龙人旗下深圳市龙芯世纪科技有限公司
  • AT45DCB002D 2Mbit,DataFlash存储器
  • 发布时间:2009/8/13 10:29:12   修改时间:2009/8/13 10:29:12 浏览次数:1092
    Density 2M
    I/O Pins 7
    Interface Type Serial
    Page Size (Bytes) 528
    Vcc (V) 2.7
    Packages  DataFlash Card 7
    Not recommended for new designs. 2M byte, 2.7-Volt Only, Serial Interface DataFlash Card
    The AT45DCB008D, AT45DCB004D and AT45DCB002D are 2.7-volt only SPI compatible serial interface DataFlash? Cards. They are offered in 8-megabyte (64-Mbit), 4-megabyte (32-Mbit) and 2-megabyte (16-Mbit), densities. These 7-pin cards are form factor compatible to the MultiMediaCard standard leveraging on a wide range of low cost connectors that are commercially available. Additionally, the DataFlash Card is pinout compatible to the SPI version of the MMC card. The small form factor and simple interface make the DataFlash Card ideal for a wide variety of data- and program code-storage applications where a removable storage medium is required. Applications range from voice/audio, text or image storage to software applications, system upgrades and software patches.
    AT45DCB002D 特性
    • MultiMediaCard (MMC) Form Factor
    • Single 2.7V to 3.6V Supply
    • 66 MHz Max Clock Frequency
    • Serial Peripheral Interface (SPI) Compatible
    • Low Power Dissipation
      – 10 mA Active Read Current Typical
      – 25 μA CMOS Standby Current Typical
    • Industrial Temperature Range
    • Pb-free/RoHS-compliant Package
    AT45DCB002D订购型号
    ICC (mA) fSCK
    (MHz)
    Ordering Code Package Max. Freq.
    (MHz)
    Operation Range
    Active AStandby
    15 0.05 66 AT45DCB008D
    AT45DCB004D
    AT45DCB002D
    7DF1 66 Industrial (-40°C to +85°C)
    AT45DCB002D 技术支持:
    1. ATMEL 爱特梅尔Flash 存储器AT45DCB002D 数据手册DataSheet 下载. PDF(PDF 文件格式完整版)
    2. 串行Flash 产品选型指南Excel 文档格式选型 Excel 文档格式)
    3. ATMEL 爱特梅尔公司全线产品目录. pdf
    4. Programmer Support for Serial Flash Devices. pdf (Other, 8 pages, revision C, updated 4/08)
    5. MicroLeadFrame Packages Pad Landing Recommendations (15 pages, revision B, updated 09/06). pdf
      This application note provides PCB designers with a set of guidelines for successful board mounting of Atmel's DataFlash memories housed in the MicroLeadFrame (MLF) package.
    6. AN-4: Using Atmel's DataFlash (30 pages, updated 11/02) . pdf
      Atmel's DataFlash is a new Flash family designed specifically for data storage applications. This Application Note describes this family.
    7. DataFlash Binary Page Size (2 pages, revision A, updated 5/08) . pdf
      Factory Configured DataFlash Binary Page Size options
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
