龙人旗下深圳市龙芯世纪科技有限公司
  • 视频放大器、缓冲器和滤波器
  • 发布时间:2009/2/28 11:47:26   修改时间:2009/2/28 11:47:26 浏览次数:3840
  • 首页ADI模拟器件公司音频和视频产品
    视频放大器、缓冲器和滤波器
    如果您的设计需要一个以1或2倍增益起简单缓冲作用的放大器,ADI公司为您提供了合适的解决方案。这些简单易用的缓冲放大器专门适合一种特定的增益,因此使您的设计时间减至最少。
    Video Op-Amps 视频运算放大器
    Part#Results: 33 -3dB Bandwidth Slew Rate Min Stable Acl Rail-Rail Out THD (-dB) Input Noise (nV/rtHz) Vcc-Vee Supply Current (max) Features Packages Price* (1000-4999) 数据手册DataSheet 下载
    AD8051 110MHz 170V/μs 1V/V Yes 68 16nV/rtHz 3V to 12V 5.5 Rail-to-Rail, Single Supply SOIC, SOT $0.86 AD8051
    AD8052 110MHz 170V/μs 1V/V Yes 68 16nV/rtHz 3V to 12V 11 Rail-to-Rail, Single Supply SOIC, SOP $1.62 AD8052
    AD8091 110MHz 170V/μs 1V/V Yes 71 16nV/rtHz 3V to 12V 5.5 Rail-to-Rail, Single Supply SOIC, SOT $0.70 AD8091
    AD8092 110MHz 170V/μs 1V/V Yes 71 16nV/rtHz 3V to 12V 11 Rail-to-Rail, Single Supply SOIC, SOP $0.90 AD8092
    AD829 120MHz 230V/μs 1V/V No n/a 1.7nV/rtHz 9V to 36V 6.5 Comp Pin, Null DIP, LCC, SOIC $2.52 AD829
    ADA4851-4 130MHz 375V/μs 1V/V Yes 83 10nV/rtHz 2.7V to 12V 12.8 Rail-to-Rail, Single Supply SOP $1.10 ADA4851-4
    ADA4851-2 130MHz 375V/μs 1V/V Yes 83 10nV/rtHz 2.7V to 12V 6.4 Rail-to-Rail, Single Supply SOP $0.70 ADA4851-2
    AD8054 150MHz 145V/μs 1V/V Yes 68 16nV/rtHz 3V to 12V 13.6 Single Supply SOIC, SOP $2.88 AD8054
    AD8044 160MHz 190V/μs 1V/V Yes 75 16nV/rtHz 3V to 12V 13.6 Rail-to-Rail, Single Supply DIP, SOIC $4.00 AD8044
    AD8041 170MHz 170V/μs 1V/V Yes 72 16nV/rtHz 3V to 12V 6.5 Disable, Power Down, Rail-to-Rail, Single Supply DIP, SOIC $1.95 AD8041
    AD8042 170MHz 225V/μs 1V/V Yes 73 15nV/rtHz 3V to 12V 14 Rail-to-Rail, Single Supply DIP, SOIC $2.05 AD8042
    ADA4850-1 175MHz 220V/μs 1V/V Yes 81 10nV/rtHz 2.7V to 6V 2.9 Power Down, Rail-to-Rail, Single Supply CSP $0.56 ADA4850-1
    ADA4850-2 175MHz 220V/μs 1V/V Yes n/a 10nV/rtHz 2.7V to 6V 5.6 Disable, Power Down, Rail-to-Rail, Single Supply CSP $0.70 ADA4850-2
    AD8019 175MHz 400V/μs 1V/V No 78 8nV/rtHz 8V to 24V 21 Power Down, Single Supply SOIC, SOP $3.10 AD8019
    AD8036 240MHz 1.2kV/μs 1V/V No 66 6.7nV/rtHz 6V to 12V 21.5 Clamp Amp DIP, SOIC $3.46 AD8036
    AD8047 250MHz 750V/μs 1V/V No 61 5.2nV/rtHz 6V to 12V 6.6 n/a DIP, SOIC $2.53 AD8047
    AD8079 260MHz 800V/μs 1V/V No 65 2nV/rtHz 6V to 12V 11.5 Buffer SOIC $4.56 AD8079
    AD8055 300MHz 1.4kV/μs 1V/V No 72 6nV/rtHz 8V to 12V 6.5 n/a DIP, SOIC, SOT $0.86 AD8055
    AD8056 300MHz 1.4kV/μs 1V/V No 72 6nV/rtHz 8V to 12V 12 n/a DIP, SOIC, SOP $1.62 AD8056
    ADA4862-3 310MHz 830V/μs 1V/V No 81 10.6nV/rtHz 5V to 12V 20.5 Disable, Power Down, Single Supply SOIC $0.96 ADA4862-3
    AD8063 320MHz 650V/μs 1V/V Yes 77 8.5nV/rtHz 2.7V to 8V 9.5 Disable, Power Down, Rail-to-Rail, Single Supply SOIC, SOT $0.86 AD8063
