首页>ATMEL 爱特梅尔>AVR 单片机
64-Kbyte self-programming Flash Program Memory, 4-Kbyte SRAM, 2-KByte EEPROM, 8 Channel 10-bit A/D-converter. JTAG interface for on-chip-debug. Up to 20 MIPS throughput at 20 MHz. 1.8 - 5.5 Volt Operation.
The ATmega164P/324P/644P is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC architecture. By executing powerful instructions in a single clock cycle, the ATmega164P/324P/644P achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
High-performance, Low-power AVR? 8-bit Microcontroller
Advanced RISC Architecture– 131 Powerful Instructions – Most Single-clock Cycle Execution– 32 x 8 General Purpose Working Registers– Fully Static Operation– Up to 20 MIPS Throughput at 20 MHz– On-chip 2-cycle Multiplier
High Endurance Non-volatile Memory segments– 16/32/64K Bytes of In-System Self-programmable Flash program memory– 512B/1K/2K Bytes EEPROM– 1/2/4K Bytes Internal SRAM– Write/Erase Cycles: 10,000 Flash/ 100,000 EEPROM– Data retention: 20 years at 85°C/100 years at 25°C– Optional Boot Code Section with Independent Lock BitsIn-System Programming by On-chip Boot ProgramTrue Read-While-Write Operation– Programming Lock for Software Security
JTAG (IEEE std. 1149.1 Compliant) Interface– Boundary-scan Capabilities According to the JTAG Standard– Extensive On-chip Debug Support– Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface
Peripheral Features– Two 8-bit Timer/Counters with Separate Prescalers and Compare Modes– One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture Mode– Real Time Counter with Separate Oscillator– Six PWM Channels– 8-channel, 10-bit ADCDifferential mode with selectable gain at 1x, 10x or 200x– Byte-oriented Two-wire Serial Interface– Two Programmable Serial USART– Master/Slave SPI Serial Interface– Programmable Watchdog Timer with Separate On-chip Oscillator– On-chip Analog Comparator– Interrupt and Wake-up on Pin Change
Special Microcontroller Features– Power-on Reset and Programmable Brown-out Detection– Internal Calibrated RC Oscillator– External and Internal Interrupt Sources– Six Sleep Modes: Idle, ADC Noise Reduction, Power-save, Power-down, Standby and Extended Standby
I/O and Packages– 32 Programmable I/O Lines– 40-pin PDIP, 44-lead TQFP, 44-pad QFN/MLF (ATmega164P/324P/644P)– 44-pad DRQFN (ATmega164P)
Operating Voltages– 1.8 - 5.5V for ATmega164P/324P/644PV– 2.7 - 5.5V for ATmega164P/324P/644P
Speed Grades– ATmega164P/324P/644PV: 0 - 4MHz @ 1.8 - 5.5V, 0 - 10MHz @ 2.7 - 5.5V– ATmega164P/324P/644P: 0 - 10MHz @ 2.7 - 5.5V, 0 - 20MHz @ 4.5 - 5.5V
Power Consumption at 1 MHz, 1.8V, 25°C for ATmega164P/324P/644P– Active: 0.4 mA– Power-down Mode: 0.1μA– Power-save Mode: 0.6μA (Including 32 kHz RTC)
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
