龙人旗下深圳市龙芯世纪科技有限公司
  • AT27BV020 2Mbit, OTP EPROM存储器
  • 发布时间:2009/8/13 10:34:18   修改时间:2009/8/13 10:34:18 浏览次数:1118
    Density 2M
    Organization 256K x 8
    Speed 90 ns
    Vcc (V) 2.7
    Packages TSOP 32
    VSOP 32
    PLCC 32
    Pb-Free Packages TSOP 32
    PLCC 32
    2M Bit, 2.7-Volt to 3.6-Volt EPROM
    The AT27BV020 is a high-performance, low-power, low-voltage, 2,097,152-bit, onetime programmable, read-only memory (OTP EPROM) organized as 256K by 8 bits. It requires only one supply in the range of 2.7 to 3.6V in normal read mode operation, making it ideal for fast, portable systems using either regulated or unregulated battery power.Atmel’s innovative design techniques provide fast speeds that rival 5V parts while keeping the low power consumption of a 3V supply. At VCC = 2.7V, any byte can be accessed in less than 90 ns. With a typical power dissipation of only 18 mW at 5 MHz and VCC = 3V, the AT27BV020 consumes less than one fifth the power of a standard 5V EPROM. Standby mode supply current is typically less than 1 μA at 3V. TheAT27BV020 simplifies system design and stretches battery lifetime even further by eliminating the need for power supply regulationThe AT27BV020 is available in industry-standard JEDEC approved one-time programmable(OTP) plastic PLCC, TSOP and VSOP packages, as well as a 42-ball,1 mm pitch. All devices feature two-line control (CE, OE) to give designers the flexibilityto prevent bus contention. The AT27BV020 operating with VCC at 3.0V produces TTL level outputs that are compatiblewith standard TTL logic devices operating at VCC = 5.0V. At VCC = 2.7V, the part is compatible with JEDEC approved low voltage battery operation (LVBO) interface specifications. The device is also capable of standard 5-volt operation making it ideally suited for dual supply range systems or card products that are pluggable in both 3-volt and 5-volt hosts. Atmel's AT27BV020 has additional features to ensure high quality and efficient production use. The Rapid Programming Algorithm reduces the time required to program the part and guarantees reliable programming. Programming time is typically only 100 μs/byte. The Integrated Product Identification Code electronically identifies the device and manufacturer. This feature is used by industry-standard programming equipment to select the proper programming algorithms and voltages. The AT27BV020 programs exactly the same way as a standard 5V AT27C020 and uses the same programming equipment.
    AT27BV020 特性
    • Fast Read Access Time – 90 ns
    • Dual Voltage Range Operation
      – Unregulated Battery Power Supply Range, 2.7V to 3.6V
      or Standard 5V ± 10% Supply Range
    • Compatible with JEDEC Standard AT27C020
    • Low-power CMOS Operation
      – 20 μA Max (Less than 1 μA Typical) Standby for VCC = 3.6V
      – 29 mW Max Active at 5 MHz for VCC = 3.6V
    • Wide Selection of JEDEC Standard Packages
      – 32-lead PLCC
      – 32-lead TSOP
      – 32-lead VSOP
    • High Reliability CMOS Technology
      – 2,000V ESD Protection
      – 200 mA Latch-up Immunity
    • Rapid Programming Algorithm – 100 μs/Byte (Typical)
    • CMOS and TTL Compatible Inputs and Outputs
      – JEDEC Standard for LVTTL and LVBO
    • Integrated Product Identification Code
    • Industrial Temperature Range
    • Green (Pb/Halide-free) Packaging Option
    AT27BV020 订购型号
    Ordering Code Package ICC (mA)
    VCC = 3.6V
    tACC
    (ns)
    Operation Range
    Active AStandby
    AT27BV020-90JU
    AT27BV020-90TU
    32J
    32T
    8 0.02 90 Industrial (-40°C to +85°C)
    AT27BV020 技术支持:
    1. ATMEL 爱特梅尔EPROM 存储器AT27BV020 数据手册DataSheet 下载. PDF(PDF 文件格式完整版)
    2. EPROM 产品选型指南Excel 文档格式选型 Excel 文档格式)
    3. ATMEL 爱特梅尔公司全线产品目录. pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
