龙人旗下深圳市龙芯世纪科技有限公司
  • 仪表放大器
  • 发布时间:2009/2/28 11:34:30   修改时间:2009/2/28 11:34:30 浏览次数:3445
  • 首页ADI模拟器件公司放大器和比较器仪表放大器
    仪表放大器
    ADI公司已经为每一种应用和市场推出了种类齐全的低成本、低功耗和高共模抑制比的仪表放大器,包括AD8221高性能仪表放大器、AD8230和AD8220。
    型号 Results: 48 描述 Single/Dual Supply Vcc-Vee Supply Current (max Gain Setting Method Bandwidth G="10" (kHz typ) Gain min. Gain max. Gain Range (min to max) Min CMRR @ 60 Hz Min Gain Min CMRR @ 60Hz Max Gain Vnoise RTI 1-10 Hz μVp-p Price* (1000-4999) DataSheet 数据手册下载
    AD522 Diff Amp Dual 10V to 36V 10mA Resistor 3 1 1,000 1,000 75dB 100dB 4 x AD522
    AD524 Precision IA Dual 12V to 36V 5mA Pin 400 1 1,000 1,000 70dB 110dB 0.3 $9.52 AD524
    AD526 Software Programmable Dual 9V to 33V 14mA Software 350 1 16 16 - - 3 $6.39 AD526
    AD620 General Purpose IA Dual 4.6V to 36V 1.3mA Resistor 800 1 10,000 10,000 73dB 110dB 0.28 $3.18 AD620
    AD621 Precision IA Dual 4.6V to 18V 1.3mA Pin 800 10 100 90 93dB 110dB 0.28 $4.09 AD621
    AD622 Low Cost IA Dual 5.2V to 36V 0.9mA Resistor 800 1 1,000 1,000 66dB 103dB 0.3 $2.51 AD622
    AD623 S.S R-R IA Single/Dual 2.7V to 12V 0.55mA Resistor 100 1 1,000 1,000 70dB 105dB 2 $1.40 AD623
    AD624 Precision IA Dual 12V to 36V 5mA Pin 400 1 1,000 1,000 70dB 110dB 0.3 $11.93 AD624
    AD625 Programmable Gain IA Dual 12V to 36V 5mA Resistor 400 1 10,000 10,000 70dB 110dB 0.3 $8.78 AD625
    AD626 Diff Amp Single/Dual 2.4V to 12V 2mA Pin 100 10 100 90 55dB 55dB 2 $3.70 AD626
    AD627 Micropower IA Single/Dual 2.2V to 36V 0.06mA Resistor 30 5 1,000 995 77dB 77dB 1.2 $2.56 AD627
    AD628 High CMV DA Single/Dual 4.5V to 36V 1.6mA Pin, Resistor 600 0.1 100 100 75dB 75dB 15 $1.78 AD628
    AD629 High CMV DA Dual 5V to 36V 1mA fixed 500 - - 1 77dB 77dB 15 $2.84 AD629
    AD8129 Low Cost Diff Amp Single/Dual 4.5V to 25V 10.8mA Resistor 200000 10 - 10 94dB - - $1.57 AD8129
    AD8202 High CMV DA Single 3.5V to 12V 0.25mA fixed 50 - - 20 82dB 82dB 10 $1.51 AD8202
    AD8203 High CMV DA Single 4.5V to 5.5V 0.25mA fixed 60 - - 14 82dB 82dB 10 $1.37 AD8203
    AD8205 S.S Diff Amp Single 4.5V to 5.5V 2mA fixed 50 - - 50 78dB 78dB 20 $1.51 AD8205
    AD8206 S.S Diff Amp Single 4.5V to 5.5V 2mA fixed 100 - - 20 76dB 76dB 20 $1.37 AD8206
    AD8210 Bi-Directional Shunt Mon Single 4.5V to 5.5V 1.5mA fixed 500 20 20 20 100dB 100dB 7 $1.81 AD8210
    AD8211 High CMV Shunt Mon Single 4.5V to 5.5V 2mA fixed 500 20 20 20 100dB 100dB 7 $0.81 AD8211
    AD8212 High CMV Shunt Mon Single 7V to 65V 720μA Resistor 1000 1 1,000 1,000 100dB 100dB 1.1 $0.93 AD8212
    AD8213 Dual High CMV Shunt Mon Single 4.5V to 5.5V 2.5mA fixed 500 20 20 20 100dB 100dB 7 $2.01 AD8213
    AD8214 High CMV Threshold Detec Single 5V to 65V 1.2mA Resistor - 1 100 100 80dB 80dB 2.2 $0.76 AD8214
