龙人旗下深圳市龙芯世纪科技有限公司
  • AT89LP4052 带有4K系统内可编程Flash存储器
  • 发布时间:2009/7/27 22:07:01   修改时间:2009/7/27 22:07:01 浏览次数:3443
  • 首页ATMEL 爱特梅尔8051单片机
    Flash (Kbytes)   4
    ISP   SPI
    RAM (Bytes)   256
    F.max (MHz)   20
    Vcc (V)   2.4-5.5
    I/O Pins   15
    UART   1
    16-bit Timers   2
    Watchdog   Yes
    SPI   Yes
    Pb-Free Packages   SOIC (300mil) 20
    TSSOP 20
    PDIP 20
    AT89LP4052 概述
    The AT89LP2052/LP4052 is a low-power, high-performance CMOS 8-bit microcontroller with 2/4K bytes of In-System Programmable Flash memory. The device is manufactured using Atmel's high-density nonvolatile memory technology and is compatible with the industry-standard MCS-51 instruction set. The AT89LP2052/LP4052 is built around an enhanced CPU core that can fetch a single byte from memory every clock cycle. In the classic 8051 architecture, each fetch required 6 clock cycles, forcing instructions to execute in 12, 24 or 48 clock cycles. In the AT89LP2052/LP4052 CPU, instructions need only 1 to 4 clock cycles providing 6 to 12 times more throughput than the standard 8051. Seventy percent of instructions need only as many clock cycles as they have bytes to execute, and most of the remaining instructions require only one additional clock. The enhanced CPU core is capable of 20 MIPS throughput whereas the classic 8051 CPU can deliver only 4 MIPS at the same current consumption. Conversely, at the same throughput as the classic 8051, the new CPU core runs at a much lower speed and thereby greatly reduces power consumption.
    The two timer/counters in the AT89LP2052/LP4052 are enhanced with two new modes. Mode 0 can be configured as a variable 9- to 16-bit timer/counter and Mode 1 can be configured as a 16-bit auto-reload timer/counter. In addition both timer/counters may be configured as 8-bit Pulse Width Modulators with 8-bit prescalers. The I/O ports of the AT89LP2052/LP4052 can be independently configured in one of four operating modes. In quasi-bidirectional mode, the ports operate as in the classic 8051. In input mode, the ports are tri-stated. Push-pull output mode provides full CMOS drivers and open-drain mode provides just a pull-down.
    AT89LP4052 特性
    • Compatible with MCS?51 Products
    • 20 MIPS Throughput at 20 MHz Clock Frequency and 2.4V, 85°C Operating Conditions
    • Single Clock Cycle per Byte Fetch
    • 2/4K Bytes of In-System Programmable (ISP) Flash Memory
      – Serial Interface for Program Downloading
      – 32-byte Fast Page Programming Mode
      – 32-byte User Signature Array
    • 2.4V to 5.5V VCC Operating Range
    • Fully Static Operation: 0 Hz to 20 MHz
    • 2-level Program Memory Lock
    • 256 x 8 Internal RAM
    • Hardware Multiplier
    • 15 Programmable I/O Lines
    • Configurable I/O with Quasi-bidirectional, Input, Push-pull Output, and
      Open-drain Modes
    • Enhanced UART with Automatic Address Recognition and Framing Error Detection
    • Enhanced SPI with Double-buffered Send/Receive
    • Programmable Watchdog Timer with Software Reset
    • 4-level Interrupt Priority
    • Analog Comparator with Selectable Interrupt and Debouncing
    • Two 16-bit Enhanced Timer/Counters with 8-bit PWM
    • Brown-out Detector and Power-off Flag
    • Internal Power-on Reset
    • Low Power Idle and Power-down Modes
    • Interrupt Recovery from Power-down Mode
    AT89LP4052 订购型号
    Speed (MHz)) 电源供应 订购型号 封装 适用范围
    20 2.4V to 5.5V AT89LP4052-20PU
    AT89LP4052-20SU
    AT89LP4052-20XU
    20P3
    20S2
    20X
    工业
    (-40°C to 85°C)
    AT89LP4052 技术支持
    1. AT89LP4052 数据手册DataSheet 下载. PDF
    2. 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049)
    3. 80C51在系统Flash编程. PDF (编号:8051 00050)
    4. Device Programmers for 8051 Devices (Other, updated 09/07)
      This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers
    5. Emulators for 80C51 Devices (Other, updated 11/03)
      This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers
    6. Package Adapters of 80C51 Devices (Other, updated 10/04)
      This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
