2.5| 3.3 2.5| 3.3         LP3963
    LP3966 LP3966 3000 1.8| 2.5| 1.215| 3.3 2.5 7 0.8 Yes| No 5         Yes No LDO -40 125   1.8| Undefined| 2.5| 3.3 5| 1.8| 2.5| 3.3         LP3966
    LP38500-ADJ LP38500-ADJ 1500 0.6 2.7 5.5 0.22 Yes 0.000025 58 100 Yes 3.5 No No LDO -40 125 Flexcap LDO Undefined 5.1 0.6       LP38500-ADJ
    LP38502-ADJ LP38502-ADJ 1500 0.6 2.7 5.5 0.22 Yes 0.000025 58 100 Yes 3.5 Yes No LDO -40 125 Flexcap LDO Undefined 5.1 0.6 Undefined     LP38502-ADJ
    LP38512 LP38512 1500 1.755 2.25 5.5 Undefined No 14 73 Undefined Yes Undefined Yes Yes LDO -40 125 Undefined 1.8 1.845 Undefined       LP38512
    LP3852 LP3852 1500 2.5 2.5 7 0.24 No 4         Yes Yes LDO -40 125   2.5 2.5         LP3852
    LP3875 LP3875 1500 1.8| 2.5| 3.3 2.5 7 0.38 No 6         Yes No LDO -40 125   1.8| 2.5| 3.3 1.8| 2.5| 3.3         LP3875
    LP3875-ADJ LP3875-ADJ 1500 1.216 2.5 7 0.38 Yes 6         Yes No LDO -40 125     6.62         LP3875-ADJ
    LP3882 LP3882 1500 1.8 1.31 6 0.11 No 3         Yes No LDO -40 125   1.8 1.8         LP3882
    LP38842 LP38842 1500 1.2 1.315 5.5 0.115 No 32         No No LDO -40 125   1.2 1.2         LP38842
    LP38842-ADJ LP38842-ADJ 1500 0.56 4.5 5.5 0.115 Yes 32         No No LDO -40 125     1.5         LP38842-ADJ
    LP38852 LP38852 1500 0.8 Undefined 5.5 0.18 Yes 13.5         Yes No LDO -40 125 Dual Rail, Soft-Start Undefined 1.8       Yes LP38852
    LP38855 LP38855 1500 0.8| 1.2 1.38| 0.98 5.5 0.18 No 22         Yes No LDO -40 125   0.8| 1.2 0.8| 1.2       Yes LP38855
    LP38858 LP38858 1500 0.8| 1.2 1.38| 0.98 5.5 0.18 No 22         No No LDO -40 125   0.8| 1.2 0.8| 1.2       Yes LP38858
    LP3892 LP3892 1500 1.5| 1.2 1.64| 1.34 5.5 0.14 No 3         Yes No LDO -40 125   1.5| 1.2 1.5| 1.2         LP3892
    LP3962 LP3962 1500 1.8| 2.5| 3.3 2.5 7 0.38 No 4         Yes Yes LDO -40 125   1.8| 2.5| 3.3 1.8| 2.5| 3.3         LP3962
    LP3965 LP3965 1500 1.8| 2.5| 1.215| 3.3 2.5 7 0.38 Yes| No 4         Yes No LDO -40 125   | 1.8| 2.5| 3.3 5| 1.8| 2.5| 3.3         LP3965
    LM3940 LM3940 1000 3.3 - 7.5 0.31 No 0.11         No No LDO -40 125   3.3 3.3         LM3940
    LMS8117A LMS8117A 1000 1.5| 1.8| 3.3 2.5 15 1.2 Yes| No 5         No No LDO 0 125   1.8| Undefined| 3.3 1.8| 13.75| 3.3         LMS8117A
    LP38690 LP38690 1000 1.8| 3.3 2.75| 3.95 10 0.95| 0.65 No 0.055 55 70 Yes 2.5 No No LDO -40 125   1.8| 3.3 1.8| 3.3     Undefined Yes LP38690