    AD8061 320MHz 650V/μs 1V/V Yes 77 8.5nV/rtHz 2.7V to 8V 9.5 Rail-to-Rail, Single Supply SOIC, SOT $0.86 AD8061
    AD8062 320MHz 650V/μs 1V/V Yes 77 8.5nV/rtHz 2.7V to 8V 19 Rail-to-Rail, Single Supply SOIC, SOP $1.62 AD8062
    AD9631 320MHz 1.3kV/μs 1V/V No 72 7nV/rtHz 6V to 12V 18 n/a DIP, SOIC $3.81 AD9631
    AD8057 325MHz 1.15kV/μs 1V/V No 85 7nV/rtHz 3V to 12V 7.5 Single Supply SOIC, SOT $0.86 AD8057
    AD8058 325MHz 1.15kV/μs 1V/V No 85 7nV/rtHz 3V to 12V 15 Single Supply SOIC, SOP $1.62 AD8058
    AD8038 350MHz 425V/μs 1V/V No 90 8nV/rtHz 3V to 12V 1.5 Disable, Power Down, Single Supply SC70, SOIC $0.86 AD8038
    AD8039 350MHz 425V/μs 1V/V No 90 8nV/rtHz 3V to 12V 3 Single Supply SOIC, SOT $1.21 AD8039
    AD8021 490MHz 150V/μs 1V/V No 93 2.1nV/rtHz 4.5V to 24V 7.7 Comp Pin, Disable, Power Down, Single Supply SOIC, SOP $1.31 AD8021
    ADA4860-1 520MHz 790V/μs 1V/V No 90 4nV/rtHz 5V to 12V 8 Disable, Power Down, Single Supply SOT $0.56 ADA4860-1
    AD8074 600MHz 1.6kV/μs 1V/V No 80 19.5nV/rtHz 9V to 11V 30 Buffer, Disable, Power Down, Single Supply SOP $2.22 AD8074
    ADA4861-3 730MHz 680V/μs 1V/V No 85 3.2nV/rtHz 5V to 12V 20.5 Power Down, Single Supply SOIC $0.96 ADA4861-3
    AD8045 1GHz 1350V/μs 1V/V No 102 3nV/rtHz 3.3V to 12V 16 - CSP, SOIC $1.41 AD8045
    Video Filters
    Part#Results:7 Standards Resolution Variable Gain 2:1 Input MUX Pos Supply Supply Current (max) Operating Temp Range Packages Price* (1000-4999) 数据手册DataSheet 下载
    ADA4410-6 CV, RGB, SD, Y/C, YPbPr, YUV 1080i, 720p 2x, 4x X +4.5V to +12V 92mA -40 to +85 32-ld LFCSP $2.52 ADA4410-6
    ADA4411-3 RGB, SD, Y/C, YPbPr, YUV 1080i, 720p 2x, 4x X +4.5V to +12V 60mA -40 to +85 24-ld QSSOP $1.91 ADA4411-3
    ADA4412-3 RGB, SD, Y/C, YPbPr, YUV 1080i, 720p 2x - +4.5V to +12V 56mA -40 to +85 20-ld QSSOP $1.61 ADA4412-3
    ADA4417-3 RGB, YPbPr, YUV 1080i, 720p 2x - +3.3V to +5V 24mA -40 to +85 10-ld MSOP $0.80 ADA4417-3
    ADA4420-6 RGB, Y/C, YPbPr - - - +4.75V to +5.25V 36mA - 16-ld QSOP $0.69 ADA4420-6
    ADA4430-1 SD, Y/C 480i 2x - +2.5V to +6V 1.85mA -40 to +125 6-ld SC70 $0.50 ADA4430-1
    ADA4431-1 SD 480i 2x - +2.5V to +3.6V 4.7mA -40 to +85 24-ld LFCSP $0.50 ADA4431-1
    Buffers
    Part#Results:4 OpAmps per Pkg -3dB Bandwidth Closed Loop Gain (dB) Vos Input Noise (nV/rtHz) Ib Vcc-Vee Supply (V) Supply Current (max) Slew Rate Operating Temp Range Price* (1000-4999) 数据手册DataSheet 下载
    AD8074 3 600MHz 0 or 6.02 2.5mV 19.5nV/rtHz 5μA 9 to 11 30 1.6kV/μs -40 to +85 $2.22 AD8074
    AD8075 3 550MHz 0 or 6.02 2.5mV 22nV/rtHz 5μA 9 to 11 30 1.35kV/μs -40 to +85 $2.22 AD8075
    AD8079 2 260MHz 6.02 or 6.85 5mV 2nV/rtHz 3μA 6 to 12 11.5 800V/μs -40 to +85 $4.56 AD8079
