龙人旗下深圳市龙芯世纪科技有限公司
  • AT89EB5114
  • 发布时间:2009/8/11 15:48:41   修改时间:2009/8/11 15:48:41 浏览次数:1780
  • AT89EB5114
    AT89EB5114 特性
    • 80C51 Compatible
      – Two I/O Ports
      – Two 16-bit Timer/Counters
      – 256 bytes RAM
    • 4 Kbytes ROM or 4 Kbytes Flash Program Memory
    • 256 bytes EEPROM (Stack Die Packaging Technology on SO20 Package)
    • X2 Speed Improvement Capability (6 Clocks/Machine Cycle)
    • 10-bit, 6 Channels A/D Converter
      – One-channel with Progammable Gain and Rectifying Amplifier (Accuracy +/- 5%)
      – Voltage Reference for A/D External Analog
    • Hardware Watchdog Timer
    • Programmable I/O Mode: Standard C51, Input Only, Push-pull, Open Drain
    • Asynchronous Port Reset
    • Triple System Clock
      – Crystal or Ceramic Oscillator (24 MHz)
      – RC Oscillator (12 MHz), with Calibration Factor Using External R and C
      (Accuracy +/- 3.5% with Ideal R and C)
      – RC Oscillator, Low Power Consumption (12 MHz Low Accuracy)
      – Programmable Prescaler
    • One PWM Unit Block With:
      – 16-bits Programmable Counter
      – 3 Independent Modules
    • One PWM Unit Block with:
      – 16 bits Programmable Counter
      – 1 Module
    • Interrupt Structure With:
      – 7 Interrupt Sources,
      – 4 interrupt Priority Levels
    • Power Control Modes:
      – Idle Mode
      – Power-down Mode
      – Power Fail Detect, Power On Reset
      – Quiet mode for A to D Conversion
    • Power Supply: 3 to 3.6V
    • Temperature Range: -40 to 85o C
    • Package: SO20, SO24 (upon request)
    AT89EB5114 概述
    The AT8xEB5114 is a high performance version of the 80C51 8-bit microcontroller in a
    Low Pin Count package.
    The AT8xEB5114 retains all the features of the standard 80C51 with 4 Kbytes program
    memory, 256 bytes of internal RAM, a 7-source, 4-level interrupt system, an onchip
    oscillator and two timers/counters. AT8xEB5114 may include a serial two wire
    interface EEPROM housed together with the microcontroller die in the same package.
    The AT8xEB5114 is dedicated for analog interfacing applications. For this, it has a 10-
    bit, 6 channels A/D converter and two PWM units; these PWM blocks provide PWM
    generation with variable frequency and pulse width.
    In addition, the AT8xEB5114 has a Hardware Watchdog Timer and an X2 speed
    improvement mechanism. The X2 feature allows to keep the same CPU power at a
    divided by two oscillator frequency. The prescaler allows to decrease CPU and peripherals
    clock frequency. The fully static design of the AT8xEB5114 allows to reduce
    system power consumption by bringing the clock frequency down to any value, even
    DC, without loss of data.
    The AT8xEB5114 has 3 software-selectable modes of reduced activity for further reduction
    in power consumption. In idle mode the CPU is frozen while the peripherals are still
    operating. In quiet mode, only the A/D converter is operating. In power-down mode the
    RAM is saved and all other functions are inoperative. Three oscillator sources, crystal,
    precision RC and low power RC, provide versatile power management.
    AT89EB5114 订购型号
    Part Number Memory
    Size
    Supply
    Voltage
    Temperature
    Range
    Max Frequency Package Packing
    AT83EB5114xxxTGRIL OBSOLETE
    AT89EB5114-TGSIL OBSOLETE
    AT83EB5114xxxTGRUL 4Kb ROM 3 to 3.6V Industrial
    Green
    40 MHz S020 Reel
    AT89EB5114-TGSUL 4Kb Flash 3 to 3.6V Industrial
    Green
    40 MHz S020 Stick
    AT89EB5114 技术支持
    1. AT89EB5114 数据手册DataSheet 下载. PDF
    8051 结构单片机技术支持
    1. 《新闻报道》Atmel 新的單周期8051核心帶來顯著的性能提高與低能耗
    2. 《技术手册》AT/TSC8x251G2D.PDF
    3. 《技术手册》AT89C2051 .PDF
    4. 《技术手册》AT89C51ID2 Errata .PDF
    5. 《技术手册》AT89LP2052/4052 Rev. C Errata .PDF
    6. 《技术手册》AT89C51CC02, T89C51CC02.PDF
    7. 《技术手册》EMC Improvement Guidelines.PDF
    8. 《技术手册》TS83C51RC2 Reliability Qualification Report .PDF
    9. 《技术手册》External Brown-out Protection for C51 Microcontrollers with Active High Reset Input .PDF
    10. 《技术手册》C51 General Information about Bootloader and In-System Programming.PDF
    11. 《技术手册》How to Calculate the Capacitor of the Reset Input of a C51 Microcontroller .PDF
    12. 《技术手册》TS80C51RA2/TS80C51RD2/TS83C51RB2/TS83C51RC2/TS83C51RD2/TS87C51RB2/TS87C51RC2/TS87C51RD2 AT80C51RA2/A .PDF
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
