龙人旗下深圳市龙芯世纪科技有限公司
  • ATmega32U4 带有32K系统内可编程Flash存储器
  • 发布时间:2009/8/8 9:19:00   修改时间:2009/8/8 9:19:00 浏览次数:2450
    Flash (Kbytes) 32
    EEPROM (Kbytes) 1
    SRAM (Bytes) 2.5K
    Max I/O Pins 26
    Pb-Free Packages VQFN(Sawn)44
    TQFP44
    32-Kbytes of In-System Programmable Flash, 1-Kbyte EEPROM, 2.5-Kbytes SRAM, USB 2.0 Full-speed/Low Speed Device Module. High-speed PWMs, 12-channel 10-bit ADC. JTAG test interface. Up to 16 MIPS Throughput at 16 MHz. 2.7 - 5.5 Volt operation.
    • 16KB 系统内可编程Flash存储器 :ATmega16U4
    • 32KB 系统内可编程Flash存储器 : ATmega32U4
    The ATmega16U4/ATmega32U4 is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC architecture. By executing powerful instructions in a single clock cycle, the ATmega16U4/ATmega32U4 achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
    ATmega32U4 特性
    • High Performance, Low Power AVR? 8-Bit Microcontroller
    • Advanced RISC Architecture
      – 135 Powerful Instructions – Most Single Clock Cycle Execution
      – 32 x 8 General Purpose Working Registers
      – Fully Static Operation
      – Up to 16 MIPS Throughput at 16 MHz
      – On-Chip 2-cycle Multiplier
    • Non-volatile Program and Data Memories
      – 32K Bytes of In-System Self-Programmable Flash
    • Endurance: 100,000 Write/Erase Cycles
      – Optional Boot Code Section with Independent Lock Bits
    • In-System Programming by On-chip Boot Program hardware activated after
      reset
    • True Read-While-Write Operation
    • All supplied parts are preprogramed with a default USB bootloader
      – 2.5K Bytes Internal SRAM
      – 1K Bytes Internal EEPROM
      – Programming Lock for Software Security
    • JTAG (IEEE std. 1149.1 compliant) Interface
      – Boundary-scan Capabilities According to the JTAG Standard
      – Extensive On-chip Debug Support
      – Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface
    • USB 2.0 Full-speed/Low Speed Device Module with Interrupt on Transfer Completion
      – Complies fully with Universal Serial Bus Specification Rev 2.0
      – Supports data transfer rates up to 12 Mbit/s and 1.5 Mbit/s
      – Endpoint 0 for Control Transfers: up to 64-bytes
      – 6 Programmable Endpoints with IN or Out Directions and with Bulk, Interrupt or
      Isochronous Transfers
      – Configurable Endpoints size up to 256 bytes in double bank mode
      – Fully independent 832 bytes USB DPRAM for endpoint memory allocation
      – Suspend/Resume Interrupts
      – CPU Reset possible on USB Bus Reset detection
      – 48 MHz from PLL for Full-speed Bus Operation
      – USB Bus Connection/Disconnection on Microcontroller Request
    • Peripheral Features
      – On-chip PLL for USB and High Speed Timer: 32 up to 96 MHz operation
      – Two 8-bit Timer/Counters with Separate Prescaler and Compare Mode
      – Two 16-bit Timer/Counter with Separate Prescaler, Compare- and Capture Mode
      – One 10-bit High-Speed Timer/Counter with PLL (64 MHz) and Compare Mode
      – Four 8-bit PWM Channels
      – Four PWM Channels with Programmable Resolution from 2 to 16 Bits
      – Six PWM Channels for High Speed Operation, with Programmable Resolution from
      2 to 11 Bits
      – Output Compare Modulator
      – 12-channels, 10-bit ADC (features Differential Channels with Programmable Gain)
      – Programmable Serial USART with Hardware Flow Control
      – Master/Slave SPI Serial Interface
    • – Byte Oriented 2-wire Serial Interface
      – Programmable Watchdog Timer with Separate On-chip Oscillator
      – On-chip Analog Comparator
      – Interrupt and Wake-up on Pin Change (8xPCINT + 5xINT sources)
      – On-chip Temperature Sensor (see A/D Converter section)
    • Special Microcontroller Features
      – Power-on Reset and Programmable Brown-out Detection
      – Internal 8 MHz Calibrated Oscillator
      – Internal clock prescaler & On-the-fly Clock Switching (Int RC / Ext Osc)
      – External and Internal Interrupt Sources
      – Six Sleep Modes: Idle, ADC Noise Reduction, Power-save, Power-down, Standby, and Extended Standby
    • I/O and Packages
      – All I/O combine CMOS outputs and LVTTL inputs
      – 26 Programmable I/O Lines
      – 44-lead TQFP Package, 10x10mm
      – 44-lead QFN Package, 7x7mm
    • Operating Voltages
      – 2.7 - 5.5V
    • Operating temperature
      – Industrial (-40°C to +85°C)
    • Maximum Frequency
      – 8 MHz at 2.7V - Industrial range
      – 16 MHz at 4.5V - Industrial range
    ATmega32U4 订购型号
    Speed (MHz) Power Supply Ordering Code Package Operation Range
    16 2.7-5.5 ATmega32U4-AU 44ML Industrial (-40° to +85°C)
    ATmega32U4-MU 44PW
    ATmega32U4 技术支持
    1. ATMEL 爱特梅尔USB 微控制器AT90USB32U4 数据手册DataSheet 下载. PDF
    2. 使用USB 定时/计数器的PWM功能设计要点 .PDF (编号:Tech USB 00045)
    3. Atmel 爱特梅尔USB 微控制器简介.PDF (编号:Tech USB 00047)
    4. USB指令集(版本:)
    5. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
