龙人旗下深圳市龙芯世纪科技有限公司
  • 汽车级 ATtiny84 带有8K系统内可编程Flash存储器
  • 发布时间:2009/8/6 9:35:39   修改时间:2009/8/6 9:35:39 浏览次数:1295
    Flash (Kbytes)   8
    EEPROM (Kbytes)   0.5
    SRAM (Bytes)   512
    Max I/O Pins   12
    F.max (MHz)   16
    Vcc (V)   2.7-5.5
    16-bit Timers   1
    8-bit Timer   1
    PWM (channels)   4
    SPI   USI
    TWI   USI
    ISP   Yes
    10-bit A/D (Channe   8
    Analog Comparator   Yes
    Brown Out Detector   Yes
    Watchdog   Yes
    On Chip Oscillator   Yes
    Interrupts   17
    Ext Interrupts   12
    Self Program Memor   Yes
    绿色封装   VQFN (Sawn) 20
    SOIC (150mil) 14
    8K Bytes of In-System Self-Programmable Flash, 512 Bytes In-System Programmable EEPROM, 512 Bytes Internal SRAM. 8-bit and 16-bit timer/counters with PWM, 10-bit ADC, USI-Universal Serial Interface, On-chip Temperature Sensor. debugWIRE for on-chip-debug. Up to 16 MIPS throughput at 16 MHz. 2.7 - 5.5 V operation.
    The ATtiny24/44/84 is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC architecture. By executing powerful instructions in a single clock cycle, the ATtiny24/44/84 achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
    ATtiny84 特性
    • High Performance, Low Power AVR? 8-Bit Microcontroller
    • Advanced RISC Architecture
      – 120 Powerful Instructions – Most Single Clock Cycle Execution
      – 32 x 8 General Purpose Working Registers
      – Fully Static Operation
    • Non-Volatile Program and Data Memories
      – 2/4/8K Bytes of In-System Programmable Program Memory Flash
    • Endurance: 10,000 Write/Erase Cycles
      – 128/256/512 Bytes of In-System Programmable EEPROM
    • Endurance: 100,000 Write/Erase Cycles
      – 128/256/512 Bytes of Internal SRAM
      – Data retention: 20 years at 85°C / 100 years at 25°C
      – Programming Lock for Self-Programming Flash & EEPROM Data Security
    • Peripheral Features
      – One 8-Bit and One 16-Bit Timer/Counter with Two PWM Channels, Each
      – 10-bit ADC
    • 8 Single-Ended Channels
    • 12 Differential ADC Channel Pairs with Programmable Gain (1x / 20x)
      – Programmable Watchdog Timer with Separate On-chip Oscillator
      – On-Chip Analog Comparator
      – Universal Serial Interface
    • Special Microcontroller Features
      – debugWIRE On-chip Debug System
      – In-System Programmable via SPI Port
      – Internal and External Interrupt Sources: Pin Change Interrupt on 12 Pins
      – Low Power Idle, ADC Noise Reduction, Standby and Power-Down Modes
      – Enhanced Power-on Reset Circuit
      – Programmable Brown-Out Detection Circuit
      – Internal Calibrated Oscillator
      – On-Chip Temperature Sensor
    • I/O and Packages
      – Available in 20-Pin QFN/MLF & 14-Pin SOIC and PDIP
      – Twelve Programmable I/O Lines
    • Operating Voltage:
      – 1.8 – 5.5V for ATtiny24V/44V/84V
      – 2.7 – 5.5V for ATtiny24/44/84
    • Speed Grade
      – ATtiny24V/44V/84V
    • 0 – 4 MHz @ 1.8 – 5.5V
    • 0 – 10 MHz @ 2.7 – 5.5V
      – ATtiny24/44/84
    • 0 – 20 MHz @ 4.5 – 5.5V
    • Industrial Temperature Range: -40°C to +85°C
    • Low Power Consumption
      – Active Mode (1 MHz System Clock): 300 μA @ 1.8V
      – Power-down Mode: 0.1 μA @ 1.8V
    ATtiny84汽车级 相关订购型号
    Speed (MHz) Power Supply Ordering Code Package Operational Range
    16 2.7 - 5.5V ATtiny84-15MZ PC Automotive (-40° to +125°C)
    ATtiny84 技术支持
    1. ATtiny84 数据手册DataSheet 在线下载(简洁版)
    2. ATtiny84 数据手册DataSheet 在线下载(完整版)
    3. Atmel 爱特梅尔AVR 微控制器简介.PDF
    4. 面向新手的AVR开发工具,及基本知识.PDF
    5. 使用AVR 定时/计数器的PWM功能设计要点 .PDF
    6. AVR指令集(版本:0856G–AVR–07/08)
    7. 相关产品选型Excel 文档格式选型 Excel 文档格式)
    8. AVR 微控制器汽车应用解决方案 . pdf
    9. AVR 微控制器选型指南. pdf
    10. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
