龙人旗下深圳市龙芯世纪科技有限公司
  • AT27BV040 4Mbit, OTP EPROM存储器
  • 发布时间:2009/8/13 10:34:54   修改时间:2009/8/13 10:34:54 浏览次数:1236
    Density 4M
    Organization 512K x 8
    Speed 120 ns
    Vcc (V) 2.7
    Packages TSOP 32
    VSOP 32
    PLCC 32
    Pb-Free Packages TSOP 32
    PLCC 32
    4M bit, 2.7-Volt to 3.6-Volt EPROM
    The AT27BV040 chip is a high performance, low power, low voltage, 4,194,304-bit one-time programmable read only memory (EPROM) organized as 512K by 8 bits. It requires only one supply in the range of 2.7 to 3.6V in normal read mode operation, making it ideal for fast, portable systems using either regulated or unregulated batterypower. Atmel’s innovative design techniques provide fast speeds that rival 5V parts while keeping the low power consumption of a 3V supply. At VCC = 2.7V, any byte can be accessed in less than 100 ns. With a typical power dissipation of only 18 mW at 5 MHz and VCC = 3V, the AT27BV040 consumes less than one fifth the power of a standard 5V EPROM. Standby mode supply current is typically less than 1 μA at 3V. The AT27BV040 simplifies system design and stretches battery lifetime even further by eliminating the need for power supply regulation.
    The AT27BV040 is available in industry-standard JEDEC-approved one-time programmable (OTP) plastic PLCC, TSOP, and VSOP packages. All devices feature twoline control (CE, OE) to give designers the flexibility to prevent bus contention. The AT27BV040 operating with VCC at 3.0V produces TTL level outputs that are compatible with standard TTL logic devices operating at VCC = 5.0V. At VCC = 2.7V, the part is compatible with JEDEC approved low voltage battery operation (LVBO) interface specifications. The device is also capable of standard 5-volt operation making it ideally suited for dual supply range systems or card products that are pluggable in both 3-volt and 5-volt hosts. Atmel’s AT27BV040 has additional features to ensure high quality and efficient production use. The Rapid Programming Algorithm reduces the time required to program the part and guarantees reliable programming. Programming time is typically only 100 μs/byte. The Integrated Product Identification Code electronically identifies the device and manufacturer. This feature is used by industry-standard programming equipment to select the proper programming algorithms and voltages. The AT27BV040 programs exactly the same way as a standard 5V AT27C040 and uses the same programming equipment.
    AT27BV040 特性
    • Fast Read Access Time – 120 ns
    • Dual Voltage Range Operation
      – Unregulated Battery Power Supply Range, 2.7V to 3.6V
      or Standard 5V ± 10% Supply Range
    • Compatible with JEDEC Standard AT27C040
    • Low Power CMOS Operation
      – 20 μA Max (Less than 1 μA Typical) Standby for VCC = 3.6V
      – 36 mW Max Active at 5 MHz for VCC = 3.6V
    • JEDEC Standard Packages
      – 32-lead PLCC
      – 32-lead TSOP
      – 32-lead VSOP
    • High Reliability CMOS Technology
      – 2,000V ESD Protection
      – 200 mA Latchup Immunity
    • Rapid Programming Algorithm – 100 μs/Byte (Typical)
    • CMOS and TTL Compatible Inputs and Outputs
      – JEDEC Standard for LVTTL and LVBO
    • Integrated Product Identification Code
    • Industrial Temperature Range
    • Green (Pb/Halide-free/RoHS Compliant) Packaging
    AT27BV040 订购型号
    Ordering Code Package ICC (mA)
    VCC = 3.6V
    tACC
    (ns)
    Operation Range
    Active AStandby
    AT27BV040-12JU
    AT27BV040-12TU
    32J
    32T
    8 0.02 120 Industrial (-40°C to +85°C)
    AT27BV040 技术支持:
    1. ATMEL 爱特梅尔EPROM 存储器AT27BV040 数据手册DataSheet 下载. PDF(PDF 文件格式完整版)
    2. EPROM 产品选型指南Excel 文档格式选型 Excel 文档格式)
    3. ATMEL 爱特梅尔公司全线产品目录. pdf
    4. AT27BV040 Reliability Qualification Report (Qualification, 7 pages, updated 10/03). pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
