龙人旗下深圳市龙芯世纪科技有限公司
  • AT89C51AC2 带有32K系统内可编程FLash存储器
  • 发布时间:2009/8/11 15:26:01   修改时间:2009/8/11 15:26:01 浏览次数:1434
    Flash (Kbytes)   32
    ISP   UART
    Self Program Memor   API
    EEPROM (Kbytes)   2
    RAM (Bytes)   1280
    F.max (MHz)   40
    Vcc (V)   3-5.5
    I/O Pins   34
    UART   1
    16-bit Timers   3
    Watchdog   Yes
    Packages   LQFP 44
    PLCC 44
    Pb-Free Packages   LQFP 44
    PLCC 44
    AT89C51AC2 概述
    8-bit microcontroller with 32Kbyte Flash, 2KByte EEPROM and 10-bit A/D converter
    We recommend to implement an external brown out to prevent any Flash/EEPROM corruption during power-on or power-off. Please refer to related application note: External Brown-out Protection for C51 Microcontrollers with Active High Reset Input.
    The A/T89C51AC2 is a high performance Flash version of the 80C51 single chip 8-bit microcontrollers. It contains a 32 KB Flash memory block for program and data.
    The 32 KB Flash memory can be programmed either in parallel mode or in serial mode with the ISP capability or with software. The programming voltage is internally generated from the standard VCC pin.
    The A/T89C51AC2 retains all features of the 80C51 with 256 bytes of internal RAM, a 7-source 4-level interrupt controller and three timer/counters. In addition, th A/T89C51AC2 has a 10-bit A/D converter, a 2 KB Boot Flash memory, 2 KB EEPROM for data, a Programmable Counter Array, an XRAM of 1024 bytes, a Hardware Watch- Dog Timer, and a more versatile serial channel that facilitates multiprocessor communication (EUART). The fully static design of the A/T89C51AC2 reduces system power consumption by bringing the clock frequency down to any value, even DC,without loss of data.
    The A/T89C51AC2 has two software-selectable modes of reduced activity and an 8-bit clock prescaler for further reduction in power consumption. In the idle mode the CPU is frozen while the peripherals and the interrupt system are still operating. In the Power-down mode the RAM is saved and all other functions are inoperative.
    The added features of the A/T89C51AC2 make it more powerful for applications that need A/D conversion, pulse width modulation, high speed I/O and counting capabilities such as industrial control, consumer goods, alarms, motor control, among others.
    While remaining fully compatible with the 80C52, the T8C51AC2 offers a superset of this standard microcontroller. In X2 mode, a maximum external clock rate of 20 MHz reaches a 300 ns cycle time.
    AT89C51AC2 特性
    • 80C51 Core Architecture
    • 256 Bytes of On-chip RAM
    • 1 KB of On-chip XRAM
    • 32 KB of On-chip Flash Memory
      – Data Retention: 10 Years at 85°C
      Read/Write Cycle: 10K
    • 2 KB of On-chip Flash for Bootloader
    • 2 KB of On-chip EEPROM
      Read/Write Cycle: 100K
    • 14-sources 4-level Interrupts
    • Three 16-bit Timers/Counters
    • Full Duplex UART Compatible 80C51
    • Maximum Crystal Frequency 40 MHz, in X2 Mode, 20 MHz (CPU Core, 20 MHz)
    • Five Ports: 32 + 2 Digital I/O Lines
    • Five-channel 16-bit PCA with:
      – PWM (8-bit)
      – High-speed Output
      – Timer and Edge Capture
    • Double Data Pointer
    • 21-bit Watchdog Timer (7 Programmable Bits)
    • 10-bit Resolution Analog to Digital Converter (ADC) with 8 Multiplexed Inputs
    • On-chip Emulation Logic (Enhanced Hook System)
    • Power Saving Modes:
      – Idle Mode
      – Power-down Mode
    • Power Supply: 3V to 5.5V
    • Temperature Range: Industrial (-40° to +85°C)
    • Packages: VQFP44, PLCC44
    AT89C51AC2 订购型号
    Part-Number Supply
    Voltage
    Temperature
    Range
    Max
    Frequency
    Package Packing
    AT89C51AC2-RLTUM 3V to 5.5V + 10% Industrial Green 40 MHz VQFP44 Tray
    AT89C51AC2-SLSUM PLCC44 Stick
    AT89C51AC2 技术支持
    1. AT89C51AC2 数据手册DataSheet 下载. PDF
    2. 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049)
    3. 80C51在系统Flash编程. PDF (编号:8051 00050)
    4. Device Programmers for 8051 Devices (Other, updated 09/07)
      This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers
    5. Emulators for 80C51 Devices (Other, updated 11/03)
      This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers
    6. Package Adapters of 80C51 Devices (Other, updated 10/04)
      This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
