龙人旗下深圳市龙芯世纪科技有限公司
  • PA Loop Control 无线通信 Wireless Communications
  • 发布时间:2009/2/28 11:04:28   修改时间:2009/2/28 11:04:28 浏览次数:3549
  • 首页NS国半方案应用无线通信
    PA Loop Control
    Base Part Number 数据手册DataSheet下载 RF Frequency (MHz) Dynamic Range Detector Power Range Accuracy Inputs/Outputs Transfer Modulation Independent Supply Min Supply Max Supply Current Shut down Special Features Detector VCO Freq Range Application Channels PLL Type Temperature Min Temperature Max AEC Q-100 Automotive Grade Automotive Selection Guide PowerWise 数据手册DataSheet下载
    LMV225 LMV225 450-2000 30 -30dBm to 0dBm 1 1月1日 Linear in dB No 2.7 5 4.8 Yes   Resistive Tap, Internal Det 0.4 to 2GHz CDMA,WCDMA,GSM,EDGE,GPRS,TDMA 1 - -40 85     Yes LMV225
    LMV221 LMV221 50-3500 40 -45 to -5dBm 0.5 1月1日 Linear in dB No 2.7 3.3 7.2 Yes   Ext Coupler, Internal Det 50MHz to 3.5GHz CDMA,WCDMA,UTMS,GSM,GPRS,802.11 1 Single -40 85     Yes LMV221
    LMV226 LMV226 450-2000 30 -15dBm to +15dBm 1 1月1日 Linear in dB No 2.7 5 4.9 Yes   External Coupler, Internal Det 0.4 to 2GHz CDMA,WCDMA,GSM,EDGE,GPRS,TDMA 1 - -40 85       LMV226
    LMV228 LMV228 450-2000 30 -15dBm to 15dBm 1 1月1日 Linear in dB No 2.7 5 4.9 Yes   External Coupler, Internal Det 0.4 to 2GHz CDMA,WCDMA,GSM,EDGE,GPRS,TDMA 1 - -40 85     Yes LMV228
    LMV242 LMV242 450-2000 50 -50 to 0 1.5 1月2日 Linear in dB; negative slope No 2.6 5.5 6.9 Yes           Delta-Sigma Fractional-N RF/IF Dual -40 85     Yes LMV242
    LMV243 LMV243 450-2000 50 -50dBm to +5dBm 1.5 1月1日 Linear in dB; negative slope No 2.7 3.3 8.7 Yes Ext Loop Comp, External Coupler, Internal Det 0.45 to 2GHz GSM,TDMA,CDMA,CDMA2000,LAN,AGC 1 - -40 85     Yes LMV243
    LMV232 LMV232 50-2000 23 -11 to 13dBm 1 2月1日 Linear in mW Yes 2.5 3.3 9.8 Yes Dual Inputs, Ext Compensation External Coupler, Internal Det 0.05 to 2GHz 3G,UMTS,WCDMA,CDMA2000,LAN,GPS 2 Dual -40 85     Yes LMV232
    LMH2100 LMH2100 50-4000 40 -45 dBm to -5 dBm 0.5 1月1日 Linear in dB No 2.7 3.3 7.1 Yes   Internal       Single -40 85       LMH2100
    LMV248 LMV248     30dB         2.5 5     Dual Band, Two PA control Ext Schottky diodes Depends on external diodes GSM,TDMA,CDMA,DCS,PCS,LAN 2 - -40 85       LMV248
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
