龙人旗下深圳市龙芯世纪科技有限公司
  • AT89C51RD2 带有64K系统可编程Flash存储器
  • 发布时间:2009/7/28 15:23:53   修改时间:2009/7/28 15:23:53 浏览次数:5104
  • 首页ATMEL 爱特梅尔8051单片机
    Flash (Kbytes)   64
    ISP   UART
    Self Program Memor   API
    RAM (Bytes)   2048
    F.max (MHz)   60
    Vcc (V)   2.7-5.5
    I/O Pins   32
    UART   1
    16-bit Timers   3
    Watchdog   Yes
    SPI   Yes
    Pb-Free Packages    LQFP 64
     LQFP 44
     PLCC 44
     PLCC 68
    AT89C51RD2 概述
    AT89C51RD2/ED2 is high performance CMOS Flash version of the 80C51 CMOS single chip 8-bit microcontroller. It contains a 64-Kbyte Flash memory block for code and for data.The 64-Kbytes Flash memory can be programmed either in parallel mode or in serial mode with the ISP capability or with software. The programming voltage is internally generated from the standard VCC pin.
    The AT89C51RD2/ED2 retains all of the features of the Atmel 80C52 with 256 bytes of internal RAM, a 9-source 4-level interrupt controller and three timer/counters. The AT89C51ED2 provides 2048 bytes of EEPROM for nonvolatile data storage.
    In addition, the AT89C51RD2/ED2 has a Programmable Counter Array, an XRAM of 1792 bytes, a Hardware Watchdog Timer, SPI interface, Keyboard, a more versatile serial channel that facilitates multiprocessor communication (EUART) and a speed< improvement mechanism (X2 Mode).
    The fully static design of the AT89C51RD2/ED2 allows to reduce system power consumption by bringing the clock frequency down to any value, including DC, without lossof data.The AT89C51RD2/ED2 has 2 software-selectable modes of reduced activity and an 8-bit clock prescaler for further reduction in power consumption. In the Idle mode the CPU is frozen while the peripherals and the interrupt system are still operating.
    In the Powerdown mode the RAM is saved and all other functions are inoperative.
    The added features of the AT89C51RD2/ED2 make it more powerful for applications that need pulse width modulation, high speed I/O and counting capabilities such as alarms, motor control, corded phones, and smart card readers.
    AT89C51RD2 特性
    • 80C52 Compatible
      – 8051 Instruction Compatible
      – Six 8-bit I/O Ports (64 Pins or 68 Pins Versions)
      – Four 8-bit I/O Ports (44 Pins Version)
      – Three 16-bit Timer/Counters
      – 256 Bytes Scratch Pad RAM
      – 9 Interrupt Sources with 4 Priority Levels
    • Integrated Power Monitor (POR/PFD) to Supervise Internal Power Supply
    • ISP (In-System Programming) Using Standard VCC Power Supply
    • 2048 Bytes Boot ROM Contains Low Level Flash Programming Routines and a Default
      Serial Loader
    • High-speed Architecture
      – In Standard Mode:
      40 MHz (Vcc 2.7V to 5.5V, both Internal and external code execution)
      60 MHz (Vcc 4.5V to 5.5V and Internal Code execution only)
      – In X2 mode (6 Clocks/machine cycle)
      20 MHz (Vcc 2.7V to 5.5V, both Internal and external code execution)
      30 MHz (Vcc 4.5V to 5.5V and Internal Code execution only)
    • 64K Bytes On-chip Flash Program/Data Memory
      – Byte and Page (128 Bytes) Erase and Write
      – 100k Write Cycles
    • On-chip 1792 bytes Expanded RAM (XRAM)
      – Software Selectable Size (0, 256, 512, 768, 1024, 1792 Bytes)
      – 768 Bytes Selected at Reset for T89C51RD2 Compatibility
    • On-chip 2048 Bytes EEPROM Block for Data Storage (AT89C51ED2 Only)
      – 100K Write Cycles
    • Dual Data Pointer
    • Variable Length MOVX for Slow RAM/Peripherals
    • Improved X2 Mode with Independent Selection for CPU and Each Peripheral
    • Keyboard Interrupt Interface on Port 1
    • SPI Interface (Master/Slave Mode)
    • 8-bit Clock Prescaler
      ? 16-bit Programmable Counter Array
      – High Speed Output
      – Compare/Capture
      – Pulse Width Modulator
      – Watchdog Timer Capabilities
    • Asynchronous Port Reset
    • Full-duplex Enhanced UART with Dedicated Internal Baud Rate Generator
    • Low EMI (Inhibit ALE)
    • Hardware Watchdog Timer (One-time Enabled with Reset-Out), Power-off Flag
    • Power Control Modes: Idle Mode, Power-down Mode
    • Single Range Power Supply: 2.7V to 5.5V
    • Industrial Temperature Range (-40 to +85°C)
    • Packages: PLCC44, VQFP44, PLCC68, VQFP64
    AT89C51RD2 订购型号
    Part Number Data EEPROM SupplyVoltage TemperatureRange Package Packing ProductMarking
    AT89C51RD2-SLSUM No 2.7V - 5.5V Industrial
    Green
    PLCC44 Stick AT89C51RD2-UM
    AT89C51RD2-RLTUM 2.7V - 5.5V Industrial
    Green
    VQFP44 Tray AT89C51RD2-UM
    AT89C51RD2-RDTUM 2.7V - 5.5V Industrial
    Green
    VQFP64 Tray AT89C51RD2-UM
    AT89C51RD2-SMSUM 2.7V - 5.5V Industrial
    Green
    PLCC68 Stick AT89C51RD2-UM
    AT89C51RD2 技术支持
    1. AT89C51RD2数据手册DataSheet 下载. PDF
    2. 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049)
    3. 80C51在系统Flash编程. PDF (编号:8051 00050)
    4. Device Programmers for 8051 Devices (Other, updated 09/07)
      This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers
    5. Emulators for 80C51 Devices (Other, updated 11/03)
      This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers
    6. Package Adapters of 80C51 Devices (Other, updated 10/04)
      This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
