龙人旗下深圳市龙芯世纪科技有限公司
  • AT89C55WD 带20K系统内可编程Flash 存储器
  • 发布时间:2009/8/11 8:48:34   修改时间:2009/8/11 8:48:34 浏览次数:2720
    Flash (Kbytes)   20
    RAM (Bytes)   256
    F.max (MHz)   33
    Vcc (V)   4.0-6.0
    I/O Pins   32
    UART   1
    16-bit Timers   3
    Watchdog   Yes
    Pb-Free Packages   TQFP44
    PDIP40
    PLCC44
    AT89C55WD 概述
    The AT89C55WD is a low-power, high-performance CMOS 8-bit microcontroller with 20K bytes of Flash programmable read only memory and 256 bytes of RAM. The device is manufactured using Atmel’s high-density nonvolatile memory technology and is compatible with the industry standard 80C51 and 80C52 instruction set and pinout. The on-chip Flash allows the program memory to be user programmed by a conventional nonvolatile memory programmer. By combining a versatile 8-bit CPU with Flash on a monolithic chip, the Atmel AT89C55WD is a powerful microcomputer which provides a highly flexible and cost effective solution to many embedded controlapplications. The AT89C55WD provides the following standard features: 20K bytes of Flash, 256 bytes of RAM, 32 I/O lines, three 16-bit timer/counters, a six-vector, two-level interrupt architecture, a full-duplex serial port, on-chip oscillator, and clock circuitry. In addition, the AT89C55WD is designed with static logic for operation down to zero frequency and supports two software selectable power saving modes. The Idle Mode stops the CPU while allowing the RAM, timer/counters, serial port, and interrupt system to continue functioning. The Power-down Mode saves the RAM contents but freezes the oscillator, disabling all other chip functions until the next external interrupt or hardware reset.
    AT89C55WD是一个低电压,高性能CMOS 8位单片机,片内含20k bytes的可反复擦写的Flash只读程序存储器和256bytes的随机存取数据存储器(RAM),器件采用ATMEL公司的高密度、非易失性存储技术生产,兼容标准MCS-51指令系统,引脚兼容工业标准89C51和89C52芯片,采用通用编程方式,片内置通用8位中央处理器和Flash存储单元,内置功能强大的微处理器的AT89C52可为您提供许多高性价比的解决方案,适用于多数嵌入式应用系统。 AT89C55WD有40个引脚,32个外部双向输入/输出(I/O)端口,同时内含2个外中断口,2个16位可编程定时计数器,2个全双工串行通信口,2个读写口线,片内时钟电路,AT89C55WD采用两种软件控制其进入省电睡眠模式的静态逻辑工作闲置方式设计,可以用RAM、定时/计数器、串行口和外部中断唤醒睡眠状态而继续工作,在睡眠模式下,RAM被冻结,其他功能全部停止,直至下个外中断触发或硬件复位方可开始运行。特别是可反复擦写的Flash存储器可有效地降低开发成本。 AT89C55WD有具有PLCC、PDIP和TQFP三种封装形式,以适应不同产品的需求。
    AT89C55WD 特性
    • Compatible with MCS?-51 Products
    • 20K Bytes of Reprogrammable Flash Memory
    • Endurance: 1000 Write/Erase Cycles
    • 4V to 5.5V Operating Range
    • Fully Static Operation: 0 Hz to 33 MHz
    • Three-level Program Memory Lock
    • 256 x 8-bit Internal RAM
    • 32 Programmable I/O Lines
    • Three 16-bit Timer/Counters
    • Eight Interrupt Sources
    • Programmable Serial Channel
    • Low-power Idle and Power-down Modes
    • Interrupt Recovery from Power-down Mode
    • Hardware Watchdog Timer
    • Dual Data Pointer
    • Power-off Flag
    • Green (Pb/Halide-free) Packaging Option
    • 兼容MCS51指令系统
    • 32个双向I/O口
    • 3个16位可编程定时/计数器中断
    • 2个串行中断
    • 2个外部中断源
    • 2个读写中断口线
    • 片内时钟电路
    • 4-5.5V工作电压范围
    • 20k可反复擦写(>1000次)Flash ROM
    • 256x8bit内部RAM
    • 时钟频率0-33MHz
    • 硬件看门狗(WDT)
    • 可编程串行通道
    • 3级加密位
    • 低功耗睡眠功能
    • 软件设置睡眠外中断唤醒功能
    AT89C55WD 订购型号
    Speed (MHz) Power Supply Ordering Code Package Operation Range
    24 4.0V to 5.5V AT89C55WD-24AU
    AT89C55WD-24JU
    AT89C55WD-24PU
    44A
    44J
    40P6
    Industrial (-40°C to 85°C)
    AT89C55WD 单片机解密服务
    可提供AT89C55WD 带20K 字节Flash 存储器高性能8位单片机机密服务:
    AT89C55WD-24AC 单片机解密(可以芯片解密,可以程序读写操作)
    AT89C55WD-24JC 单片机解密(可以芯片解密,可以程序读写操作)
    AT89C55WD-24PC 单片机解密(可以芯片解密,可以程序读写操作)
    AT89C55WD-24AI 单片机解密(可以芯片解密,可以程序读写操作)
    AT89C55WD-24JI 单片机解密(可以芯片解密,可以程序读写操作)
    AT89C55WD-24PI 单片机解密(可以芯片解密,可以程序读写操作)
    AT89C55WD-33AC 单片机解密(可以芯片解密,可以程序读写操作)
    AT89C55WD-33JC 单片机解密(可以芯片解密,可以程序读写操作)
    AT89C55WD-33PC 单片机解密(可以芯片解密,可以程序读写操作)
    AT89C55WD-24AU 单片机解密(可以芯片解密,可以程序读写操作)
    AT89C55WD-24JU 单片机解密(可以芯片解密,可以程序读写操作)
    AT89C55WD-24PU 单片机解密(可以芯片解密,可以程序读写操作) 备注:AT89C55WD 单片机解密服务,BDTIC 只提供合法的芯片解密服务。AT89C55WD 解密技术已经比较成熟,单片机解密难度很低,单片机解密成功的概率几乎100%,解密周期较短。 目前BDTIC 已经多次成功解密,需提供母片1片,当然如果能提供2片更好。
    . . . 关于ATMEL 爱特梅尔解密 . . .
    AT89C55WD 单片机技术支持
    1. AT89C55WD数据手册DataSheet 下载. PDF
    2. 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049)
    3. 80C51在系统Flash编程. PDF (编号:8051 00050)
    4. Device Programmers for 8051 Devices (Other, updated 09/07)
      This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers
    5. Emulators for 80C51 Devices (Other, updated 11/03)
      This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers
    6. Package Adapters of 80C51 Devices (Other, updated 10/04)
      This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
