龙人旗下深圳市龙芯世纪科技有限公司
  • AT27C256R 256Kbit, OTP EPROM存储器
  • 发布时间:2009/8/13 10:47:56   修改时间:2009/8/13 10:47:56 浏览次数:1187
    Density 256K
    Organization 32K x 8
    Speed 45,70 ns
    Vcc (V) 5
    Packages TSOP 28
    PDIP 28
    PLCC 32
    SOIC (330mil) 28
    Pb-Free Packages TSOP 28
    PDIP 28
    PLCC 32
    SOIC (330mil) 28
    256K EPROM
    The AT27C256R is a low-power, high-performance 262,144-bit one-time programmable read-only memory (OTP EPROM) organized 32K by 8 bits. It requires only one 5V power supply in normal read mode operation. Any byte can be accessed in less than 45 ns, eliminating the need for speed reducing WAIT states on high-performance microprocessor systems. Atmel’s scaled CMOS technology provides low-active power consumption, and fast programming. Power consumption is typically only 8 mA in Active Mode and less than 10 μA in Standby.
    The AT27C256R is available in a choice of industry-standard JEDEC-approved one time programmable (OTP) plastic DIP, PLCC, SOIC, and TSOP packages. All devices feature two-line control (CE, OE) to give designers the flexibility to prevent bus contention. With 32K byte storage capability, the AT27C256R allows firmware to be stored reliably and to be accessed by the system without the delays of mass storage media. Atmel’s AT27C256R has additional features to ensure high quality and efficient production use. The Rapid Programming Algorithm reduces the time required to program the part and guarantees reliable programming. Programming time is typically only 100 μs/byte. The Integrated Product Identification Code electronically identifies the device and manufacturer. This feature is used by industry-standard programming equipment to select the proper programming algorithms and voltages.
    AT27C256R 特性
    • Fast Read Access Time – 45 ns
    • Low-Power CMOS Operation
      – 100 μA Max Standby
      – 20 mA Max Active at 5 MHz
    • JEDEC Standard Packages
      – 28-lead PDIP
      – 32-lead PLCC
      – 28-lead TSOP and SOIC
    • 5V ± 10% Supply
    • High Reliability CMOS Technology
      – 2,000V ESD Protection
      – 200 mA Latchup Immunity
    • Rapid Programming Algorithm – 100 μs/Byte (Typical)
    • CMOS and TTL Compatible Inputs and Outputs
    • Integrated Product Identification Code
    • Industrial and Automotive Temperature Ranges
    • Green (Pb/Halide-free) Packaging Option
    AT27C256R 订购型号
    Ordering Code Package ICC (mA)
    VCC = 3.6V
    tACC
    (ns)
    Operation Range
    Active AStandby
    AT27C256R-45JU
    AT27C256R-45PU
    AT27C256R-45RU
    AT27C256R-45TU
    32J
    28P6
    28R(1)
    28T
    20 0.1 45 Industrial (-40°C to +85°C)
    AT27C256R-70JU
    AT27C256R-70PU
    AT27C256R-70RU
    AT27C256R-70TU
    32J
    28P6
    28R(1)
    28T
    20 0.1 70 Industrial (-40°C to +85°C)
    AT27C256R 技术支持:
    1. ATMEL 爱特梅尔EPROM 存储器AT27C256R 数据手册DataSheet 下载. PDF(PDF 文件格式完整版)
    2. EPROM 产品选型指南Excel 文档格式选型 Excel 文档格式)
    3. ATMEL 爱特梅尔公司全线产品目录. pdf
    4. AT27CXXX Series (1 pages, updated 10/98) . pdf
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