    LP38690-ADJ LP38690-ADJ 1000 1.25 2.7 10 0.65 Yes 0.055 55 70 Yes 2.5 No No LDO -40 125 Undefined Undefined 9 1.25   Yes Yes LP38690-ADJ
    LP38692 LP38692 1000 5.0| 3.3 5.45| 3.75 10 0.2 No 0.055 55 70 Yes 2.5 Yes No LDO -40 125   5.0| 3.3 5.0| 3.3 Undefined Undefined Undefined Yes LP38692
    LP38692-ADJ LP38692-ADJ 1000 1.25 2.7 10 Undefined Yes 0.055         Yes No LDO -40 125   Undefined 9     Yes Yes LP38692-ADJ
    LP8340 LP8340 1000 1.25| 5| 2.5| 3.3 2.7 10 0.42| 0.54| 0.67 Yes| No 0.019         No No LDO 0 125   5| 2.5| Undefined| 3.3 9.3| 5| 2.5| 3.3         LP8340
    LM1117 LM1117 800 1.25| 5| 1.8| 2.5| 3.3 2.65| 2.6 15 1.2 Yes| No 5         No No LDO 0 125   5| 1.8| 2.5| Undefined| 3.3 5| 1.8| 2.5| 13.8| 3.3         LM1117
    LP38511 LP38511 800 1.755 2.25 5.5 Undefined No 14 73 Undefined Yes Undefined Yes Yes LDO -40 125 Undefined 1.8 1.845 Undefined       LP38511
    LP3871 LP3871 800 3.3 2.5 7 0.24 No 6         Yes Yes LDO -40 125   3.3 3.3         LP3871
    LP3874 LP3874 800 5| 1.8| 3.3 2.5 7 0.24 No 6         Yes No LDO -40 125   5| 1.8| 3.3 5| 1.8| 3.3         LP3874
    LP3874-ADJ LP3874-ADJ 800 1.216 2.5 7 0.24 Yes 6         Yes No LDO -40 125     6.76         LP3874-ADJ
    LP3878-ADJ LP3878-ADJ 800 1 2.5 16 0.475 Yes 0.18 60 18     Yes No LDO -40 125   Undefined 5.5         LP3878-ADJ
    LP3879 LP3879 800 1.2| 1 2.5 6 Undefined No 0.1 60 18     Yes No LDO -40 125   1.2| 1 1.2| 1         LP3879
    LP38841-ADJ LP38841-ADJ 800 0.56 4.5 5.5 0.075 Yes 32         No No LDO -40 125     1.5         LP38841-ADJ
    LP38851 LP38851 800 0.8 Undefined 5.5 0.2 Yes 13.5         Yes No LDO -40 125 Dual Rail, Soft-Start Undefined 1.8       Yes LP38851
    LP3891 LP3891 800 1.2 1.3 5.5 0.1 No 3         Yes No LDO -40 125   1.2 1.2         LP3891
    LP3961 LP3961 800 1.8| 2.5| 3.3 2.5 7 0.24 No -         Yes Yes LDO -40 125   1.8| 2.5| 3.3 1.8| 2.5| 3.3         LP3961
    LP3964 LP3964 800 2.5| 1.215| 3.3 2.5 7 0.24 Yes| No -| 3         Yes No LDO -40 125   | 2.5| 3.3 5| 2.5| 3.3         LP3964
    LP2989 LP2989 500 3| 5| 3.6| 4| 2.85| 2.8| 3.3 5.31| 3.11| 2.81| 3.61 16 0.31 No 0.11         Yes Yes LDO -40 125   3| 5| 3.6| 4| 2.85| 2.8| 3.3 3| 5| 3.6| 4| 2.85| 2.8| 3.3         LP2989
    LP2989LV LP2989LV 500 1.8 2.1 16 0.31 No 0.11         Yes Yes LDO -40 125   1.8 1.8         LP2989LV
