龙人旗下深圳市龙芯世纪科技有限公司
  • TS83C51RC2
  • 发布时间:2009/7/27 21:35:12   修改时间:2009/7/27 21:35:12 浏览次数:3480
  • 首页ATMEL 爱特梅尔8051单片机
    TS83C51RC2
    Atmel TS8xC51Rx2 is a high performance CMOS ROM, OTP, EPROM and ROMless versions of the 80C51 CMOS single chip 8-bit microcontroller.
    The TS8xC51Rx2 retains all features of the 80C51 with extended ROM/EPROM capacity (16/32/64 Kbytes), 256 bytes of internal RAM, a 7-source , 4-level interrupt system, an on-chip oscilator and three timer/counters.
    In addition, the TS80C51Rx2 has a Programmable Counter Array, an XRAM of 256 or 768 bytes, a Hardware Watchdog Timer, a more versatile serial channel that facilitates multiprocessor communication (EUART) and an X2 speed improvement mechanism. The fully static design of the TS80C51Rx2 allows to reduce system power consumption by bringing the clock frequency down to any value, even DC, without loss of data.
    The TS80C51Rx2 has 2 software-selectable modes of reduced activity for further reduction in power consumption. In the idle mode the CPU is frozen while the timers, the serial port and the interrupt system are still operating. In the power-down mode the RAM is saved and all other functions are inoperative.
    TS83C51RC2 特性
    • 80C52 Compatible
      – 8051 pin and instruction compatible
      – Four 8-bit I/O ports
      – Three 16-bit timer/counters
      – 256 bytes scratchpad RAM
    • High-Speed Architecture
      – 40 MHz @ 5V, 30MHz @ 3V
      – X2 Speed Improvement capability (6 clocks/machine cycle)
      – 30 MHz @ 5V, 20 MHz @ 3V (Equivalent to
      – 60 MHz @ 5V, 40 MHz @ 3V)
    • Dual Data Pointer
    • On-chip ROM/EPROM (16K-bytes, 32K-bytes, 64K-bytes)
    • On-chip eXpanded RAM (XRAM) (256 or 768 bytes)
    • Programmable Clock Out and Up/Down Timer/Counter 2
    • Programmable Counter Array with
      – High Speed Output,
      – Compare / Capture,
      – Pulse Width Modulator,
      – Watchdog Timer Capabilities
    • Hardware Watchdog Timer (One-time enabled with Reset-Out)
    • 2 extra 8-bit I/O ports available on RD2 with high pin count packages
    • Asynchronous port reset
    • Interrupt Structure with
      – 7 Interrupt sources,
      – 4 level priority interrupt system
    • Full duplex Enhanced UART
      – Framing error detection
      – Automatic address recognition
    • Low EMI (inhibit ALE)
    • Power Control modes
      – Idle mode
      – Power-down mode
      – Power-off Flag
    • Once mode (On-chip Emulation)
    • Power supply: 4.5-5V, 2.7-5.5V
    • Temperature ranges: Commercial (0 to 70oC) and Industrial (-40 to 85oC)
    • Packages: PDIL40, PLCC44, VQFP44 1.4, PLCC68, VQFP64 1.4
    TS83C51RC2 订购型号
    Part Number 电源供应 订购型号 封装
    TS83C51RC2 5V OBSOLETE
    PDIL40 PLCC44 VQFP44
    TS83C51RC2 替代型号
    Part Number Memory size Supply Voltage Temperature Range Max Frequency Package Packing
    AT83C51RC2-3CSUM ROM 32k Bytes 5V Industrial Green 40 MHz (20 MHz X2) PDIL40 Stick
    AT83C51RC2-SLSUM ROM 32k Bytes 5V Industrial Green 40 MHz (20 MHz X2) PLCC44 Stick
    AT83C51RC2-RLTUM ROM 32k Bytes 5V Industrial Green 40 MHz (20 MHz X2) VQFP44 Tray
    AT83C51RC2-3CSUL ROM 32k Bytes 3-5V Industrial Green 30 MHz (20 MHz X2) PDIL40 Stick
    AT83C51RC2-SLSUL ROM 32k Bytes 5V Industrial Green 30 MHz (20 MHz X2) PLCC44 Stick
    AT83C51RC2-RLTUL ROM 32k Bytes 3-5V Industrial Green 30 MHz (20 MHz X2) VQFP44 Tray
    TS83C51RC2 技术支持
    1. TS83C51RC2 数据手册DataSheet 下载. PDF
    8051 结构单片机技术支持
    1. 《新闻报道》Atmel 新的單周期8051核心帶來顯著的性能提高與低能耗
    2. 《技术手册》AT/TSC8x251G2D.PDF
    3. 《技术手册》AT89C2051 .PDF
    4. 《技术手册》AT89C51ID2 Errata .PDF
    5. 《技术手册》AT89LP2052/4052 Rev. C Errata .PDF
    6. 《技术手册》AT89C51CC02, T89C51CC02.PDF
    7. 《技术手册》EMC Improvement Guidelines.PDF
    8. 《技术手册》TS83C51RC2 Reliability Qualification Report .PDF
    9. 《技术手册》External Brown-out Protection for C51 Microcontrollers with Active High Reset Input .PDF
    10. 《技术手册》C51 General Information about Bootloader and In-System Programming.PDF
    11. 《技术手册》How to Calculate the Capacitor of the Reset Input of a C51 Microcontroller .PDF
    12. 《技术手册》TS80C51RA2/TS80C51RD2/TS83C51RB2/TS83C51RC2/TS83C51RD2/TS87C51RB2/TS87C51RC2/TS87C51RD2 AT80C51RA2/A .PDF
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
