龙人旗下深圳市龙芯世纪科技有限公司
  • 汽车级ATtiny167 带有16K系统内可编程Flash存储器
  • 发布时间:2009/7/4 14:28:26   修改时间:2009/7/4 14:28:26 浏览次数:1392
  • 首页ATMEL 爱特梅尔AVR单片机
    Flash (Kbytes) 16
    EEPROM (Kbytes) 0.5
    SRAM (Bytes) 512
    Max I/O Pins 16
    F.max (MHz) 16
    Vcc (V) 2.7 - 5.5
    10-bit A/D Channels 11
    Analog Comparator Yes
    16-bit Timers 1
    8-bit Timer 1
    Brown Out Detector Yes
    Ext Interrupts 16
    Interrupts 20
    On Chip Oscillator Yes
    PWM Channels 4
    RTC Yes
    Self Program Memory Yes
    SPI 1+USI
    TWI No
    UART Yes
    Watchdog Yes
    Pb-Free Packages VQFN (Sawn) 32
    TSSOP 20
    SOIC 20
    The ATtiny167 provides the following features: 16K byte of In-System Programmable Flash, 512 bytes EEPROM, 512 bytes SRAM, 6 general purpose I/O lines, 32 general purpose working reg-isters, one 8-bit Timer/Counter with compare modes, one 8-bit high speed Timer/Counter, Universal Serial Interface, a LIN controller, Internal and External Interrupts, a 4-channel, 10-bit ADC, a programmable Watchdog Timer with internal Oscillator, and three software selectable power saving modes
    The ATtiny167 have been developed and manufactured according to the most stringent requirements of the international standard ISO-TS-16949. This data sheet contains limit values
    extracted from the results of extensive characterization (temperature and voltage). The quality and reliability of the ATtiny167 have been verified during regular product qualification as per AEC-Q100 grade 1.
    As indicated in the ordering information paragraph, the products are available in only one temperature
    grade as listed in
    ATtiny167 产品特性
    • High Performance, Low Power AVR? 8-Bit Microcontroller Advanced RISC Architecture
      – 123 Powerful Instructions – Most Single Clock Cycle Execution
      – 32 x 8 General Purpose Working Registers
      – Fully Static Operation
      Non-volatile Program and Data Memories
      – 16K Byte of In-System Programmable (ISP) Program Memory Flash
      Endurance: 10,000 Write/Erase Cycles
      – 512 Bytes In-System Programmable EEPROM
      Endurance: 100,000 Write/Erase Cycles
      – 512 Bytes Internal SRAM
      – Programming Lock for Self-Programming Flash Program and EEPROM Data
      Security
      – Low size LIN/UART Software In-System Programmable
      Peripheral Features
      – LIN 2.1 and 1.3 Controller or 8-Bit UART
      – 8-bit Asynchronous Timer/Counter0:
      . 10-bit Clock Prescaler
      . 1 Output Compare or 8-bit PWM Channel
      – 16-bit Synchronous Timer/Counter1:
      . External Event Counter
      . 2 Output Compares Units or 16-bit PWM Channels on 2x 4 Separated Pins
      – Master/Slave SPI Serial Interface,
      – Universal Serial Interface (USI) with Start Condition Detector (Master/Slave SPI,
      TWI, AES, ...)
      – 10-bit ADC:
      . 11 Single Ended Channels
      . 16 Differential ADC Channel Pairs with Programmable Gain (8x or 20x)
      – On-chip Analog Comparator with Selectable Voltage Reference
      – 100μA ±6% Current Source (LIN Node Identification)
      – On-chip Temperature Sensor
      – Programmable Watchdog Timer with Separate On-chip Oscillator
      Special Microcontroller Features
      – Dynamic Clock Switching (External/Internal RC/Watchdog Clock)
      – DebugWIRE On-chip Debug (OCD) System
      – Hardware In-System Programmable (ISP) via SPI Port
      – External and Internal Interrupt Sources
      – Interrupt and Wake-up on Pin Change
      – Low Power Idle, ADC Noise Reduction, and Power-down Modes
      – Enhanced Power-on Reset Circuit
      – Programmable Brown-out Detection Circuit
      – Internal Calibrated RC Oscillator 8MHz
      – 4-16 MHz and 32 KHz Crystal/Ceramic Resonator Oscillators
      I/O and Packages
      – 16 Programmable I/O Lines
      – 20-pin SOIC, 32-pad QFN and 20-pin TSSOP
      Operating Voltage:
      – 2.7 - 5.5V for ATtiny167
      Speed Grade:
      – 0 - 8 MHz @ 2.7 - 5.5V (Automotive Temp. Range: -40°C to +125°C)
      – 0 - 16 MHz @ 4.5 - 5.5V (Automotive Temp. Range: -40°C to +125°C)
    ATtiny167汽车级 订购型号
    Ordering Code Speed (MHz) Power Supply (V) Package Operation Range
    Engineering
    Sample
    ATtiny167-ESSZ 16 2.7-5.5V TG -40° to +125°C
    ATtiny167-ESMZ PN
    ATtiny167-ESXZ 6G
    ATtiny167-15SZ 16 2.7-5.5V TG -40° to +125°C
    ATtiny167-15MZ PN
    ATtiny167-15XZ 6G
    ATtiny167 技术支持
    1. ATMEL 爱特梅尔AVR 微控制器ATtiny167 数据手册DataSheet 下载. PDF(简洁版)
    2. ATMEL 爱特梅尔AVR 微控制器ATtiny167 数据手册DataSheet 下载. PDF(完整版)
    3. Atmel 爱特梅尔AVR 微控制器简介.PDF (编号:Tech AVR 000)MLF 32
    4. 面向新手的AVR 开发工具,及基本知识.PDF(编号:Tech AVR 001)
    5. 使用AVR 定时/计数器的PWM功能设计要点 .PDF (编号:Tech AVR 002)
    6. AVR指令集(版本:0856G–AVR–07/08)
    7. 相关产品选型Excel 文档格式选型 Excel 文档格式)
    8. AVR 微控制器汽车应用解决方案 . pdf
    9. AVR 微控制器选型指南. pdf
    10. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
