龙人旗下深圳市龙芯世纪科技有限公司
  • TS80C31X2 带有128K系统内可编程ROM/OTP存储器
  • 发布时间:2009/7/27 21:36:14   修改时间:2009/7/27 21:36:14 浏览次数:2076
  • 首页ATMEL 爱特梅尔8051单片机
    RAM (Bytes) 128
    F.max (MHz) 60
    Vcc (V) 2.7-5.5
    I/O Pins 32
    UART 1
    16-bit Timers 2
    Packages PDIP 40
    LQFP 44
    PLCC 44
    Pb-Free Packages PDIP 40
    LQFP 44
    PLCC 44
    TS80C31X2 is high performance CMOS and ROMless versions of the 80C51 CMOS single chip 8-bit microcontroller. The TS80C31X2 retains all features of the TSC80C31 with 128 bytes of internal RAM, a 5-source, 4 priority level interrupt system, an on-chip oscilator and two timer/counters. In addition, the TS80C31X2 has a dual data pointer, a more versatile serial channel that facilitates multiprocessor communication (EUART) and a X2 speed improvement mechanism.
    TS80C31X2 特性
    • 80C31 Compatible
    • 8031 pin and instruction compatible
    • Four 8-bit I/O ports
    • Two 16-bit timer/counters
    • 128 bytes scratchpad RAM
    • High-Speed Architecture
    • 40 MHz @ 5V, 30MHz @ 3V
    • X2 Speed Improvement capability (6 clocks/machine cycle)
    • 30 MHz @ 5V, 20 MHz @ 3V (Equivalent to 60 MHz @ 5V, 40 MHz @ 3V)
    • Dual Data Pointer
    • Asynchronous port reset
    • Interrupt Structure with
    • 5 Interrupt sources,
    • 4 priority level interrupt system
    • Full duplex Enhanced UART
    • Framing error detection
    • Automatic address recognition
    • Power Control modes
    • Idle mode
    • Power-down mode
    • Power-off Flag
    • Once mode (On-chip Emulation)
    • Power supply: 4.5-5.5V, 2.7-5.5V
    • Temperature ranges: Commercial (0 to 70oC) and Industrial (-40 to 85oC)
    • Packages: PDIL40, PLCC44, VQFP44 1.4, PQFP F1 (13.9 footprint)
    TS80C31X2 订购型号
    Part Number Memory size Supply Voltage Temperature Range Max Frequency Package Packing
    AT80C31X2-3CSUM ROMLess 5V ±10% Industrial Green 40 MHz (20 MHz X2) PDIL40 Stick
    AT80C31X2-SLSUM Romless 5V ±10% Industrial Green 40 MHz (20 MHz X2) PLCC44 Stick
    AT80C31X2-RLTUM Romless 5V ±10% Industrial Green 40 MHz (20 MHz X2) VQFP44 Tray
    AT80C31X2-3CSUL Romless 2.7 to 5.5V Industrial Green 30 MHz (20 MHz X2) PDIL40 Stick
    AT80C31X2-SLSUL Romless 2.7 to 5.5V Industrial Green 30 MHz (20 MHz X2) PLCC44 Stick
    AT80C31X2-RLTUL ROMLess 2.7 to 5.5V Industrial Green 30 MHz (20 MHz X2) VQFP44 Tray
    AT80C31X2-3CSUV ROMLess 5V ±10% Industrial Green 60 MHz (20 MHz X2) PDIL40 Stick
    AT80C31X2-SLSUV ROMLess 5V ±10% Industrial Green 60 MHz (20 MHz X2) PLCC44 Stick
    AT80C31X2-RLTUV Romless 5V ±10% Industrial Green 60 MHz (20 MHz X2) VQFP44 Tray
    TS80C31X2 技术支持
    1. TS80C31X2 数据手册DataSheet 下载. PDF
    2. 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049)
    3. 80C51在系统Flash编程. PDF (编号:8051 00050)
    4. Device Programmers for 8051 Devices (Other, updated 09/07)
      This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers
    5. Emulators for 80C51 Devices (Other, updated 11/03)
      This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers
    6. Package Adapters of 80C51 Devices (Other, updated 10/04)
      This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
