龙人旗下深圳市龙芯世纪科技有限公司
  • ATtiny88 带有8K系统内可编程Flash存储器
  • 发布时间:2009/8/8 9:04:21   修改时间:2009/8/8 9:04:21 浏览次数:1210
    Flash (Kbytes) 8
    EEPROM (Kbytes) 0.0625
    SRAM (Bytes) 512
    Max I/O Pins 24/28
    F.max (MHz) 12
    Vcc (V) 1.8 - 5.5
    10-bit A/D Channels 37415
    Analog Comparator Yes
    16-bit Timers 1
    8-bit Timer 1
    Brown Out Detector Yes
    Ext Interrupts 30
    Interrupts 20
    ISP Yes
    On Chip Oscillator Yes
    PWM Channels 1
    Self Program Memory Yes
    SPI Yes
    TWI Yes
    Watchdog Yes
    Pb-Free Packages MLF (VQFN) 28
    MLF (VQFN) 32
    PDIP 28
    TQFP 32
    8K Bytes of In-System Self-Programmable Flash, 64 Bytes In-System Programmable EEPROM, 512 Bytes Internal SRAM. 8-bit timer/counter and 16-bit timer/counter with PWM, 10-bit ADC, SPI-Serial Peripheral Interface. debugWIRE for on-chip-debug. Up to 12 MIPS throughput at 12 MHz. 1.8 - 5.5 V operation.
    The ATtiny48/88 is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC architecture. By executing powerful instructions in a single clock cycle, the ATtiny48/88 achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
    ATtiny88 特性
    • High Performance, Low Power AVR? 8-Bit Microcontroller
    • Advanced RISC Architecture
      – 123 Powerful Instructions – Most Single Clock Cycle Execution
      – 32 x 8 General Purpose Working Registers
      – Fully Static Operation
    • High Endurance Non-volatile Memory Segments
      – 4K/8K Bytes of In-System Self-Programmable Flash program memory(ATtiny48/88)
      – 64/64 Bytes EEPROM (ATtiny48/88)
      – 256/512 Bytes Internal SRAM (ATtiny48/88)
      – Write/Erase Cycles: 10,000 Flash/100,000 EEPROM
      – Data retention: 20 years at 85°C / 100 years at 25°C
      – Optional Boot Code Section with Indepentent Lock Bits
    • In-System Programming by On-chip Boot Program
    • True Read-While-Write Operation
      – Programming Lock for Software Security
    • Peripheral Features
      – One 8-bit Timer/Counter with Separate Prescaler and Compare Mode
      – One 16-bit Timer/Counter with Prescaler, and Compare and Capture Modes
      – 8-channel 10-bit ADC in 32-lead TQFP and 32-pad QFN/MLF package
      – 6-channel 10-bit ADC in 28-pin PDIP and 28-pad QFN/MLF package
      – Master/Slave SPI Serial Interface
      – Byte-oriented 2-wire Serial Interface (Philips I2C Compatible)
      – Programmable Watchdog Timer with Separate On-chip Oscillator
      – On-chip Analog Comparator
      – Interrupt and Wake-up on Pin Change
    • Special Microcontroller Features
      – debugWIRE On-chip Debug System
      – In-System Programmable via SPI Port
      – Power-on Reset and Programmable Brown-out Detection
      – Internal Calibrated Oscillator
      – External and Internal Interrupt Sources
      – Three Sleep Modes: Idle, ADC Noise Reduction and Power-down
    • I/O and Packages
      – 28 Programmable I/O Lines in 32-lead TQFP and 32-pad QFN/MLF package
      – 24 Programmable I/O Lines in 28-pin PDIP and 28-pad QFN/MLF package
      – 28-pin PDIP, 32-lead TQFP, 28-pad QFN/MLF and 32-pad QFN/MLF
    • Operating Voltage:
      – 1.8 – 5.5V
    • Temperature Range:
      – -40°C to +85°C
    • Speed Grade:
      – 0 – 2 MHz @ 1.8 – 5.5V
      – 0 – 6 MHz @ 2.7 – 5.5V
      – 0 – 12 MHz @ 4.5 – 5.5V
    • Low Power Consumption
      – Active Mode: 1 MHz, 1.8V: 240μA
      – Power-down Mode: 0.1μA at 1.8V
    ATtiny88 订购型号
    Speed (MHz) Power Supply Ordering Code Package Operational Range
    12 1.8 – 5.5 ATtiny88-AU
    ATtiny88-MMU
    ATtiny88-MMH
    ATtiny88-MU
    ATtiny88-PU
    32A
    28M1
    28M1
    32M1-A
    28P3
    Industrial (-40°C to 85°C)
    ATtiny88 技术支持
    1. ATMEL 爱特梅尔AVR 微控制器ATtiny88 中文数据手册DataSheet 下载 .PDF
    2. Atmel 爱特梅尔AVR 微控制器简介.PDF
    3. 面向新手的AVR开发工具,及基本知识.PDF
    4. 使用AVR 定时/计数器的PWM功能设计要点 .PDF
    5. AVR指令集(版本:0856G–AVR–07/08)
    6. 相关产品选型Excel 文档格式选型 Excel 文档格式)
    7. AVR 微控制器汽车应用解决方案 . pdf
    8. AVR 微控制器选型指南. pdf
    9. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