    LP38691 LP38691 500 5| 1.8| 2.5| 3.3 3.73| 2.7| 2.93| 5.43 10 0.25| 0.33| Undefined| 0.43 No 0.055         No No LDO -40 125   5| 1.8| 2.5| 3.3 5| 1.8| 2.5| 3.3       Yes LP38691
    LP38691-ADJ LP38691-ADJ 500 1.25 2.7 10 Undefined Yes 0.055         No No LDO -40 125   Undefined 9     Yes Yes LP38691-ADJ
    LP38693 LP38693 500 5| 3.3 3.73| 5.43 10 0.25| 0.33 No 0.055         Yes No LDO -40 125   5| 3.3 5| 3.3       Yes LP38693
    LP38693-ADJ LP38693-ADJ 500 1.25 2.7 10 Undefined Yes 0.055         Yes No LDO -40 125   Undefined 9     Yes Yes LP38693-ADJ
    LP8345 LP8345 500 5| 1.8| 2.5| 3.3 2.7 10 0.27| 0.335| Undefined| 0.18| 0.21| 1.2 No 0.019         No No LDO 0 125   5| 1.8| 2.5| 3.3 5| 1.8| 2.5| 3.3         LP8345
    LP5952 LP5952 350 2.0| 1.6| 1.5| 0.7| 1.8| 1.3| 1.0| 1.2| 1.4 2.2| 1.8| 1.7| 1.4| 1.55| 1.5| 1.6| 2.0| 0.9| 1.75| 1.45| 2.05| 1.2 4.5 0.088| 0.128 No 0.011 95 100 Yes   Yes No Linear Regulator -40 125 Dual Rail 2.0| 1.6| 1.5| 0.7| 1.8| 1.3| 1.0|  1.2| 1.2| 1.4 2.0| 1.6| 1.5| 0.7| 1.8| 1.3| 1.0|  1.2| 1.2| 1.4       Yes LP5952
    LP3981 LP3981 300 2.83| 2.7| 2.5| 3.03| 2.8| 3.3 2.7 6 0.132 No 0.07         Yes No LDO -40 125   2.83| 2.7| 2.5| 3.03| 2.8| 3.3 2.83| 2.7| 2.5| 3.03| 2.8| 3.3         LP3981
    LP3982 LP3982 300 2.77| 1.25| 3| 1.8| 2.5| 2.82| 3.3 2.5 6 0.12 Yes| No 0.09| 0.095         Yes Yes LDO -40 85   2.77|  | 3| 1.8| 2.5| 2.82| 3.3 2.77| 3| 1.8| 2.5| 2.82| 6| 3.3         LP3982
    LP3991 LP3991 300 1.5| 1.3| 2.8| 1.2 1.65 3.6 0.075| Undefined No 0.05         Yes No LDO -40 125 Low Input Voltage 1.5| 1.3| 2.8| 1.2 1.5| 1.3| 2.8| 1.2       Yes LP3991
    LP2992 LP2992 250 1.5| 5| 1.8| 2.5| 3.3 2.5 16 0.45 No 0.065 46 30     Yes No LDO -40 125   1.5| 5| 1.8| 2.5| 3.3 1.5| 5| 1.8| 2.5| 3.3         LP2992
    LP2986 LP2986 200 3| 5| 3.3 2.1 16 0.18 No 0.1         Yes Yes LDO -40 125   3| 5| 3.3 3| 5| 3.3         LP2986
    LP2987 LP2987 200 3.8| 3| 5| 3.2| 2.8| 3.3 3.98| 3.38| 2.1| 2.98 16 0.18 No 0.1         Yes Yes LDO -40 125   3.8| 3| 5| 3.2| 2.8| 3.3 3.8| 3| 5| 3.2| 2.8| 3.3         LP2987
    LP2988 LP2988 200 3.8| 3| 2.7| 5| 3.2| 2.8| 3.3 3.98| 2.1| 2.98 16 0.18 No 0.1 65 20     Yes Yes LDO -40 125   3.8| 3| 2.7| 5| 3.2| 2.8| 3.3 3.8| 3| 2.7| 5| 3.2| 2.8| 3.3         LP2988
    LP2983 LP2983 150 0.9| 1.2| 1 2.2 16 1.3| 1| 1.2 No 0.065         Yes No LDO -40 125   0.9| 1.2| 1| 3.3 0.9| 1.2| 1         LP2983
