龙人旗下深圳市龙芯世纪科技有限公司
  • ATxmega16A4
  • 发布时间:2009/8/8 9:22:50   修改时间:2009/8/8 9:22:50 浏览次数:1046
  • ATxmega16A4
    ATxmega16A4 特性
    • High-performance, Low-power AVR 8/16-bit AVR XMEGA Microcontroller
    • Non-volatile Program and Data Memories
      – 16K - 128K Bytes of In-System Self-Programmable Flash
      – 4K Boot Code Section with Independent Lock Bits
      – 1K - 2K Bytes EEPROM
      – 2K - 8K Bytes Internal SRAM
    • Peripheral Features
      – Four-channel DMA Controller with support for external requests
      – Eight-channel Event System
      – Five 16-bit Timer/Counters
      Three Timer/Counters with 4 Output Compare or Input Capture channels
      Two Timer/Counters with 2 Output Compare or Input Capture channels
      High-Resolution Extensions on all Timer/Counters
      Advanced Waveform Extension on one Timer/Counter
      – Five USARTs
      IrDA Extension on one USART
      – Two Two-Wire Interfaces with dual address match (I2C and SMBus compatible)
      – Two SPIs (Serial Peripheral Interfaces) peripherals
      – AES and DES Crypto Engine
      – 16-bit Real Time Counter with Separate Oscillator
      – One Twelve-channel, 12-bit, 2 Msps Analog to Digital Converter
      – One Two-channel, 12-bit, 1 Msps Digital to Analog Converter
      – Two Analog Comparators with Window compare function
      – External Interrupts on all General Purpose I/O pins
      – Programmable Watchdog Timer with Separate On-chip Ultra Low Power Oscillator
    • Special Microcontroller Features
      – Power-on Reset and Programmable Brown-out Detection
      – Internal and External Clock Options with PLL
      – Programmable Multi-level Interrupt Controller
      – Sleep Modes: Idle, Power-down, Standby, Power-save, Extended Standby
      – Advanced Programming, Test and Debugging Interfaces
      PDI (Program and Debug Interface) for programming, test and debugging
    • I/O and Packages
      – 36 Programmable I/O Lines
      – 44-lead TQFP
      – 44-pad MLF
    • Operating Voltage
      – 1.6 – 3.6V
    • Speed performance
      – 0 – 12 MHz @ 1.6 – 2.7V
      – 0 – 32 MHz @ 2.7 – 3.6V
    ATxmega16A4 概述
    The XMEGA A4 is a family of low power, high performance and peripheral rich CMOS 8/16-bit
    microcontrollers based on the AVR?enhanced RISC architecture. By executing powerful
    instructions in a single clock cycle, the XMEGA A4 achieves throughputs approaching 1 Million
    Instructions Per Second (MIPS) per MHz allowing the system designer to optimize power consumption versus processing speed.
    The AVR CPU combines a rich instruction set with 32 general purpose working registers. All the
    32 registers are directly connected to the Arithmetic Logic Unit (ALU), allowing two independent
    registers to be accessed in one single instruction, executed in one clock cycle. The resulting
    architecture is more code efficient while achieving throughputs many times faster than conventional
    single-accumulator or CISC based microcontrollers.
    The XMEGA A4 devices provides the following features: In-System Programmable Flash with
    Read-While-Write capabilities, Internal EEPROM and SRAM, four-channel DMA Controller,
    eight-channel Event System, Programmable Multi-level Interrupt Controller, 36 general purpose
    I/O lines, 16-bit Real Time Counter (RTC), five flexible 16-bit Timer/Counters with compare
    modes and PWM, five USARTs, two Two Wire Serial Interfaces (TWIs), two Serial Peripheral
    Interfaces (SPIs), AES and DES crypto engine, one Twelve-channel, 12-bit ADC with optional
    differential input with programmable gain, one Two-channel, 12-bit DAC, two analog comparators
    with window mode, programmable Watchdog Timer with separate Internal Oscillator,
    accurate internal oscillators with PLL and prescaler and programmable Brown-Out Detection.
    The Program and Debug Interface (PDI), a fast 2-pin interface for programming and debugging,
    is available.
    The XMEGA A4 devices have five software selectable power saving modes. The Idle mode
    stops the CPU while allowing the SRAM, DMA Controller, Event System, Interrupt Controller and
    all peripherals to continue functioning. The Power-down mode saves the SRAM and register
    contents but stops the oscillators, disabling all other functions until the next TWI or pin-change
    interrupt, or Reset. In Power-save mode, the asynchronous Real Time Counter continues to run,
    allowing the application to maintain a timer base while the rest of the device is sleeping. In
    Standby mode, the Crystal/Resonator Oscillator is kept running while the rest of the device is
    sleeping. This allows very fast start-up from external crystal combined with low power consumption.
    In Extended Standby mode, both the main Oscillator and the Asynchronous Timer continue
    to run. To further reduce power consumption, the peripheral clock to each individual peripheral
    can optionally be stopped in Active mode and in Idle sleep mode.
    The device is manufactured using Atmel's high-density nonvolatile memory technology. The program
    Flash memory can be reprogrammed in-system through the PDI. A Bootloader running in
    the device can use any interface to download the application program to the Flash memory. The
    Bootloader software in the Boot Flash section will continue to run while the Application Flash
    section is updated, providing true Read-While-Write operation. By combining an 8/16-bit RISC
    CPU with In-System Self-Programmable Flash, the Atmel XMEGA A4 is a powerful microcontroller
    family that provides a highly flexible and cost effective solution for many embedded
    applications.
    The XMEGA A4 devices is supported with a full suite of program and system development tools
    including: C compilers, macro assemblers, program debugger/simulators, programmers, and
    evaluation kits.
    ATxmega16A4 订购型号
    Ordering Code Flash (B) E2 (B) SRAM (B) Speed (MHz) Power Supply Package Temp
    ATxmega16A4-AU 16K + 4K 1K 2K 32 1.6 - 3.6V 44A -40° - 85°C
    ATxmega16A4-MU 16K + 4K 1K 2K 32 1.6 - 3.6V 44M1 -40° - 85°C
    ATxmega16A4 技术支持
    1. ATMEL 爱特梅尔AVR 微控制器 ATxmega16A4 中文数据手册DataSheet 下载. PDF
    2. ATMEL 爱特梅尔AVR 微控制器ATxmega16A4 数据手册DataSheet 下载. PDF
    3. ATMEL 爱特梅尔半导体公司产品线. PDF (编号:Atmel Products)
    4. Atmel 爱特梅尔AVR 微控制器简介.PDF (编号:Tech AVR 000)MLF32
    5. 面向新手的AVR开发工具,及基本知识.PDF(编号:Tech AVR 001)
    6. 使用AVR 定时/计数器的PWM功能设计要点 .PDF (编号:Tech AVR 002
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
