龙人旗下深圳市龙芯世纪科技有限公司
  • AT89C51CC02 / T89C51CC02 带有16K系统内可编程FLash存储器
  • 发布时间:2009/8/12 10:59:05   修改时间:2009/8/12 10:59:05 浏览次数:1557
    Flash (Kbytes) 16
    CAN (mess. Obj.) 4
    ISP Yes
    Self Program Memory Yes
    EEPROM (Kbytes) 2
    RAM (Bytes) 512
    F.max (MHz) 40
    Vcc (V) 3-5.5
    I/O Pins 20
    UART 1
    16-bit Timers 1
    Watchdog Yes
    ADC Yes
    Packages   LQFP 32
    PLCC 28
    SOIC 24
    SOIC 28
    Pb-Free Packages   LQFP 32
    PLCC 28
    SOIC 24
    SOIC 28
    AT89C51CC02 / T89C51CC02 概述 Low pin count 8-bit microcontroller with CAN controller and 16-Kbyte Flash
    We recommend to implement an external brown out to prevent any Flash/EEPROM corruption during power-on or power-off. Please refer to related application note: External Brown-out Protection for C51 Microcontrollers with Active High Reset Input
    AT89C51CC02 / T89C51CC02 特性
    • 80C51 Core Architecture
    • 256 Bytes of On-chip RAM
    • 256 Bytes of On-chip XRAM
    • 16K Bytes of On-chip Flash Memory
      – Data Retention: 10 Years at 85°C
      – Erase/Write Cycle: 100K
    • Boot Code Section with Independent Lock Bits
    • 2K Bytes of On-chip Flash for Bootloader
    • In-System Programming by On-Chip Boot Program (CAN, UART) and IAP Capability
    • 2K Bytes of On-chip EEPROM
    • 14-sources 4-level Interrupts
    • Three 16-bit Timers/Counters
    • Full Duplex UART Compatible 80C51
    • Maximum Crystal Frequency 40 MHz. In X2 Mode, 20 MHz (CPU Core, 40 MHz)
    • Three or Four Ports: 16 or 20 Digital I/O Lines
    • Two-channel 16-bit PCA
      – PWM (8-bit)
      – High-speed Output
      – Timer and Edge Capture
    • Double Data Pointer
    • 21-bit Watchdog Timer (7 Programmable bits)
    • A 10-bit Resolution Analog-to-Digital Converter (ADC) with 8 Multiplexed Inputs
    • Full CAN Controller
      – Fully Compliant with CAN rev.# 2.0A and 2.0B
      – Optimized Structure for Communication Management (Via SFR)
      – 4 Independent Message Objects
      -Each Message Object Programmable on Transmission or Reception
      -Individual Tag and Mask Filters up to 29-bit Identifier/Channel
      -8-byte Cyclic Data Register (FIFO)/Message Object
      -16-bit Status and Control Register/Message Object
      -16-bit Time-Stamping Register/Message Object
      -CAN Specification 2.0 Part A or 2.0 Part B Programmable for Each Message
      Object
      -Access to Message Object Control and Data Registers Via SFR
      -Programmable Reception Buffer Length up to 4 Message Objects
      -Priority Management of Reception of Hits on Several Message Objects
      Simultaneously (Basic CAN Feature)
      -Priority Management for Transmission
      -Message Object Overrun Interrupt
      – Supports
      -Time Triggered Communication
      -Autobaud and Listening Mode
      -Programmable Automatic Reply Mode
    • 1-Mbit/s Maximum Transfer Rate at 8 MHz(1) Crystal Frequency In X2 Mode
    • Readable Error Counters
    • Programmable Link to On-chip Timer for Time Stamping and Network Synchronization
    • Independent Baud Rate Prescaler
    • Data, Remote, Error and Overload Frame Handling
    • Power-saving Modes
      – Idle Mode
      – Power-down Mode
    • Power Supply: 3 Volts to 5.5 Volts
    • Temperature Range: Industrial (-40° to +85°C)
    • Packages: SOIC28, SOIC24, PLCC28, VQFP32
    AT89C51CC02 / T89C51CC02 订购型号
    Part Number Boot Loader Temperature Range Package Packing Product Marking
    AT89C51CC02CA-RATUM CAN Industrial Green VQFP32 Tray 89C51CC02CA-UM
    AT89C51CC02CA-SISUM CAN Industrial Green PLCC28 Stick 89C51CC02CA-UM
    AT89C51CC02CA-TDSUM CAN Industrial Green SOIC24 Stick 89C51CC02CA-UM
    AT89C51CC02CA-TISUM CAN Industrial Green SOIC28 Stick 89C51CC02CA-UM
    AT89C51CC02UA-RATUM UART Industrial Green VQFP32 Tray 89C51CC02UA-UM
    AT89C51CC02UA-SISUM UART Industrial Green PLCC28 Stick 89C51CC02UA-UM
    AT89C51CC02UA-TDSUM UART Industrial Green SOIC24 Stick 89C51CC02UA-UM
    AT89C51CC02UA-TISUM UART Industrial Green SOIC28 Stick 89C51CC02UA-UM
    T89C51CC02 停产型号
    T89C51CC02CA-RATIM
    T89C51CC02CA-SISIM
    T89C51CC02CA-TDSIM
    T89C51CC02CA-TISIM
    T89C51CC02UA-RATIM
    T89C51CC02UA-SISIM
    T89C51CC02UA-TDSIM
    T89C51CC02UA-TISIM
    AT89C51CC02 / T89C51CC02 技术支持
    1. AT89C51CC02 数据手册DataSheet 下载. PDF
    2. 80C51微控制器的复位输入. PDF (编号: Tech 8051 00049)
    3. 80C51在系统Flash编程. PDF (编号:8051 00050)
    4. Device Programmers for 8051 Devices (Other, updated 09/07)
      This Excel spreadsheet provide summary information on device programmers supporting Atmel 8051 microcontrollers
    5. Emulators for 80C51 Devices (Other, updated 11/03)
      This Excel spreadsheet provide summary information on emulation support for Atmel 80C51 microcontrollers
    6. Package Adapters of 80C51 Devices (Other, updated 10/04)
      This Excel spreadsheet list available package adapters for Atmel 80C51 microcontrollers
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
