龙人旗下深圳市龙芯世纪科技有限公司
  • ATmega48PA 带有4K系统内可编程Flash存储器
  • 发布时间:2009/8/7 10:35:53   修改时间:2009/8/7 10:35:53 浏览次数:2483
    Flash (Kbytes) 4
    EEPROM (Kbytes) 0.25
    SRAM (Bytes) 512
    Max I/O Pins 23
    F.max (MHz) 20
    Vcc (V) 1.8-5.5
    10-bit A/D Channels 8
    Analog Comparator Yes
    16-bit Timers 1
    8-bit Timer 2
    Brown Out Detector Yes
    Ext Interrupts 26
    Hardware Multiplier Yes
    Interrupts 26
    ISP Yes
    On Chip Oscillator Yes
    PWM Channels 6
    RTC Yes
    Self Program Memory Yes
    SPI 1+USART
    TWI Yes
    UART 1
    Watchdog Yes
    Pb-Free Packages MLF (VQFN) 28
     MLF (VQFN) 32
     PDIP 28
     TQFP 32
    4K byte self-programming Flash Program Memory, 512 byte SRAM, 256 Byte EEPROM, 8 Channel 10-bit A/D-converter(TQFP and QFN/MLF). debugWIRE On-chip Debug System. Up to 20 MIPS throughput at 20 MHz.
    • 4KB 系统内可编程Flash存储器:ATmega48PA
    • 8KB 系统内可编程Flash存储器:ATmega88PA
    The ATmega48PA/88PA is a low-power CMOS 8-bit microcontroller based on the AVR
    enhanced RISC architecture. By executing powerful instructions in a single clock cycle, the
    ATmega48PA/88PA achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
    ATmega48PA 产品特性
    • ? High Performance, Low Power AVR? 8-Bit Microcontroller
      ? Advanced RISC Architecture
      – 131 Powerful Instructions – Most Single Clock Cycle Execution
      – 32 x 8 General Purpose Working Registers
      – Fully Static Operation
      – Up to 20 MIPS Throughput at 20 MHz
      – On-chip 2-cycle Multiplier
      ? High Endurance Non-volatile Memory Segments
      – 4K/8K Bytes of In-System Self-Programmable Flash progam memory
      (ATmega48PA/88PA)
      – 256/512 Bytes EEPROM (ATmega48PA/88PA)
      – 512/1K Bytes Internal SRAM (ATmega48PA/88PA)
      – Write/Erase Cycles: 10,000 Flash/100,000 EEPROM
      – Data retention: 20 years at 85°C/100 years at 25°C(1)
      – Optional Boot Code Section with Independent Lock Bits
      In-System Programming by On-chip Boot Program
      True Read-While-Write Operation
      – Programming Lock for Software Security
      ? Peripheral Features
      – Two 8-bit Timer/Counters with Separate Prescaler and Compare Mode
      – One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture
      Mode
      – Real Time Counter with Separate Oscillator
      – Six PWM Channels
      – 8-channel 10-bit ADC in TQFP and QFN/MLF package
      Temperature Measurement
      – 6-channel 10-bit ADC in PDIP Package
      – Programmable Serial USART
      – Master/Slave SPI Serial Interface
      – Byte-oriented 2-wire Serial Interface (Philips I2C compatible)
      – Programmable Watchdog Timer with Separate On-chip Oscillator
      – On-chip Analog Comparator
      – Interrupt and Wake-up on Pin Change
      ? Special Microcontroller Features
      – Power-on Reset and Programmable Brown-out Detection
      – Internal Calibrated Oscillator
      – External and Internal Interrupt Sources
      – Six Sleep Modes: Idle, ADC Noise Reduction, Power-save, Power-down, Standby,
      and Extended Standby
      ? I/O and Packages
      – 23 Programmable I/O Lines
      – 28-pin PDIP, 32-lead TQFP, 28-pad QFN/MLF and 32-pad QFN/MLF
      ? Operating Voltage:
      – 1.8 - 5.5V for ATmega48PA/88PA
      ? Temperature Range:
      – -40?C to 85?C
      ? Speed Grade:
      – 0 - 20 MHz @ 1.8 - 5.5V
      ? Low Power Consumption at 1 MHz, 1.8V, 25?C for ATmega48PA/88PA:
      – Active Mode: 0.2 mA
      – Power-down Mode: 0.1 μA
      – Power-save Mode: 0.75 μA (Including 32 kHz RTC)
    ATmega48PA 订购型号
    速度 (MHz) 所需电源 产品号 封装 工作范围
    20 1.8 - 5.5 ATmega48PA-AU
    ATmega48PA-MMH
    ATmega48PA-MU
    ATmega48PA-PU
    32A
    28M1
    32M1-A
    28P3
    Industrial(-40°C - 85°C)
    ATmega48PA 技术支持
    1. ATMEL 爱特梅尔AVR 微控制器ATmega48PA 数据手册DataSheet 下载. PDF(简洁版)
    2. ATMEL 爱特梅尔AVR 微控制器ATmega48PA 数据手册DataSheet 下载. PDF(完整版)
    3. Atmel 爱特梅尔AVR 微控制器简介.PDF (编号:Tech AVR 000)MLF 32
    4. 面向新手的AVR 开发工具,及基本知识.PDF(编号:Tech AVR 001)
    5. 使用AVR 定时/计数器的PWM功能设计要点 .PDF (编号:Tech AVR 002)
    6. AVR指令集(版本:0856G–AVR–07/08)
    7. 相关产品选型Excel 文档格式选型 Excel 文档格式)
    8. AVR 微控制器汽车应用解决方案 . pdf
    9. AVR 微控制器选型指南. pdf
    10. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
