龙人旗下深圳市龙芯世纪科技有限公司
  • AT89C2051 带有2K系统内可编程Flash存储器
  • 发布时间:2009/8/11 8:39:26   修改时间:2009/8/11 8:39:26 浏览次数:1048
    Flash (Kbytes)   2
    RAM (Bytes)   128
    F.max (MHz)   24
    Vcc (V)   2.7-6.0
    I/O Pins   15
    UART   1
    16-bit Timers   2
    Pb-Free Packages    SOIC 20
    PDIP 20
    AT89C2051 概述
    The AT89C2051 is a low-voltage, high-performance CMOS 8-bit microcomputer with 2K bytes of Flash programmable and erasable read-only memory (PEROM). The device is manufactured using Atmel’s high-density nonvolatile memory technology and is compatible with the industry-standard MCS-51 instruction set. By combining a versatile 8-bit CPU with Flash on a monolithic chip, the Atmel AT89C2051 is a powerful microcomputer which provides a highly-flexible and cost-effective solution to many embedded control applications. The AT89C2051 provides the following standard features: 2K bytes of Flash, 128 bytes of RAM, 15 I/O lines, two 16-bit timer/counters, a five vector two-level interrupt architecture, a full duplex serial port, a precision analog comparator, on-chip oscillator and clock circuitry. In addition, the AT89C2051 is designed with static logic for operation down to zero frequency and supports two software selectable power saving modes. The Idle Mode stops the CPU while allowing the RAM, timer/counters, serial port and interrupt system to continue functioning. The power-down mode saves the RAM contents but freezes the oscillator disabling all other chip functions until the next hardware reset.
    AT89C2051 特性
    • Compatible with MCS?-51Products
    • 2K Bytes of Reprogrammable Flash Memory
      – Endurance: 1,000 Write/Erase Cycles
    • 2.7V to 6V Operating Range
    • Fully Static Operation: 0 Hz to 24 MHz
    • Two-level Program Memory Lock
    • 128 x 8-bit Internal RAM
    • 15 Programmable I/O Lines
    • Two 16-bit Timer/Counters
    • Six Interrupt Sources
    • Programmable Serial UART Channel
    • Direct LED Drive Outputs
    • On-chip Analog Comparator
    • Low-power Idle and Power-down Modes
    • Green (Pb/Halide-free) Packaging Option
    AT89C2051 订购型号
    Speed (MHz) Power
    Supply
    Ordering Code Package Operation Range
    12 2.7V to 6.0V AT89C2051-12PC
    AT89C2051-12SC
    20P3
    20S
    Commercial (0°C to 70°C)
    AT89C2051-12PI
    AT89C2051-12SI
    20P3
    20S
    Industrial (-40°C to 85°C)
    24 4.0V to 6.0V AT89C2051-24PC
    AT89C2051-24SC
    20P3
    20S
    AT89C2051-24PI
    AT89C2051-24SI
    20P3
    20S
    12 2.7V to 6.0V AT89C2051-12PU
    AT89C2051-12SU
    20P3
    20S
    24 4.0V to 6.0V AT89C2051-24PU
    AT89C2051-24SU
    20P3
    20S
    AT89C2051 技术支持
    1. AT89C2051 数据手册DataSheet 下载. PDF
    2. 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049)
    3. 80C51在系统Flash编程. PDF (编号:8051 00050)
    4. Device Programmers for 8051 Devices (Other, updated 09/07)
      This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers
    5. Emulators for 80C51 Devices (Other, updated 11/03)
      This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers
    6. Package Adapters of 80C51 Devices (Other, updated 10/04)
      This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
