龙人旗下深圳市龙芯世纪科技有限公司
  • AT89C5131 带有USB接口8位FLash单片机
  • 发布时间:2009/8/12 10:51:03   修改时间:2009/8/12 10:51:03 浏览次数:1955
    Flash (Kbytes) 64
    USB Device Yes
    ISP Yes
    Self Program Memory Yes
    RAM (Bytes) 2304
    F.max (MHz) 20
    Vcc (V) 2.7-3.6
    I/O Pins 44
    UART Yes
    16-bit Timers Yes
    Watchdog Yes
    SPI Yes
    ADC Yes
    Packages LQFP 80
    USB C51-based Microcontroller with 64K Bytes Flash, 2304 bytes RAM, 4 USB Endpoints, SPI, UART, IDE, TWI, MultiMediaCard, DataFlash, I2S, 10-bit ADC.
    The AT89C5132 is a mass storage device controlling data exchange between various
    Flash modules, HDD and CD-ROM.
    The AT89C5132 includes 64K Bytes of Flash memory and allows In-System Programming through an embedded 4K Bytes of Boot Flash Memory.
    The AT89C5132 include 2304 Bytes of RAM memory.
    The AT89C5132 provides all the necessary features for man-machine interface including, timers, keyboard port, serial or parallel interface (USB, SPI, IDE), ADC input, I2S output, and all external memory interface (NAND or NOR Flash, SmartMedia, MultiMedia, DataFlash cards).
    AT89C5132 特性
    • Programmable Audio Output for Interfacing with Common Audio DAC
      – PCM Format Compatible
      – I2S Format Compatible
    • 8-bit MCU C51 Core-based (FMAX = 20 MHz)
    • 2304 Bytes of Internal RAM
    • 64K Bytes of Code Memory
      – AT89C5132: Flash (100K Write/Erase Cycles)
    • 4K Bytes of Boot Flash Memory (AT89C5132)
      – ISP: Download from USB (standard) or UART (option)
    • USB Rev 1.1 Device Controller
      – “Full Speed” Data Transmission
    • Built-in PLL
    • MultiMedia Card? Interface Compatibility
    • Atmel DataFlash? SPI Interface Compatibility
    • IDE/ATAPI Interface
    • 2 Channels 10-bit ADC, 8 kHz (8 True Bits)
      – Battery Voltage Monitoring
      – Voice Recording Controlled by Software
    • Up to 44 Bits of General-purpose I/Os
      – 4-bit Interrupt Keyboard Port for a 4 x n Matrix
      – SmartMedia? Software Interface
    • Two Standard 16-bit Timers/Counters
    • Hardware Watchdog Timer
    • Standard Full Duplex UART with Baud Rate Generator
    • Two Wire Master and Slave Modes Controller
    • SPI Master and Slave Modes Controller
    • Power Management
      – Power-on Reset
      – Software Programmable MCU Clock
      – Idle Mode, Power-down Mode
    • Operating Conditions
      – 3V, ±10%, 25 mA Typical Operating at 25°C
      – Temperature Range: -40°C to +85°C
    • Packages
      – TQFP80, PLCC84 (Development Board Only)
      – Dice
    AT89C5132 订货型号
    Part Number Memory Size (Bytes) Supply Voltage Temperature Range Max Frequency (MHz) Package Packing Product Marking
    AT89C5132-ROTUL 64K Flash 3V Industrial Green 40 TQFP80 Tray 895132-UL
    AT89C5132 技术支持
    1. AT89C5132 数据手册DataSheet 下载. PDF
    2. 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049)
    3. 80C51在系统Flash编程. PDF (编号:8051 00050)
    4. Device Programmers for 8051 Devices (Other, updated 09/07)
      This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers
    5. Emulators for 80C51 Devices (Other, updated 11/03)
      This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers
    6. Package Adapters of 80C51 Devices (Other, updated 10/04)
      This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
