龙人旗下深圳市龙芯世纪科技有限公司
  • AT90USB162 带有16K ISP Flash存储器
  • 发布时间:2009/8/8 9:14:19   修改时间:2009/8/8 9:14:19 浏览次数:1801
    Flash (Kbytes) 16
    EEPROM (Kbytes) 0.5
    SRAM (Bytes) 512
    Max I/O Pins 22
    Pb-Free Packages   VQFN (Sawn)
    32
     TQFP 32
    16-Kbyte self-programming Flash Program Memory, 512-byte SRAM, 512-byte EEPROM. DebugWire interface for on-chip-debug. Up to 16 MIPS throughput at 16 MHz. 2.7 - 5.5 Volt operation.
    • 8KB 系统内可编程Flash存储器 :AT90USB82
    • 16KB 系统内可编程Flash存储器 :AT90USB162
    The AT90USB82/162 is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC architecture. By executing powerful instructions in a single clock cycle, the AT90USB82/162 achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
    AT90USB162 特性
    • High Performance, Low Power AVR? 8-Bit Microcontroller
    • Advanced RISC Architecture
      – 125 Powerful Instructions – Most Single Clock Cycle Execution
      – 32 x 8 General Purpose Working Registers
      – Fully Static Operation
      – Up to 16 MIPS Throughput at 16 MHz
    • Non-volatile Program and Data Memories
      – 8K / 16K Bytes of In-System Self-Programmable Flash
    • Endurance: 10,000 Write/Erase Cycles
      – Optional Boot Code Section with Independent Lock Bits
    • USB boot-loader programmed by default in the factory
    • In-System Programming by on-chip Boot Program hardware-activated after
      reset
    • True Read-While-Write Operation
      – 512 Bytes EEPROM
    • Endurance: 100,000 Write/Erase Cycles
      – 512 Bytes Internal SRAM
      – Programming Lock for Software Security
    • USB 2.0 Full-speed Device Module with Interrupt on Transfer Completion
      – Complies fully with Universal Serial Bus Specification REV 2.0
      – 48 MHz PLL for Full-speed Bus Operation : data transfer rates at 12 Mbit/s
      – Fully independant 176 bytes USB DPRAM for endpoint memory allocation
      – Endpoint 0 for Control Transfers: from 8 up to 64-bytes
      – 4 Programmable Endpoints:
    • IN or Out Directions
    • Bulk, Interrupt and IsochronousTransfers
    • Programmable maximum packet size from 8 to 64 bytes
    • Programmable single or double buffer
      – Suspend/Resume Interrupts
      – Microcontroller reset on USB Bus Reset without detach
      – USB Bus Disconnection on Microcontroller Request
      – USB pad multiplexed with PS/2 peripheral for single cable capability
    • Peripheral Features
      – PS/2 compliant pad
      – One 8-bit Timer/Counters with Separate Prescaler and Compare Mode (two 8-bit
      PWM channels)
      – One 16-bit Timer/Counter with Separate Prescaler, Compare and Capture Mode
      (three 8-bit PWM channels)
      – USART with SPI master only mode and hardware flow control (RTS/CTS)
      – Master/Slave SPI Serial Interface
      – Programmable Watchdog Timer with Separate On-chip Oscillator
      – On-chip Analog Comparator
      – Interrupt and Wake-up on Pin Change
    • On Chip Debug Interface (debugWIRE)
    • Special Microcontroller Features
      – Power-On Reset and Programmable Brown-out Detection
      – Internal Calibrated Oscillator
      – External and Internal Interrupt Sources
      – Five Sleep Modes: Idle, Power-save, Power-down, Standby, and Extended Standby
    • I/O and Packages
      – 22 Programable I/O Lines
      – QFN32 (5x5mm) / TQFP32 packages
    • Operating Voltages
      – 2.7 - 5.5V
    • Operating temperature
      – Industrial (-40°C to +85°C)
    • Maximum Frequency
      – 8 MHz at 2.7V - Industrial range
      – 16 MHz at 4.5V - Industrial range
    AT90USB162 订购型号
    Part Number Temp. Range Flash Memory Size Package Product Marking
    AT90USB162-16MU Industrial Green 16K QFN32 90USB162-16MU
    AT90USB162-16AU Industrial Green 16K TQFP32 90USB162-16AU
    AT90USB162 技术支持
    1. ATMEL 爱特梅尔USB 微控制器AT90USB162 数据手册DataSheet 下载. PDF(完整版)
    2. ATMEL 爱特梅尔USB 微控制器AT90USB162 数据手册DataSheet 下载. PDF(简洁版)
    3. 使用USB 定时/计数器的PWM功能设计要点 .PDF (编号:Tech USB 00045)
    4. Atmel 爱特梅尔USB 微控制器简介.PDF (编号:Tech USB 00047)
    5. USB指令集(版本:)
    6. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
