龙人旗下深圳市龙芯世纪科技有限公司
  • AT27C1024 1Mbit, OTP EPROM存储器
  • 发布时间:2009/8/13 10:43:41   修改时间:2009/8/13 10:43:41 浏览次数:1666
    Density 1M
    Organization 64K x 16
    Speed 45,70 ns
    Vcc (V) 5
    Packages VSOP 40
    PDIP 40
    PLCC 44
    Pb-Free Packages  PDIP 40
    PLCC 44
    1M bit, x16 EPROM
    The AT27C1024 is a low-power, high-performance 1,048,576 bit one-time programmable read-only memory (OTP EPROM) organized 64K by 16 bits. It requires only one 5V power supply in normal read mode operation. Any word can be accessed in less than 45 ns, eliminating the need for speed reducing WAIT states. The by-16 organization make this part ideal for high-performance 16- and 32-bit microprocessor systems. In read mode, the AT27C1024 typically consumes 15 mA. Standby mode supply current is typically less than 10 μA.
    The AT27C1024 is available in industry-standard JEDEC-approved one-time programmable (OTP) plastic PDIP, PLCC, and VSOP packages. The device features two-line control (CE, OE) to eliminate bus contention in high-speed systems. With high density 64K word storage capability, the AT27C1024 allows firmware to be stored reliably and to be accessed by the system without the delays of mass storage media. Atmel’s AT27C1024 have additional features to ensure high quality and efficient production use. The Rapid Programming Algorithm reduces the time required to program the part and guarantees reliable programming. Programming time is typically only 100 μs/word. The Integrated Product Identification Code electronically identifies the device and manufacturer. This feature is used by industry-standard programming equipment to select the proper programming algorithms and voltages.
    AT27C1024 特性
    • Fast Read Access Time – 45 ns
    • Low-Power CMOS Operation
      – 100 μA Max Standby
      – 30 mA Max Active at 5 MHz
    • JEDEC Standard Packages
      – 40-lead PDIP
      – 44-lead PLCC
      – 40-lead VSOP
    • Direct Upgrade from 512K (AT27C516) EPROM
    • 5V ± 10% Power Supply
    • High-Reliability CMOS Technology
      – 2000V ESD Protection
      – 200 mA Latchup Immunity
    • Rapid Programming Algorithm – 100 μs/Word (Typical)
    • CMOS and TTL Compatible Inputs and Outputs
    • Integrated Product Identification Code
    • Industrial and Automotive Temperature Ranges
    • Green (Pb/Halide-free) Packaging Option
    AT27C1024 订购型号
    Ordering Code Package ICC (mA)
    VCC = 3.6V
    tACC
    (ns)
    Operation Range
    Active AStandby
    AT27C1024-45JU
    AT27C1024-45PU
    44J
    40P6
    30 0.1 45 Industrial (-40°C to +85°C)
    AT27C1024-70JU
    AT27C1024-70PU
    44J
    40P6
    30 0.1 70 Industrial (-40°C to +85°C)
    AT27C1024 技术支持:
    1. ATMEL 爱特梅尔EPROM 存储器AT27C1024 数据手册DataSheet 下载. PDF(PDF 文件格式完整版)
    2. EPROM 产品选型指南Excel 文档格式选型 Excel 文档格式)
    3. ATMEL 爱特梅尔公司全线产品目录. pdf
    4. AT27C1024 Reliability Qualification Report (Qualification, 7 pages, updated 10/03). pdf
    5. AT27CXXX Series (1 pages, updated 10/98) . pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
