龙人旗下深圳市龙芯世纪科技有限公司
  • AT89C5115 带有16K系统内可编程Flash存储器
  • 发布时间:2009/8/11 8:49:08   修改时间:2009/8/11 8:49:08 浏览次数:1410
    Flash (Kbytes)   16
    ISP   UART
    Self Program Memor   API
    EEPROM (Kbytes)   2
    RAM (Bytes)   512
    F.max (MHz)   40
    Vcc (V)   3-5.5
    I/O Pins   20
    UART   1
    16-bit Timers   2
    Watchdog   Yes
    ADC   Yes
    Packages    LQFP 32
     PLCC 28
     SOIC 28
    Pb-Free Packages    LQFP 32
     PLCC 28
     SOIC 28
    AT89C5115 概述
    Low-pin-count 8-bit Microcontroller with A/D Converter and 16K Bytes of Flash Memory We recommend to implement an external brown out to prevent any Flash/EEPROM corruption during power-on or power-off. Please refer to related application note: External Brown-out Protection for C51 Microcontrollers with Active High Reset Input. The T89C5115 is a high performance Flash version of the 80C51 single chip 8-bit microcontrollers.It contains a 16-KB Flash memory block for program and data.
    The 16-KB Flash memory can be programmed either in parallel mode or in serial mode with the ISP capability or with software. The programming voltage is internally generated from the standard VCC pin.
    The T89C5115 retains all features of the 80C52 with 256 bytes of internal RAM, a 7- source 4-level interrupt controller and three timer/counters. In addition, the T89C5115 has a 10-bit A/D converter, a 2-KB Boot Flash memory, 2-KB EEPROM for data, a Programmable Counter Array, an XRAM of 256 bytes, a Hardware WatchDog Timer and a more versatile serial channel that facilitates multiprocessor communication (EUART).
    The fully static design of the T89C5115 reduces system power consumption by bringing the clock frequency down to any value, even DC, without loss of data.
    The T89C5115 has two software-selectable modes of reduced activity and an 8 bit clock prescaler for further reduction in power consumption. In the idle mode the CPU is frozen while the peripherals and the interrupt system are still operating. In the power-down mode the RAM is saved and all other functions are inoperative.
    The added features of the T89C5115 make it more powerful for applications that need A/D conversion, pulse width modulation, high speed I/O and counting capabilities such as industrial control, consumer goods, alarms, motor control, etc. While remaining fully compatible with the 80C52 it offers a superset of this standard microcontroller.
    AT89C5115 特性
    • 80C51 Core Architecture
    • 256 Bytes of On-chip RAM
    • 256 Bytes of On-chip XRAM
    • 16K Bytes of On-chip Flash Memory
      – Data Retention: 10 Years at 85°C
      – Erase/Write Cycle: 100K
    • 2K Bytes of On-chip Flash for Bootloader
    • 2K Bytes of On-chip EEPROM
    • 14-sources 4-level Interrupts
    • Three 16-bit Timers/Counters
    • Full Duplex UART Compatible 80C51
    • Maximum Crystal Frequency 40 MHz. In X2 Mode, 20 MHz (CPU Core, 40 MHz)
    • Three or Four Ports: 16 or 20 Digital I/O Lines
    • Two-channel 16-bit PCA
      – PWM (8-bit)
      – High-speed Output
      – Timer and Edge Capture
    • Double Data Pointer
    • 21-bit Watchdog Timer (7 Programmable bits)
    • A 10-bit Resolution Analog-to-Digital Converter (ADC) with 8 Multiplexed Inputs
    • Power-saving Modes
      – Idle Mode
      – Power-down Mode
    • Power Supply: 3 Volts to 5.5 Volts
    • Temperature Range: Industrial (-40° to +85°C)
    • Packages: SOIC28, SOIC24, PLCC28, VQFP32
    AT89C5115 订购型号
    Part-Number Memory Size Supply
    Voltage
    Temperature
    Range
    Max
    Frequency
    Package Packing
    AT89C5115-SISUM 16K 5V Industrial Green 40 MHz PLCC28 Stick
    AT89C5115-TISUM 16K 5V Industrial Green 40 MHz SOIC28 Stick
    AT89C5115-RATUM 16K 5V Industrial Green 40 MHz VQFP32 Tray
    AT89C5115 技术支持
    1. AT89C5115 数据手册DataSheet 下载. PDF
    2. 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049)
    3. 80C51在系统Flash编程. PDF (编号:8051 00050)
    4. Device Programmers for 8051 Devices (Other, updated 09/07)
      This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers
    5. Emulators for 80C51 Devices (Other, updated 11/03)
      This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers
    6. Package Adapters of 80C51 Devices (Other, updated 10/04)
      This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