    ADD8701 13 4.5MHz 0 4mV 25nV/rtHz 500nA 7 to 16 13 6V/μs -40 to +85 ** ADD8701
    CAT-5 Video Drivers
    Part#Results:12 -3 dB BW (MHz) 0.1 dB Flatness (MHz) Minimum Gain (Acl) Slew Rate (V/us) Disable Pos Supply Supply Current (max) Features Package Price* (1000-4999) 数据手册DataSheet 下载
    AD8131 400 85 2 2000 - +2.7V to +11V 10.25mA - 8-Lead MSOP, 8-Lead SOIC $1.82 AD8131
    AD8133 450 55 2 1600 X +2.8V to +11V 26mA - 24-Lead LFCSP $2.62 AD8133
    AD8134 450 55 2 1600 X +4.5V to +11V 26.5mA Sync-on-CM 24-Lead LFCSP $2.62 AD8134
    AD8146 700 200 2 3000 X +4.5V to ±5.5V 61.5mA Adjustable Output Common Mode Voltage 24-Lead LFCSP $2.92 AD8146
    AD8147 600 235 2 3000 X +4.5V to +5.5V 61.5mA Sync on Common Mode 24-Lead LFCSP $3.03 AD8147
    AD8148 700 235 4 3000 X +4.5V to +5.5V 62.5mA Sync on Common Mode 24-Lead LFCSP $3.13 AD8148
    AD8390A 45 - - 260 - +10V to +24V - - - $1.16 AD8390A
    AD8392A 37 - - 515 - +10V to +24V - - - $2.82 AD8392A
    AD8394 35 - - 300 - +12V to +24V - - 20-Lead TSSOP, 24-Lead LFCSP $2.07 AD8394
    AD8396 - - - - - +12V to +24V - - - $1.97 AD8396
    AD8398 165 - - 820 - +5V to +12V - - - $1.77 AD8398
    ADL5321             84mA   3-Lead SOT-89 $2.58 ADL5321
    CAT-5 Video Receivers
    Part#Results:4 -3 dB BW (MHz) 0.1 dB Flatness (MHz) Slew Rate (V/us) Minimum Gain (Acl) Pos Supply Supply Current (max) Disable Features Package Price* (1000-4999) 数据手册DataSheet 下载
    AD8129 200 20 1060 10 +4.5V to +25.2V 10.8mA X Low Noise 8-Lead MSOP, 8-Lead SOIC $1.57 AD8129
    AD8130 270 30 1090 1 -4.5V to +25.2V 10.8mA X - 8-Lead MSOP, 8-Lead SOIC $1.57 AD8130
    AD8143 260 60 1000 1 +4.5V to +25.2V 39mA X Sync-on-CM 32-Lead CSP $2.58 AD8143
    AD8145 500 100 2100 1 +4.5V to +11V 48.5mA X - 32-Lead CSP $3.03 AD8145
    CAT-5 Cable Equalizers
    Part#Results:2 -3 dB BW (MHz) Slew Rate (V/us) 0.1 dB Flatness (MHz) Minimum Gain (Acl) Pos Supply Supply Current (max) Features Package Price* (1000-4999) 数据手册DataSheet 下载
    AD8123 120 - - - +4.5V to +5.5V 132mA Up to 300 m of Cat-5 40-Lead LFCSP $7.88 AD8123
    AD8128 120 2700 70 - +4.5V to +5.5V 24mA Up to 100m of CAT-5 8-Lead LFCSP $2.62 AD8128
    Video RF Splitters
    Part#Results:2 I/O Configuration Inputs:Outputs 1-dB Bandwidth (MHz) CSO (dBc) CTB (dBc) Noise Figure (dB) Package   Price* (1000-4999) 数据手册DataSheet 下载
    ADA4302-4 Differential 1:4 900 -73 -66 4.4 20-Lead LFCSP   $2.63 ADA4302-4
    ADA4304-2 - - - -62 -72 4.6 16-Lead LFCSP   $0.70 ADA4304-2
    Analog Devices, Inc.ADI 美国模拟器件公司相关技术支持
    这里所列出的美国报价单仅供预算参考,指美元报价(规定订量的每片美元,美国离岸价),如有修改不再另行通知。由于地区关税、商业税、汇率及手续费原因,国内报价可能不同。对于特殊批量报价,请与BDTIC 半导体事业部联系。对于评估板和套件的报价是指一个单位价格。
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