    LP2985 LP2985 150 3| 3.6| 3.2| 2.5| 6.1| 2.9| 2.6| 3.3| 3.8| 2.4| 5| 2.7| 3.1| 4.5| 4| 2.8 2.5 16 0.28 No 0.065 45 30 | null | null Yes No LDO -40 125   3| 3.6| 3.2| 2.5| 6.1| 2.9| 2.6| 3.3| 3.8| 2.4| 5| 2.7| 3.1| 4.5| 4| 2.8 3| 3.6| 3.2| 2.5| 6.1| 2.9| 2.6| 3.3| 3.8| 2.4| 5| 2.7| 3.1| 4.5| 4| 2.8 | null null| 0 | null   LP2985
    LP2985LV LP2985LV 150 3.0| 2.85| 3.3 2.2 16 0.28 null| No 0.065 45 30     Yes No LDO -40 125 null| 3.0| 2.85| 3.3 3.0| 2.85| 3.3   Undefined     LP2985LV
    LP3984 LP3984 150 1.5| 1.8 2.5 6 0.06 No 0.08         Yes No LDO -40 125   1.5| 1.8 1.5| 1.8         LP3984
    LP3985 LP3985 150 4.7| 3| 5| 2.7| 3.2| 2.5| 3.1| 2.9| 2.8| 2.6| 3.3 2.5 6 0.06 No 0.085 50 30     Yes No LDO -40 125   4.7| 3| 5| 2.7| 3.2| 2.5| 3.1| 2.9| 2.8| 2.6| 3.3 4.7| 3| 5| 2.7| 3.2| 2.5| 3.1| 2.9| 2.8| 2.6| 3.3         LP3985
    LP3987 LP3987 150 2.8| 2.85| 2.6 3| 3.05| 2.8 6.5| 6 0.06 No 0.085         Yes No LDO -40 125   2.8| 2.85| 2.6 2.8| 2.85| 2.6       Yes LP3987
    LP3988 LP3988 150 2.5| 2.85| 2.6 2.7| 3.1| 2.8 6 0.08 No 0.085         Yes Yes LDO -40 125   2.5| 2.85| 2.6 2.5| 2.85| 2.6         LP3988
    LP3990 LP3990 150 1.5| 1.8| 2.5| 0.8| 1.35| 2.8| 1.2| 3.3 3.8| 3| 2| 2.3| 3.3 6 0.06 No 0.043         Yes No LDO -40 125   1.5| 1.8| 2.5| 0.8| 1.35| 2.8| 1.2| 3.3 1.5| 1.8| 2.5| 0.8| 1.35| 2.8| 1.2| 3.3         LP3990
    LP3995 LP3995 150 3| 2.8| 1.9 2.7| 2.5| 3.1| 2.9 6 -| 0.06 No 0.085 60 25 Yes| null | null Yes No LDO -40 125   3| 2.8| 1.9 3| 2.8| 1.9 | null       LP3995
    LP3999 LP3999 150 1.5| 2.4| 1.8| 2.5| 2.8| 3.3 2.5 6 -| 0.06 No 0.085 60 30     Yes No LDO -40 125   1.5| 2.4| 1.8| 2.5| 2.8| 3.3 1.5| 2.4| 1.8| 2.5| 2.8| 3.3         LP3999
    LP5900 LP5900 150 1.5| 2.8| 3.3 2.5 5.5 0.08 No 0.025 75 6.5     Yes No LDO -40 125   1.5| 2.8| 3.3 1.5| 2.8| 3.3       Yes LP5900
    LP5951 LP5951 150 2.0| 1.5| 3.0| 1.8| 1.3| 2.5| 2.8| 3.3 1.8 5.5 0.2 No 0.029 60 125 Yes   Yes No LDO -40 125   2.0| 1.5| 3.0| 1.8| 1.3| 2.5| 2.8| 3.3 2.0| 1.5| 3.0| 1.8| 1.3| 2.5| 2.8| 3.3         LP5951
    LP8358 LP8358 150 1.2 2.7 6 0.9 No 0.14         Yes Yes LDO -40 125   1.2 1.2         LP8358
    LP2981 LP2981 100 4.7| 3| 5| 3.6| 3.2| 2.5| 3.1| 4| 2.9| 3.3 3.8| 3.5| 4.9| 2.7| 3.2| 3.1| 3.4| 4.2| 5.2| 3.3 16 0.2 No 0.065         Yes No LDO -40 125   4.7| 3| 5| 3.6| 3.2| 2.5| 3.1| 4| 2.9| 3.3 4.7| 3| 5| 3.6| 3.2| 2.5| 3.1| 4| 2.9| 3.3         LP2981
