龙人旗下深圳市龙芯世纪科技有限公司
  • 热管理Thermal Management 汽车电子
  • 发布时间:2009/2/28 10:53:18   修改时间:2009/2/28 10:53:18 浏览次数:5166
  • 首页NS国半方案应用汽车电子
    模拟Analog
    Base Part Number 数据手册DataSheet下载 Quiescent Current Sensor Gain Supply Min Supply Max Temperature Accuracy (+/-) Single Supply Output Impedance Temperature Min Temperature Max PowerWise 数据手册DataSheet下载
    LM19 LM19 0.0045 -11.7 mV/Deg C 2.4 5.5 2.5 Yes 160 -55 130   LM19
    LM20 LM20 0.0045 -11.7 mV/Deg C 2.4 5.5 1.5| 2.5| 4 Yes 160 -55| -40 130| 125   LM20
    LM94022 LM94022 0.0081 -5.5 to -13.6 mV/degC 1.5 5.5 1.5 Yes 5.2 -50 150 Yes LM94022
    LM94021 LM94021 0.012 -5.5 to -13.6 mV/degC 1.5 5.5 1.5 Yes 8 -50 150 Yes LM94021
    LM35 LM35 0.056 10 mV/Deg C 4 30 0.5| 1 No 0.4 -55| 0| -40 150| 110| 100   LM35
    LM34 LM34 0.075 10 mV/Deg F 5 30 1.11| 0.556 No 0.4 -45.5555| 0| -40 110| 148.889008| 100   LM34
    LM60 LM60 0.082 6.25 mV/Deg C 2.7 10 3| 2 Yes 800 -40| -25 125   LM60
    LM61 LM61 0.082 10 mV/Deg C 2.7 10 3| 2 Yes 800 -30| -25 85| 100   LM61
    LM62 LM62 0.082 15.6 mV/Deg C 2.7 10 3| 2 Yes 4400 0 90   LM62
    LM45 LM45 0.12 10 mV/Deg C 4 10 3| 2 No 35 -20 100 No LM45
    LM50 LM50 0.13 10 mV/Deg C 4.5 10 3| 2 Yes 2000 -40| -25 125| 100   LM50
    LM135 LM135 1 10 mV/Deg K 5 - 3 Yes 0.5 -55 150   LM135
    LM135A LM135A 1 10 mV/Deg K 5 - 1 Yes 0.5 -55 150   LM135A
    LM235 LM235 1 10 mV/Deg K 5 - 3 Yes 0.5 -40 125   LM235
    LM235A LM235A 1 10 mV/Deg K 5 - 1 Yes 0.5 -40 125   LM235A
    LM335 LM335 1 10 mV/Deg K 5 - 3| 6 Yes 0.6 -40 100   LM335
    LM335A LM335A 1 10 mV/Deg K 5 - 3 Yes 0.6 -40 100   LM335A
    LM334 LM334               0 70   LM334
    数字Digital
    Base Part Number DataSheet数据手册下载 Quiescent Current Resolution degC/LSB Interface Type Temperature Accuracy (+/-) Supply Min Supply Max Remote Diode Thermal Sensors TruTherm(TM) Beta Compensation Resolution Programmable Setpoints Shut down Integrated Fan Controls Interrupt Outputs Fault Queue Temperature Min Temperature Max PowerWise DataSheet数据手册下载
    LM76 LM76 0.45 0.0625 2-Wire Serial 1 4.5 5.5 - - 13 Yes Yes - 2 Yes -55 150   LM76
    LM70 LM70 0.49 0.25 SPI/Microwire 2 2.7 5.5 - - 11 No Yes - - No -55 150 Yes LM70
    LM77 LM77 0.5 0.5 2-Wire Serial 1.5 3 5.5 - - 10 Yes Yes - 2 Yes -55 125   LM77
    LM95010 LM95010 0.5 0.25 Sensor Path 3 3 3.6 - - - No Yes - - No 0 125   LM95010
    LM74 LM74 0.52 0.0625 SPI/Microwire 1.25 3| 4.5 3.6| 5.5 - - 13 No Yes - - No -55 150   LM74
    LM92 LM92 0.625 0.0625 2-Wire Serial 0.33 2.7 5.5 - - 13 Yes Yes - 2 Yes -55 150 Yes LM92
    LM82 LM82 0.8 1 2-Wire Serial 3 3 3.6 1 - 8 Yes No - 2 No -40 125   LM82
    LM83 LM83 0.8 1 2-Wire Serial 3 3 3.6 3 - 8 Yes No - 2 No -40 125   LM83
    LM75 LM75 1 0.5 2-Wire Serial 2 3| 4.5 3.6| 5.5 - - 9 Yes Yes - 1 Yes -55 125   LM75
    LM84 LM84 1 1 2-Wire Serial 3 3 3.6 1 - 8 Yes No - 2 No 0 125   LM84
    LM63 LM63 1.3 0.125 SMBus 1 3 3.6 1 No 11 Yes Yes 1 1 Yes 0 125 Yes LM63
    LM86 LM86 1.7 0.125 2-Wire Serial 0.75 3 3.6 1 - 11 Yes Yes - 2 Yes 0 125   LM86
    LM90 LM90 1.7 0.125 2-Wire Serial 3 3 3.6 1 - 11 Yes Yes - 2 Yes 0 125   LM90
    温控器Thermostat
    Base Part Number DataSheet数据手册下载 Sensor Gain Quiescent Current Preset Setpoints Temperature Accuracy (+/-) Supply Min Supply Max VtempOutput Impedance Comparators Reference Output Remote Diode Thermal Sensors Temperature Min Temperature Max SetPoint Type SetPoint Value PowerWise DataSheet数据手册下载
    LM26 LM26 -10.82 mV/Deg C 0.04 Yes| null 3 2.7 5.5 18 1 Undefined Undefined -55 125 Fixed 85| 105| 0| 70| 115| 75| 95| 65| 50| 90| 110| 100| -25| 120| 45 Yes LM26
    LM27 LM27 -10.82 mV/Deg C 0.04 Yes| null 3 2.7 5.5 18 1 -| Undefined Undefined 120 150 Fixed 130| 140| 120 Yes LM27
    LM56 LM56 6.2 mV/Deg C 0.23 No 3| 2 2.7 10 1500 2 1.25 Undefined -40 125 Resistor Selectable   Yes LM56
    LM88 LM88 Digital Output 1.5 Yes 3 2.8 3.8 - 3 - 2 -40 85 Fixed 80   LM88
    汽车电子技术支持
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