    AD8215 High CMV Shunt Mon Single 4.5V to 5.5V 2.2mA fixed 450 20 20 20 100dB 100dB 7 $1.21 AD8215
    AD8216 High BW 65 V Diff Amp Single 4.5V to 5.5V 2mA fixed 3000 3 3 3 80dB 80dB 20 $1.62 AD8216
    AD8220 R-R JFET IA Single/Dual 4.6V to 36V 750μA Resistor 800 1 1,000 1,000 78dB 94dB 0.8 $2.32 AD8220
    AD8221 High Performance IA Dual 4.6V to 36V 1mA Resistor 562 1 1,000 1,000 80dB 130dB 0.25 $2.01 AD8221
    AD8222 Dual High Performance IA Dual - 0.9mA Resistor 750 1 10,000 10,000 80dB 130dB 0.25 $3.63 AD8222
    AD8223 S.S R-R IA Single/Dual 3V to 25V 0.6mA Pin 200 5 1,000 - 70dB 105dB 2 $1.05 AD8223
    AD8224 Dual JFET R-R IA Single/Dual 4.6V to 36V - Resistor 800 1 1,000 - 78dB 94dB 0.8 $4.17 AD8224
    AD8225 Fixed G="5" IA Dual 3.4V to 36V 1.2mA fixed 900 - - 5 86dB 86dB 1.5 $3.29 AD8225
    AD8228 Precision IA Dual 4.6V to 36V - Pin 650 10 100 10,100 100dB 120dB 0.5 $3.03 AD8228
    AD8230 Zero Drift IA Single/Dual 8V to 16V 2.7mA Resistor 2 2 1,000 998 - 110dB 3 $2.99 AD8230
    AD8231 Zero Drift Software Prog Single 3V to 6V 4mA Pin, Software 700 1 128 128 80dB 110dB 0.7 $1.71 AD8231
    AD8250 Software Programmable Dual 10V to 34V 4.5mA Pin, Software 3000 1 10 10 80dB 98dB 1 $5.01 AD8250
    AD8251 Software Programmable Dual 10V to 34V 3.5mA Pin, Software 2500 1 8 8 80dB 98dB 1.2 $5.01 AD8251
    AD8253 Software Programmable Dual 10V to 34V 4mA Pin, Software 10000 1 1,000 999 80dB 120dB 1 $4.95 AD8253
    AD8270 Dual Diff Amp Dual 5V to 36V 2.5mA Pin 10000 0.5 2 1.5 70dB 80dB 1 $1.89 AD8270
    AD8273 Dual Audio Diff Amp Dual 5V to 36V 2.5mA Pin 20000 0.5 2 1.5 77dB - 2 $1.67 AD8273
    AD8274 - - 5V to 36V 2.6mA - 10000 0.5 2 - - - - $1.05 AD8274
    AD8290 Sensor Amp - 2.6V to 5.5V 4.68mA fixed - 50 50 50 - - 0.75 $1.52 AD8290
    AD8293G160 Zero Drift Filter Amp Single 1.8V to 5.5V 1.3mA fixed 0.5 160 160 n/a 94dB 94dB 0.7 $0.99 AD8293G160
    AD8293G80 Zero Drift Filter Amp Single 1.8V to 5.5V 1.3mA fixed 0.5 80 80 - 94dB 94dB 0.7 $0.99 AD8293G80
    AD8553 Zero Drift IA Single 1.8V to 5.5V 1.3mA Resistor 1 0.1 10,000 10,000 80dB 120dB 0.7 $1.32 AD8553
    AD8555 Sensor Amp Single 5.5V to 2.7V 2.5mA Software n/a 70 1,280 1,210 80dB 96dB 0.5 $3.12 AD8555
    AD8556 Sen/Filter Amp Single 2.7V to 5.5V 2mA Software n/a 70 1,280 1,210 80dB 94dB 0.5 $2.88 AD8556
    AD8557 Sensor Amp Single 2.7V to 5.5V - Software - 28 1,300 - 75dB 86dB - $2.13 AD8557
    AMP03 Precision Diff Amp Dual 12V to 36V 2.5mA fixed 3000 - - 1 85dB 85dB 2 $2.81 AMP03
    Analog Devices, Inc.ADI美国模拟器件公司
    这里所列出的美国报价单仅供预算参考,指美元报价(规定订量的每片美元,美国离岸价),如有修改不再另行通知。由于地区关税、商业税、汇率及手续费原因,国内报价可能不同。对于特殊批量报价,请与BDTIC 半导体事业部联系。对于评估板和套件的报价是指一个单位价格。
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