    LMS5213 LMS5213 80 3| 2.8| 3.3 2.7 6 0.33 No 0.16         Yes No LDO -40 125   3| 2.8| 3.3 3| 2.8| 3.3         LMS5213
    LMS5214 LMS5214 80 3| 2.5| 2.9| 2.8| 2.6 2.8 6 0.3 No 0.07         Yes No LDO -40 125   3| 2.5| 2.9| 2.8| 2.6 3| 2.5| 2.9| 2.8| 2.6         LMS5214
    LP2978 LP2978 50 3.8 2.5 16 0.12 No 0.065 45 30     Yes No LDO -40 125   3.8 3.8         LP2978
    LP2980 LP2980 50 4.7| 3.5| 3| 2.7| 5| 3.6| 2.5| 3.1| 4.5| 4| 2.6| 3.3 2.1 16 0.12 No 0.065         Yes No LDO -40 125   4.7| 3.5| 3| 2.7| 5| 3.6| 2.5| 3.1| 4.5| 4| 2.6| 3.3 4.7| 3.5| 3| 2.7| 5| 3.6| 2.5| 3.1| 4.5| 4| 2.6| 3.3         LP2980
    LP2980-ADJ LP2980-ADJ 50 1.24 2.5 16 0.12 Yes 0.065         Yes No LDO -40 125   Undefined 15.5         LP2980-ADJ
    LP2982 LP2982 50 3.8| 4.7| 3| 5| 3.6| 5.3| 2.5| 4.5| 4| 2.8| 2.6| 3.3 5.42| 2.72| 4.62| 2.92| 5.12| 4.82| 2.62| 3.42| 3.12| 4.12| 3.72 16 0.12 No 0.065 45 30     Yes No LDO -40 125   3.8| 4.7| 3| 5| 3.6| 5.3| 2.5| 4.5| 4| 2.8| 2.6| 3.3 3.8| 4.7| 3| 5| 3.6| 5.3| 2.5| 4.5| 4| 2.8| 2.6| 3.3         LP2982
    LM4132 LM4132 20 2.5| 4.096| 2.048 2.2 5.5 0.175 No 0.06   170     No No LDO Reference -40 125 0.05% to 0.5% tolerance versions available 2.5| 4.096| 2.048 2.5| 4.096| 2.048     Yes Yes LM4132
    LM3411 LM3411 15 5 Undefined 20 Undefined No 0.085       0.5| 1 No No Linear/LDO Controller -40 85 Custom voltages available, 3V-17V 5 5 5       LM3411
    LM3460 LM3460 15 1.2 Undefined 20 Undefined No 0.085       1 No No Linear/LDO Controller 0 70 Can also be used for GTL, GTLp bus voltage control 1.2 1.2 1.2       LM3460
    LM4140 LM4140 8 1.25| 1.024| 2.5| 4.096| 2.048 4.366| 1.8| 2.283| 2.735 5.5 0.195| 0.16 No 0.23   2.2     No No LDO Reference 0 70 0.1% Initial Accuracy 1.25| 1.024| 2.5| 4.096| 2.048 1.25| 1.024| 2.5| 4.096| 2.048       Yes LM4140
    LM4120 LM4120 5 3| 5| 1.8| 2.5| 4.096| 2.048| 3.3 3.3 14 0.18 No 0.16   20     No No LDO -40 85   3| 5| 1.8| 2.5| 4.096| 2.048| 3.3 3| 5| 1.8| 2.5| 4.096| 2.048| 3.3     Yes Yes LM4120
    LM4121 LM4121 5 1.2| 1.21 3.3 14 0.25 Yes| No 0.16   30     No No LDO -40 85   Undefined| 1.2 10| 1.2       Yes LM4121
    LP3983 LP3983 5 1.6| 2.5 2.7| 2.5 6 - No 0.014         Yes No LDO -40 125   1.6| 2.5 1.6| 2.5       Yes LP3983
    电源管理技术支持
    • Excel 文档格式下载 Excel 文档格式选型指南下载 - 线性/低压降(LDO)稳压器Linear/LDO Regulators
    模拟产品选择及设计指引
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
