龙人旗下深圳市龙芯世纪科技有限公司
  • 汽车级ATmega324P带有32K系统内可编程Flash存储器
  • 发布时间:2009/6/9 19:02:25   修改时间:2009/6/9 19:02:25 浏览次数:2473
  • 首页ATMEL 爱特梅尔AVR 单片机
    Flash (Kbytes) 32
    EEPROM (Kbytes) 1
    SRAM (Bytes) 2048
    Max I/O Pins 32
    F.max (MHz) 16
    Vcc (V) 2.7 - 5.5
    10-bit A/D Channels 8
    Analog Comparator Yes
    16-bit Timers 1
    8-bit Timer 2
    Brown Out Detector Yes
    Ext Interrupts 32
    Hardware Multiplier Yes
    Interrupts 31
    On Chip Oscillator Yes
    PWM Channels 6
    RTC Yes
    Self Program Memory Yes
    SPI 1+USART
    TWI Yes
    UART 2
    Watchdog Yes
    Pb-Free Packages
    VQFN (Sawn) 44
    TQFP 44
    32-Kbyte self-programming Flash Program Memory, 2-Kbyte SRAM, 1-KByte EEPROM, 8 Channel 10-bit A/D-converter. JTAG interface for on-chip-debug. Up to 16 MIPS throughput at 16 MHz. 2.7 - 5.5 Volt Operation.
    The ATmega164P/324P/644P is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC architecture. By executing powerful instructions in a single clock cycle, the ATmega164P/324P/644P achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
    ATmega324P 产品特性
    • High-performance, Low-power AVR? 8-bit Microcontroller
    • Advanced RISC Architecture
      – 131 Powerful Instructions – Most Single-clock Cycle Execution
      – 32 x 8 General Purpose Working Registers
      – Fully Static Operation
      – Up to 20 MIPS Throughput at 20 MHz
      – On-chip 2-cycle Multiplier
    • High Endurance Non-volatile Memory segments
      – 16/32/64K Bytes of In-System Self-programmable Flash program memory
      – 512B/1K/2K Bytes EEPROM
      – 1/2/4K Bytes Internal SRAM
      – Write/Erase Cycles: 10,000 Flash/ 100,000 EEPROM
      – Data retention: 20 years at 85°C/100 years at 25°C
      – Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation
      – Programming Lock for Software Security
    • JTAG (IEEE std. 1149.1 Compliant) Interface
      – Boundary-scan Capabilities According to the JTAG Standard
      – Extensive On-chip Debug Support
      – Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface
    • Peripheral Features
      – Two 8-bit Timer/Counters with Separate Prescalers and Compare Modes
      – One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture Mode
      – Real Time Counter with Separate Oscillator
      – Six PWM Channels
      – 8-channel, 10-bit ADC
      Differential mode with selectable gain at 1x, 10x or 200x
      – Byte-oriented Two-wire Serial Interface
      – Two Programmable Serial USART
      – Master/Slave SPI Serial Interface
      – Programmable Watchdog Timer with Separate On-chip Oscillator
      – On-chip Analog Comparator
      – Interrupt and Wake-up on Pin Change
    • Special Microcontroller Features
      – Power-on Reset and Programmable Brown-out Detection
      – Internal Calibrated RC Oscillator
      – External and Internal Interrupt Sources
      – Six Sleep Modes: Idle, ADC Noise Reduction, Power-save, Power-down, Standby and Extended Standby
    • I/O and Packages
      – 32 Programmable I/O Lines
      – 40-pin PDIP, 44-lead TQFP, 44-pad QFN/MLF (ATmega164P/324P/644P)
      – 44-pad DRQFN (ATmega164P)
    • Operating Voltages
      – 1.8 - 5.5V for ATmega164P/324P/644PV
      – 2.7 - 5.5V for ATmega164P/324P/644P
    • Speed Grades
      – ATmega164P/324P/644PV: 0 - 4MHz @ 1.8 - 5.5V, 0 - 10MHz @ 2.7 - 5.5V
      – ATmega164P/324P/644P: 0 - 10MHz @ 2.7 - 5.5V, 0 - 20MHz @ 4.5 - 5.5V
    • Power Consumption at 1 MHz, 1.8V, 25°C for ATmega164P/324P/644P
      – Active: 0.4 mA
      – Power-down Mode: 0.1μA
      – Power-save Mode: 0.6μA (Including 32 kHz RTC)
    ATmega324P 汽车级 订购型号
    Speed (MHz) Power Supply Ordering Code Package Operational Range
    8-16 2.7 - 5.5V ATmega324P-A15AZ ML -40°C to +125°C
    8-16 2.7 - 5.5V ATmega324P-A15MZ PW -40°C to +125°C
    ATmega324P 技术支持
    1. ATMEL 爱特梅尔 AVR 微控制器ATmega324P 中文数据手册 DataSheet 下载. PDF(简洁版)
    2. ATMEL 爱特梅尔 AVR 微控制器 ATmega324P 英文数据手册 DataSheet 下载. PDF(完整版)
    3. Atmel 爱特梅尔AVR 微控制器简介.PDF (编号:Tech AVR 000)MLF 32
    4. 面向新手的AVR 开发工具,及基本知识.PDF(编号:Tech AVR 001)
    5. 使用AVR 定时/计数器的PWM功能设计要点 .PDF (编号:Tech AVR 002)
    6. AVR指令集(版本:0856G–AVR–07/08)
    7. 相关产品选型Excel 文档格式选型 Excel 文档格式)
    8. AVR 微控制器汽车应用解决方案 . pdf
    9. AVR 微控制器选型指南. pdf
    10. Atmel 爱特梅尔全线产品目录 . pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
