龙人旗下深圳市龙芯世纪科技有限公司
  • ATxmega192A1
  • 发布时间:2009/8/8 9:23:24   修改时间:2009/8/8 9:23:24 浏览次数:1836
  • ATxmega192A1
    ATxmega192A1 特性
    • High-performance, Low-power 8/16-bit AVR XMEGA Microcontroller
    • Non-Volatile Program and Data Memories
      – 64K - 384K Bytes of In-System Self-Programmable Flash
      – 4K - 8K Bytes Boot Section with Independent Lock Bits
      – 2K - 4K Bytes EEPROM
      – 4K - 32K Bytes Internal SRAM
      External Bus Interface for up to 16M bytes SRAM
      External Bus Interface for up to 128M bit SDRAM
    • Peripheral Features
      – Four-channel DMA Controller with support for external requests
      – Eight-channel Event System
      – Eight 16-bit Timer/Counters
      Four Timer/Counters with 4 Output Compare or Input Capture channels
      Four Timer/Counters with 2 Output Compare or Input Capture channels
      High-Resolution Extension on all Timer/Counters
      Advanced Waveform Extension on two Timer/Counters
      – Eight USARTs
      IrDA modulation/demodulation for one USART
      – Four Two-Wire Interfaces with dual address match (I2C and SMBus compatible)
      – Four SPI (Serial Peripheral Interface) peripherals
      – AES and DES Crypto Engine
      – 16-bit Real Time Counter with separate Oscillator
      – Two Eight-channel, 12-bit, 2 Msps Analog to Digital Converters
      – Two Two-channel, 12-bit, 1 Msps Digital to Analog Converters
      – Four Analog Comparators with Window compare function
      – External Interrupts on all General Purpose I/O pins
      – Programmable Watchdog Timer with Separate On-chip Ultra Low Power Oscillator
    • Special Microcontroller Features
      – Power-on Reset and Programmable Brown-out Detection
      – Internal and External Clock Options with PLL and Prescaler
      – Programmable Multi-level Interrupt Controller
      – Sleep Modes: Idle, Power-down, Standby, Power-save, Extended Standby
      – Advanced Programming, Test and Debugging Interfaces
      JTAG (IEEE 1149.1 Compliant) Interface for programming, test and debugging
      PDI (Program and Debug Interface) for programming and debugging
    • I/O and Packages
      – 78 Programmable I/O Lines
      – 100 - lead TQFP
      – 100 - ball CBGA
    • Operating Voltage
      – 1.6 – 3.6V
    • Speed performance
      – 0 – 12 MHz @ 1.6 – 3.6V
      – 0 – 32 MHz @ 2.7 – 3.6V
    ATxmega192A1 概述
    The XMEGA A1 is a family of low power, high performance and peripheral rich CMOS 8/16-bit
    microcontrollers based on the AVR?enhanced RISC architecture. By executing powerful
    instructions in a single clock cycle, the XMEGA A1 achieves throughputs approaching 1 Million
    Instructions Per Second (MIPS) per MHz allowing the system designer to optimize power consumption versus processing speed.
    The AVR CPU combines a rich instruction set with 32 general purpose working registers. All the
    32 registers are directly connected to the Arithmetic Logic Unit (ALU), allowing two independent
    registers to be accessed in one single instruction, executed in one clock cycle. The resulting
    architecture is more code efficient while achieving throughputs many times faster than conventional
    single-accumulator or CISC based microcontrollers.
    The XMEGA A1 devices provides the following features: In-System Programmable Flash with
    Read-While-Write capabilities, Internal EEPROM and SRAM, four-channel DMA Controller,
    eight-channel Event System, Programmable Multi-level Interrupt Controller, 78 general purpose
    I/O lines, 16-bit Real Time Counter (RTC), eight flexible 16-bit Timer/Counters with compare
    modes and PWM, eight USARTs, four Two Wire Serial Interfaces (TWIs), four Serial Peripheral
    Interfaces (SPIs), AES and DES crypto engine, two 8-channel, 12-bit ADCs with optional differential
    input with programmable gain, two 2-channel, 12-bit DACs, four analog comparators with
    window mode, programmable Watchdog Timer with seperate Internal Oscillator, accurate internal
    oscillators with PLL and prescaler and programmable Brown-Out Detection.
    The Program and Debug Interface (PDI), a fast 2-pin interface for programming and debugging,
    is available. The devices also have an IEEE std. 1149.1 compliant JTAG test interface, and this
    can also be used for On-chip Debug and programming.
    The XMEGA A1 devices have five software selectable power saving modes. The Idle mode
    stops the CPU while allowing the SRAM, DMA Controller, Event System, Interrupt Controller and
    all peripherals to continue functioning. The Power-down mode saves the SRAM and register
    contents but stops the oscillators, disabling all other functions until the next TWI or pin-change
    interrupt, or Reset. In Power-save mode, the asynchronous Real Time Counter continues to run,
    allowing the application to maintain a timer base while the rest of the device is sleeping. In
    Standby mode, the Crystal/Resonator Oscillator is kept running while the rest of the device is
    sleeping. This allows very fast start-up from external crystal combined with low power consumption.
    In Extended Standby mode, both the main Oscillator and the Asynchronous Timer continue
    to run. To further reduce power consumption, the peripheral clock to each individual peripheral
    can optionally be stopped in Active mode and Idle sleep mode.
    The device is manufactured using Atmel's high-density nonvolatile memory technology. The program
    Flash memory can be reprogrammed in-system through the PDI or JTAG. A Bootloader
    running in the device can use any interface to download the application program to the Flash
    memory. The Bootloader software in the Boot Flash section will continue to run while the Application
    Flash section is updated, providing true Read-While-Write operation. By combining an
    8/16-bit RISC CPU with In-System Self-Programmable Flash, the Atmel XMEGA A1 is a powerful
    microcontroller family that provides a highly flexible and cost effective solution for many
    embedded applications.
    The XMEGA A1 devices is supported with a full suite of program and system development tools
    including: C compilers, macro assemblers, program debugger/simulators, programmers, and
    evaluation kits.
    ATxmega192A1 订购型号
    Ordering Code Flash (B) E2 (B) SRAM (B) Speed (MHz) Power Supply Package Temp
    ATxmega192A1-CU 192K + 8K 2K 16K 32 1.6 - 3.6V 100C1 -40° - 85°C
    ATxmega192A1-AU 192K + 8K 2K 16K 32 1.6 - 3.6V 100A -40° - 85°C
    ATxmega192A1 技术支持
    1. ATMEL 爱特梅尔AVR 微控制器 ATxmega192A1 中文数据手册DataSheet 下载. PDF
    2. ATMEL 爱特梅尔AVR 微控制器ATxmega192A1 数据手册DataSheet 下载. PDF
    3. ATMEL 爱特梅尔半导体公司产品线. PDF (编号:Atmel Products)
    4. Atmel 爱特梅尔AVR 微控制器简介.PDF (编号:Tech AVR 000)MLF32
    5. 面向新手的AVR开发工具,及基本知识.PDF(编号:Tech AVR 001)
    6. 使用AVR 定时/计数器的PWM功能设计要点 .PDF (编号:Tech AVR 002)
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
