龙人旗下深圳市龙芯世纪科技有限公司
  • 高速MOSFET驱动器
  • 发布时间:2009/2/28 10:47:42   修改时间:2009/2/28 10:47:42 浏览次数:3007
  • 首页NS国半电源管理
    高速MOSFET驱动器
    Base Part Number 数据手册DataSheet下载 Topology Input Max Voltage Supply Min Supply Max Peak Sink Current Peak Source Current Output Rise Time (tr) Output Fall Time tf Bottom Driver Prop Delay TopDriver PropDelay PulseWidth Min Quiescent Current HighSide Drive LowSide Drive Outputs LowGate Enable UVLO Shut down Internal BootDiode On/Off Pin Input Control Special Features RegType Temperature Min Temperature Max PowerWise 数据手册DataSheet下载
    LM5110 LM5110 Forward, push-pull, etc - 3.5 14 5 2 15 15 25 Undefined Undefined 1 No Yes 2 No Yes Yes Not required - Dual, independent Compound driver, negative output capable, one inverted, one non-inverted MOSFET Driver -40 125   LM5110
    LM5111 LM5111 Forward, push-pull, etc - 3.5 14 5 3 15 12 25 - Undefined 1 No Yes 1 No Yes - Not required - Dual, independent Compound driver, one inverted, one non-inverted MOSFET Driver -40 125   LM5111
    LM5112 LM5112 Forward, push-pull, etc Undefined 3.5 14 7 3 14 12 25 - Undefined 1 No Yes 1 No Yes No Not required No Single PWM Compound driver, Single supply config MOSFET Driver -40 125   LM5112
    LM27222 LM27222 Synchronous Buck 30 4 6.85 4.5 3 17 14 11.5 9.5 30 0.54 Yes Yes 2 Yes No Yes Undefined Yes Single PWM Undefined MOSFET Driver -40 125   LM27222
    LM5100A LM5100A Synchronous Buck, Bridge 100 7.5 14 3 3 10 10 25 25 50 0.2 Yes Yes 2 No Yes No Yes - Dual, independent CMOS type threshold inputs MOSFET Driver -40 125   LM5100A
    LM5100B LM5100B Synchronous Buck, Bridge 100 7.5 14 2 2 10 10 25 25 50 0.2 Yes Yes 2 No Yes No Yes | - Dual, independent CMOS type threshold inputs MOSFET Driver -40 125   LM5100B
    LM5100C LM5100C Synchronous Buck, Bridge 100 7.5 14 1 1 10 10 25 25 50 0.2 Yes Yes 2 No Yes No Yes   Dual, independent CMOS type threshold inputs MOSFET Driver -40 125   LM5100C
    LM5101A LM5101A Synchronous Buck, Bridge 100 7.5 14 3 3 10 10 25 25 50 0.2 Yes Yes 2 No Yes No Yes - Dual, independent TTL type threshold inputs MOSFET Driver -40 125   LM5101A
    LM5101B LM5101B Synchronous Buck, Bridge 100 7.5 14 2 2 10 10 25 25 50 0.2 Yes Yes 2 No Yes No Yes   Dual, independent TTL type threshold inputs MOSFET Driver -40 125   LM5101B
    LM5101C LM5101C Synchronous Buck, Bridge 100 7.5 14 1 1 10 10 25 25 50 0.2 Yes Yes 2 No Yes No Yes   Dual, independent TTL type threshold inputs MOSFET Driver -40 125   LM5101C
    LM5102 LM5102 Synchronous Buck, Bridge 100 7.5 14 2 2 10 10 35 35 50 0.4 Yes Yes 2 No Yes No Yes - Dual, independent Independent programmable delay (rising edge) MOSFET Driver -40 125   LM5102
    LM5104 LM5104 Synchronous Buck, Bridge 100 7.5 14 2 2 10 10 35 35 50 0.4 Yes Yes 2 No Yes No Yes - Single PWM Adaptive deadtime with programmable delay MOSFET Driver -40 125   LM5104
    LM5105 LM5105 Synchronous Buck, Bridge 100 7.5 14 2 2 10 10 35 35 50 0.4 Yes Yes 2 Yes Yes No Yes No Single PWM   MOSFET Driver -40 125   LM5105
    LM5106 LM5106 Synchronous Buck, Bridge 100 7.6 14 1.8 1.2 15 10 32 32 50 0.34 Yes Yes 2 No Yes Yes Undefined Yes Single PWM Programmable Dead-Time MOSFET Driver -40 125   LM5106
    LM5107 LM5107 Synchronous Buck, Bridge 100 7.5 14 1.4 1.3 15 15 25 25 50 0.3 Yes Yes 2 No Yes No Yes Undefined Dual, independent TTL Inputs MOSFET Driver -40 125   LM5107
    LM5109 LM5109 Synchronous Buck, Bridge 100 7.5 14 1 1 15 15 25 25 50 0.2 Yes Yes 2 No Yes No Undefined Undefined Dual, independent   MOSFET Driver -40 125   LM5109
    LM5109A LM5109A Synchronous Buck, Bridge 90 7.5 14 1 1 15 15 25 25 50 0.2 Yes Yes 2 No Yes No Undefined Undefined Dual, independent   MOSFET Driver -40 125   LM5109A
    LM5109B LM5109B Synchronous Buck, Bridge 90 7.5 14 1 1 15 15 25 25 40 0.2 Yes Yes 2 No Yes No Undefined Undefined Dual, independent TTL Inputs MOSFET Driver -40 125   LM5109B
    电源管理技术支持
    模拟产品选择及设计指引
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
