龙人旗下深圳市龙芯世纪科技有限公司
  • AT89S8253 带有12K系统内可编程Flash系统
  • 发布时间:2009/8/11 15:44:12   修改时间:2009/8/11 15:44:12 浏览次数:1224
    Flash (Kbytes)   12
    ISP   SPI
    EEPROM (Kbytes)   2
    RAM (Bytes)   256
    F.max (MHz)   24
    Vcc (V)   2.7-5.5
    I/O Pins   32
    UART   1
    16-bit Timers   3
    Watchdog   Yes
    SPI   Yes
    Packages   TQFP 44
    PDIP 40
    PDIP 42
    PLCC 44
    Pb-Free Packages   TQFP 44
    PDIP 40
    PDIP 42
    PLCC 44
    In-System Programmable Microcontroller with 12K bytes Flash 2K bytes EEPROM
    AT89S8253 概述
    The AT89S8253 is a low-power, high-performance CMOS 8-bit microcontroller with 12K bytes of In-System Programmable (ISP) Flash program memory and 2K bytes of EEPROM data memory. The device is manufactured using Atmel’s high-density nonvolatile memory technology and is compatible with the industry-standard MCS-51 instruction set and pinout. The on-chip downloadable Flash allows the program memory to be reprogrammed in-system through an SPI serial interface or by a conventional nonvolatile memory programmer. By combining a versatile 8-bit CPU with downloadable Flash on a monolithic chip, the Atmel AT89S8253 is a powerful microcontroller which provides a highly-flexible and cost-effective solution to many embedded control applications.
    The AT89S8253 provides the following standard features: 12K bytes of In-System Programmable Flash, 2K bytes of EEPROM, 256 bytes of RAM, 32 I/O lines, programmable watchdog timer, two data pointers, three 16-bit timer/counters, a six-vector, four-level interrupt architecture, a full duplex serial port, on-chip oscillator, and clock circuitry. In addition, the AT89S8253 is designed with static logic for operation down to zero frequency and supports two software selectable power saving modes. The Idle Mode stops the CPU while allowing the RAM, timer/counters, serial port, and interrupt system to continue functioning. The Power-down mode saves the RAM contents but freezes the oscillator, disabling all other chip functions until the next external interrupt or hardware reset.
    The on-board Flash/EEPROM is accessible through the SPI serial interface. Holding RESET active forces the SPI bus into a serial programming interface and allows the program memory to be written to or read from, unless one or more lock bits have been activated.
    AT89S8253 特性
    • Compatible with MCS?-51 Products
    • 12K Bytes of In-System Programmable (ISP) Flash Program Memory
      – SPI Serial Interface for Program Downloading
      – Endurance: 10,000 Write/Erase Cycles
    • 2K Bytes EEPROM Data Memory
      – Endurance: 100,000 Write/Erase Cycles
    • 64-byte User Signature Array
    • 2.7V to 5.5V Operating Range
    • Fully Static Operation: 0 Hz to 24 MHz (in x1 and x2 Modes)
    • Three-level Program Memory Lock
    • 256 x 8-bit Internal RAM
    • 32 Programmable I/O Lines
    • Three 16-bit Timer/Counters
    • Nine Interrupt Sources
    • Enhanced UART Serial Port with Framing Error Detection and Automatic
      Address Recognition
    • Enhanced SPI (Double Write/Read Buffered) Serial Interface
    • Low-power Idle and Power-down Modes
    • Interrupt Recovery from Power-down Mode
    • Programmable Watchdog Timer
    • Dual Data Pointer
    • Power-off Flag
    • Flexible ISP Programming (Byte and Page Modes)
      – Page Mode: 64 Bytes/Page for Code Memory, 32 Bytes/Page for Data Memory
    • Four-level Enhanced Interrupt Controller
    • Programmable and Fuseable x2 Clock Option
    • Internal Power-on Reset
    • 42-pin PDIP Package Option for Reduced EMC Emission
    • Green (Pb/Halide-free) Packaging Option
    AT89S8253 订购型号
    Speed (MHz) Power
    Supply
    Ordering Code Package Operation Range
    24 2.7V to 5.5V AT89S8253-24AU
    AT89S8253-24JU
    AT89S8253-24PU
    AT89S8253-24PSU
    44A
    44J
    40P6
    42PS6
    Industrial (-40° C to 85° C)
    AT89S8253 技术支持
    1. AT89S8253数据手册DataSheet 下载. PDF
    2. 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049)
    3. 80C51在系统Flash编程. PDF (编号:8051 00050)
    4. Device Programmers for 8051 Devices (Other, updated 09/07)
      This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers
    5. Emulators for 80C51 Devices (Other, updated 11/03)
      This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers
    6. Package Adapters of 80C51 Devices (Other, updated 10/04)
      This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
