龙人旗下深圳市龙芯世纪科技有限公司
  • TS87C58X2 带有32K系统内可编程ROM/OTP存储器
  • 发布时间:2009/7/27 21:34:25   修改时间:2009/7/27 21:34:25 浏览次数:4035
  • 首页ATMEL 爱特梅尔8051单片机
    Mask ROM (Kbytes) 32
    RAM (Bytes) 256
    F.max (MHz) 60
    Vcc (V) 2.7—5.5
    I/O Pins 32
    UART 1
    16-bit Timers 3
    Watchdog Yes
    Packages PDIP 40
    LQFP 44
    PLCC 44
    TS87C58X2 概述
    TS80C54/58X2 is high performance CMOS ROM, OTP and EPROM versions of the
    80C51 CMOS single chip 8-bit microcontroller.
    The TS80C54/58X2 retains all features of the Atmel 80C51 with extended ROM/EPROM capacity (16/32 Kbytes), 256 bytes of internal RAM, a 6-source , 4-level interrupt system, an on-chip oscilator and three timer/counters. In addition, the TS80C54/58X2 a Hardware Watchdog Timer, a more versatile serial channel that facilitates multiprocessor communication (EUART) and a X2 speed improvement mechanism. The fully static design of the TS80C54/58X2 allows to reduce system power consumption by bringing the clock frequency down to any value, even DC, without loss of data.
    The TS80C54/58X2 has 2 software-selectable modes of reduced activity for further reduction in power consumption. In the idle mode the CPU is frozen while the timers, the serial port and the interrupt system are still operating. In the power-down mode the RAM is saved and all otherfunctions are inoperative.
    • 16KB 系统内可编程Flash存储器:AT80C54X2
    • 16KB 系统内可编程Flash存储器:TS80C54X2
    • 32KB 系统内可编程Flash存储器:TS80C58X2
    • 16KB 系统内可编程Flash存储器:AT87C54X2
    • 16KB 系统内可编程Flash存储器:TS87C54X2
    • 32KB 系统内可编程Flash存储器:TS87C58X2
    TS87C58X2 特性
    • 80C52 Compatible
    • 8051 pin and instruction compatible
    • Four 8-bit I/O ports
    • Three 16-bit timer/counters
    • 256 bytes scratchpad RAM
    • High-Speed Architecture
    • 40 MHz @ 5V, 30MHz @ 3V
    • X2 Speed Improvement capability (6 clocks/machine cycle)
      – 30 MHz @ 5V, 20 MHz @ 3V (Equivalent to
      – 60 MHz @ 5V, 40 MHz @ 3V)
    • Dual Data Pointer
    • On-chip ROM/EPROM (16K-bytes, 32K-bytes)
    • Programmable Clock Out and Up/Down Timer/Counter 2
    • Hardware Watchdog Timer (One-time enabled with Reset-Out)
    • Asynchronous port reset
    • Interrupt Structure with
    • 6 Interrupt sources
    • 4 level priority interrupt system
    • Full duplex Enhanced UART
    • Framing error detection
    • Automatic address recognition
    • Low EMI (inhibit ALE)
    • Power Control modes
    • Idle mode
    • Power-down mode
    • Power-off Flag
    • Once mode (On-chip Emulation)
    • Power supply: 4.5-5.5V, 2.7-5.5V
    • Temperature ranges: Commercial (0 to 70oC) and Industrial (-40 to 85oC)
    • Packages: PDIL40, PLCC44, VQFP44 1.4, PQFP44 F1, CQPJ44 (window), CDIL40
      (window)
    TS87C58X2 订购型号
    Part Number Supply Voltage Temperature
    Range
    Package Packing
    AT87C58X2-3CSUM 5V ±10% Industrial Green
    PDIL40
    Stick
    AT87C58X2-SLSUM 5V ±10% Industrial Green PLCC44 Stick
    AT87C58X2-RLTUM 5V ±10% Industrial Green VQFP44 Tray
    AT87C58X2-3CSUL 2.7 to 5.5V Industrial Green PDIL40 Stick
    AT87C58X2-SLSUL 2.7 to 5.5V Industrial Green PLCC44 Stick
    AT87C58X2-RLTUL 2.7 to 5.5V Industrial Green VQFP44 Tray
    AT87C58X2-3CSUV 5V ±10% Industrial Green PDIL40 Stick
    AT87C58X2-SLSUV 5V ±10% Industrial Green PLCC44 Stick
    AT87C58X2-RLTUV 5V ±10% Industrial Green VQFP44 Tray
    TS87C58X2 技术支持
    1. TS87C58X2 数据手册DataSheet 下载. PDF
    2. 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049)
    3. 80C51在系统Flash编程. PDF (编号:8051 00050)
    4. Device Programmers for 8051 Devices (Other, updated 09/07)
      This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers
    5. Emulators for 80C51 Devices (Other, updated 11/03)
      This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers
    6. Package Adapters of 80C51 Devices (Other, updated 10/04)
      This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
